Type : Amplificateur stéréo de puissance
Marque : Parasound
Modèle et options : NewClassic 2125v2
Prix de vente : 450 €
Département où la marchandise est visible : 63
Montant des frais d'expédition : colissimo avec assurance 25 €
État de la marchandise : excellent état, quelques marques sans importances très discrètes (voir photos), parfait état de marche
Première main : non
Prix neuf : 1200 €
Facture disponible : non
Date, pays et lieu d'achat : sur le forum il y a 1,5 an
Garantie et date d'expiration : n/a
Numéro de série : sur demande je vous dis ça
THX Ultra2 certified
150 watts x 2 into 8 Ω (all channels driven)
225 watts x 2 into 4 Ω or 2 Ω (all channels driven)
400 watts x 1 bridged into 8 Ω or 4 Ω
35 amps peak current per channel
2 Ohm stable operation with load selector switch
Two pairs of speaker outputs with front panel A/B buttons
Rear-mounted lockout switch disables front A/B buttons
High pass filter, switchable for 20Hz or 40Hz
Automatic on/off by DC trigger with looping output
Automatic on/off by audio signal with 2 sensitivity settings
Fully discrete circuitry with high current toroid transformer
Bridging switch for stereo or mono operation
Efficient, low heat design
DC Servo and relay protection circuits
Rear-mounted left and right gain controls
Standby, channel status and high temperature indicators
Gold-plated RCA input jacks
Heavy duty 24k gold-plated 5-way speaker terminals
115/230v selector on rear panel
20 Hz - 50 kHz, +0/-3 dB, 1 watt
Dynamic Headroom - 1.3 dB Total Harmonic Distortion
0.25% at full rated output
0.015% at average listening levels IM Distortion - 0.05 %
Transient IM Distortion - Not measurable S/N Ratio
114 dB at rated output, IHF A-weighted
106 dB at rated output, unweighted
93 dB at 2.828 V output, IHF A-weighted
84 dB at 2.828 V output, unweighted Input Impedance - 33 k Ω Input Sensitivity
1 V in for 28.28 V out, THX standard Inter-Channel Crosstalk
85 dB @1 kHz, 73 dB @10 kHz, 67 dB @ 20kHz
Damping Factor - Over 150 at 20Hz
12V Trigger Turn On - DC 9 – 12V, 15 mA Audio Turn On
Quieter: 1 mV
Louder: 6 mV AC Power Requirement
110 - 120 V / 220 -240 V, 50 - 60 Hz
0.5 watts standby
32 watts Idle (no audio)
550 watts full output Dimensions
171/4" Wide
16" Deep, with cables connected
4.25" High with feet, 3.5" panel only (2U)
(437 x 406 x 107mm, 88.2 mm panel only) Net Weight - 27 lbs (12.3 kg)
Site web du constructeur : http://parasound.com/2125-v2.php
Commentaires : Excellente amplificateur, dynamique et chaleureux. Je pourrais le garder, mais j'arrête la collectionnite. Revente pour cause de montée en gamme.
2 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 27 invités
[VENDU] Parasound stéréo 2125v2 THX - 2x150W
http://www.multiroom.fr - l'actualité de la musique sans fil partout dans la maison
multiroom - Membre HCFR
- Inscription Forum: 06 Juil 2000 2:00
Vendu !
2 messages
