Type : cable coaxial
[b]Marque : Loops
[b]Modèle et options : LOOPS® A123 Series Digital Audio Coaxial Cable
[b]Prix de vente : 6 euros
[b]Département où la marchandise est visible : 75
[b]Possibilité d'expédition : oui
[b]Montant des frais d'expédition : inclus
[b]État de la marchandise : bonne
[b]Première main : oui
[b]Prix neuf : 8, 50 euros + 11 euros actuellement de frais de port car il s'agit d'une marque anglaise vendu par thatcable qui propose des cables au très bon rapport qualité/prix
[b]Date, pays et lieu d'achat : thatcable en grande-bretagne
[b]commentaires: cable coaxial bien construit et très flexible
[b]Site web du constructeur : http://www.thatcable.com/product/Loops- ... Cable-Lead
caractéristiques:
. The conducting cores are made from oxygen free pure copper conductors which further enhance signal quality. High density triple shield and gas injected dielectric insulation around the conducting cores eliminates radio frequency (RF) and Electromagnetic (EM) interference. The dielectric is totally enveloped with 100% aluminum foil and 95% copper braid. The dielectric and the copper braid are supple, yet maintain integrity even after bending and flexing.
2. The LOOPS® PureConnect™ solid brass, 24k gold plated, corrosion resistant, RCA connectors are used with this cable. Their unique design consists of an expanding split centre pin for an ultra snug fit into any RCA socket and a heavyweight outer shell with 4 cut contact points which anchor the connector in place. Both of these elements combine to produce a snug fit which further eliminates signal loss and consistantly delivers optimum signal transfer.
If your digital coax cable’s dielectric isn’t perfect, it won’t precisely match the 75 Ohm impedance of your components. This means it will be affected by jitter, which can increase noise floor* and affect the clarity. LOOPS® superior quality construction along with the digital coax’s wider bandwidth helps eliminate jitter to give you better speed and sound.
[b]Photos :
2 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 11 invités
(vendu) Cable coaxial Loops 1,5m
- vindermere
- Modérateur Installations
Vendu. On peut fermer. merci
- vindermere
2 messages
