Type : Ampli Stéréo Pro
Marque : Crown
Modèle et options : K1
Prix de vente : 550€00
Département où la marchandise est visible : 95
Montant des frais d'expédition : 30€
Première main : non
Prix neuf : 1800€
Facture disponible : non
Date, pays et lieu d'achat : France 2015
Power Output
2-ohm Stereo (Per Channel): 750W
4-ohm Stereo (Per Channel): 550W
8-ohm Stereo (Per Channel): 350W
4-ohm Bridged-Mono: 1500W
8-ohm Bridged-Mono: 1100W
No Fan No Noise
Patented BCATM Circuit Design
Unmatched Thermal Efficiency
Superior Energy Efficiency
Sealed Chassis
Universal Power Supply
Modular Design and Construction for Quick Service
TLC -Thermal Level Control Protection Subtly and Dynamically Reduces Gain As Needed
Automatic Turn-On Diagnostics
Voltage Gain (at maximum level setting): 31.5 dB (K1) ) with input sensitivity switch set to 1.4V. 26 dB with input sensitivity switch set to 26 dB gain (back panel switchable).
Damping Factor: >3,000 from 10 to 400 Hz
Line Voltage Requirements: Universal power supply can be configured to operate with 100, 120, 200, 220, 230, 240, 250 VAC at 50 or 60 Hz. Adapters are available through a Crown or Authorized Service Center.
Back Panel Controls
Input Sensitivity: A two-position switch for each channel located near each channel's input connectors. Can be set to 1.4 V for full output into an 8 ohm load or a fixed voltage gain of 26 dB.
Bridge Output: An on/off switch near each channel's input connectors which, when turned on, bridges the two output channels for twice the output voltage.
"Y" Input: An on/off switch located between the input connectors which, when turned on, parallels the two input channels.
Dimensions: Standard 19-inch (48.3 cm) rack mount width (EIA RS-310-B), 3.5-inch (8.9 cm) height and 16-inch (40.6 cm) depth behind front mounting surface.
Approximate Weight:K1: 32 pounds (14.6 kg).K2: 38 pounds (17.3 kg).
Site web du constructeur :
Excellent ampli pro parfaitement silencieux, très puissant, excellent sur le grave! Etat neuf (acheté dans un studio pro ou il était en spare).....Je vais vendre pas mal d'appareils...fini la hifi...
4 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: fredz1432, imotep27000 et 34 invités
Ampli Crown K1 (Vendu)
alfachris - Membre HCFR
- Inscription Forum: 12 Aoû 2003 21:36
Baisse du prix : 550€00
MP envoyé
- jayce996
- Inscription Forum: 06 Nov 2006 22:23
4 messages
