Type : Amplificateur intégré
Marque : Manley
Modèle et options : Stingray
Prix de vente : 1200
Département où la marchandise est visible : 38
Montant des frais d'expédition : 60 via transporteur assuré.
État de la marchandise : trés bon état
Première main : non
Prix neuf :
Facture disponible : oui
Date, pays et lieu d'achat : échangé sur le site
Numéro de série : en mp au besoin
Manley Stingray®
4 x Stereo Line RCA Inputs
TRIODE - UL Switching
RECORDING OUT
SUBWOOFER OUT
TAPE LOOP (Insert) with Bypass switch
Passive Noble Volume and Balance Controls
All-Vacuum Tube Lo-feedback Stereo Integrated Design
Output Tubes: 8 x EL84 Ships with Russian NOS EL84M (aka 6Pi14Pi-EB) (We are out of Ei 6BQ5)
Driver Tubes: 2 x 6414 Ships with GE or RAYTHEON JAN NOS USA or 6414W
Input Tubes: 2 x 12AT7EH Ships with: 12AT7EH large plate Electro-Harmonix Russian
Maximum Output Power UL mode: 40 Watts x 2 channels 1.5% THD @ 1kHz
Maximum Output Power TRIODE mode: 20 Watts x 2 channels
Frequency Response: 15 Hz - 40 kHz, -1dB
Gain: 37 dB at max Volume
Input Sensitivity: 185 mV in = 50 watts out into 5 Ohms
Input Sensitivity Triode: 66mV in = 1W into 8 Ohms
Input Sensitivity UL: 53mV in = 1W into 8 Ohms
S/N Ratio: typically 87 dB A-WGT, 20Hz-20KHz
Input Impedance: 50 kOhm nominal
Optimum Speaker Load: 5 Ohms
Actual Output Impedance at 20Hz: 2.8 Ohms at 100Hz: 2.6 Ohms at 1KHz: 2 Ohms
Damping Factor: 5
Scratch Factor: Use pennies under pointed feet to avoid marring cabinetry. Try quarters if you are in upper tax brackets. The bargain performer would be nickels. Paper currency does not function as well. Euro coins work 1.54 times better.
Power Consumption Idle: 200W
Maximum Power Consumption at Full Power: 370W
MAINS Fuses: 100~120VAC operation: MDL 3 AMP / 250 Volt SLO-BLO 220~240VAC operation: MDL 1.5 AMP / 250 Volt SLO-BLO
B+ FUSES (2): MDA 1/4 AMP, 250 Volt SLO-BLO, Ceramic. (Located internally)
Power Supply: is factory set for 100V, 120V or 220-240VAC operation for original destination country's mains voltage.
Operating Mains Voltage: changeable with power transformer re-wiring on PCB and fuse value change.
Mains Voltage Frequency:
Power Cord: Detachable IEC standard. Appropriate power cord supplied for destination country
Dimensions: W= 19", D=14", H= 5 1/2"
Shipping Weight: 30 lbs.
Site web du constructeur : http://mail.manley.com/mst.php
Un intégré Très musical ! C'est recherché et ce n'est pas pour rien
Excellent sur des Tannoy par exemple
Je rentre un peu de finances d'où la vente ..
Cadeau à ce prix ...
http://www.enjoythemusic.com/magazine/e ... ingray.htm
http://www.stereophile.com/integratedam ... 6ZdAdod.97
4 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 59 invités
ampli génialissime !
j'ai eu l'occasion de tester sur du Proac et du JMR et c'est fantastique !
bobim - Membre HCFR
Quelle version ??
Tannoy Kensington GR,News AudioFrontiers SE 845 ,Cd+DAC Eera Tentations, Cables Full O2a sublim ,Plasma Pana 50st ,HC >Zapitti pro 4K, Denon AVR 4700,Centrale KEF IQ9 ,LINN AKTIV,SVS PBP 12,JVC DLA 7900, Lumene 240c,Conditionneur Gigawatt PCEVO1.
- 0webi7db
- Inscription Forum: 01 Aoû 2001 2:00
L'ampli est réservé.
Pour la version ce n'est pas le tout dernier avec le dock et telco.
- citikab
- Inscription Forum: 20 Fév 2002 2:00
4 messages
