A vendre : 600 € => 550 €
Ampli HC Yamaha RXV-1700
Bon etat.
Date et lieu d'achat : 01/2007 - Illel
Couleur : Silver
Descriptif :
Audio
- Power Output RMS 7x130w (8Ω, 20Hz - 20kHz and 0.06% THD)
- Damping Factor ≧140 (8Ω, 20 - 20kHz SPEAKER-A)
- Input Sensitivity 200mV/47kohms (Line) 3.5mV/47kohm (Phono MM)
- Frequency Characteristics 0/-3dB (10Hz - 100kHz)
- Frequency Range 10Hz - 100kHz (0/-3dB)
- Total Harmonic Distortion 0.04% (CD line in) 0.02% (PHONO mm)
- S/N ratio (EFFECT OFF): ≧100dB (CD line in, 250mV)
- Channel Separation ≧ 60dB/ ≧ 45dB (1kHz/10kHz) CD
- YPAO Yamaha Parametric Room Acoustic Optimizer
- Dolby Digital EX & Pro Logic IIx, DTS 96/24 Bit, DTS-ES Discrete and DTS Neo:6 Processing
- 7 Channel High Power Amplifier Configuration
- Burr Brown 192kHz/24-bit DACs for all channels
- Assignable Amplifiers for bi-amp connection or Zones 2/3
- Wide Frequency Range For DVD-Audio and SACD
- DSP Surround Headphone Output (Silent Cinema DSP)
- 37 Surround DSP modes
- Virtual Cinema DSP mode
- 5.1/7.1 Channel External Decoder Input
- Zone 2 and 3 outputs with the ability to switch speakers
- Pure Direct for all inputs
- Gold Plated 4mm Banana Plug Sockets & Phono Connections
- Built in RDS FM/AM Tuner
Video
- Upconversion vidéo composite/S-Vidéo/YUV/HDMI
- Désentrelacemrnt des signaux 480i et 576i vers 480p, 576p avec TBC (Time Base Correction)
grâce à la puce « intel-oplus » MS2.
- Sortie moniteur YUV compatible HDTV
- GUI on-screen display
- Logical On-screen Display with Speaker Test Mode
Connectiques
- 2 HDMI 1.2a input allows SACD output through HDMI, 1 HDMI output
- Front AV input with optical in behind hidden panel
- Microphone based auto calibration
- RS-232 Output
- Dock for ipod
- Dimensions Width: 435mm
- Height: 171mm
- Depth: 438mm
- Weight 17,4kg
NOTE : supporte les flux LPCM via HDMI venant de platines HD-DVD et Blu-Ray sortant du PCM a partir des flux DTS-HD MA et Dolby True HD !
et possibilite de connecter les platines munies de sorties 5.1 analogiques aux entrees 5.1 analogiques du 1700.
Disponible dans le 92 a partir de fin Juillet.
Je prefere ne pas l'expedier.
Carton d'origine conserve ainsi que la documentation.
Me contacter par MP pour plus d'infos.
11 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 39 invités
Danam a écrit:l'ampli est bien en vente mais je suis actuellement aux USA en vacances (d'ou le manque d'accent - clavier qwerty ) et je ne peux pas le mettre a dispo avant fin juillet...
Danam a écrit:j'ai en effet oublie de mettre le prix de vente, desole.
peux-tu ajouter donc le prix de vente : 600euros ?
Adhérez à l'association pour que le site progresse : http://www.homecinema-fr.com/asso.php/
- frahlt
- Membre d'Honneur
- Inscription Forum: 05 Mai 2006 4:29
up, n'hesitez pas a me contacter si vous souhaitez echanger...
- Danam
- Inscription Forum: 12 Fév 2002 2:00
upupup, ne soyez pas timides proposez donc
- Danam
UP pour un vendeur sympa.
Super bête à petit prix ! foncez !!!
- djdactylo
- Inscription Forum: 10 Fév 2006 19:23
baisse à 550€
- Danam
je n'arrive pas à trouver la lettre de cession proposée sur le forum ... est-ce quelqu'un peut me filer un coup de main, je vais en avoir besoin dans qques minutes
- Danam
vendu à un forumeur sympa
- Danam
11 messages
