Type : Câble HDMI 2M
Marque : Wireworld
Modèle et options : Starlight 6 silver
Prix de vente : 270 €-------> 250 €---->235€--->215€---> 205 €
----> 195€---> 185€
Département où la marchandise est visible : 74400 Chamonix
Montant des frais d'expédition : inclus dans le prix
Première main : OUI
Prix neuf : 510 €
garantie: oui normalement a vie
lieu d'achat: Futureshop en england 2012
http://www.futureshop.co.uk/wireworld-s ... aurOfntmko
ce cable marche parfaitement en 4K UHD/HDR/REC2020 meme en forcant en 4.4.4 12bit
j'ai aussi des chord active silver de 1m/2m/20m qui sont 1.3 et marche parfaitement eux aussi en 4K UHD/HDR/REC2020 et meme en forcant en 4.4.4 12bit
descriptif:
The Silver Starlight® 7 is the next best HDMI® cable available utlizing the same advanced design as the Platinum Starlight®, with 24 heavily Silver-Clad OFC conductors and aluminium connectors. The Silver Starlight® 7 benefits from the unique WireWorld proprietary DNA Helix Tri™ cable design which utilizes twenty four signal conductors instead of twelve conductors found in conventional HDMI® cables.
The new ‘Series 7’ cables incorporate a number of innovations, including a new composite insulation materials called ‘Composilex® 2’, HD-Grip™ and self-locking HDMI connectors. Many of the new cables include distinctive coins that commemorate the company’s 20-year anniversary.
All of the Series 7 cables feature Composilex 2 insulation technology, which minimizes the triboelectric noise produced by conventional insulation materials. Many understand that insulation materials influence the performance of a cable. Wireworld created unique polymer composites designed specifically to optimize fidelity. The benefits of Composilex 2 are especially noticeable on Series 7 HDMI cables where the reduced interference preserves the purity of the original sound thereby greatly improves performance. These new materials push the boundaries of there expectations for fidelity by letting us hear, see and feel more than ever before.
Wireworld’s HD-Grip HDMI connectors solve the common problem of cables becoming unplugged. Unlike some competitors, the self-locking function of HD-Grip is as simple to use as a standard cable, while the increased retention force compares favorably to other more complex
solutions. In addition to self-locking, HD-Grip plugs also feature upgraded contacts with proprietary silver+gold plating that improves audible and visible clarity. All six levels of Wireworld Series 7 HDMI cables were upgraded with HD-Grip connectors and Composilex 2 insulation to provide superior performance and value.
Wireworld’s line of HDMI® cables consist of six different levels of price and performance. All of these cables utilize Wireworld's proprietary cable designs, either a 24-Conductor DNA Helix® or 16-Conductor Symmetricon® design, with material improvements that enable each upgrade level to provide even higher levels of sound and image quality. All Wireworld HDMI cables now feature HD-Grip™ plugs for improved retention. FT4 & CL3 approved for in-wall installation.
With the unique invention of the DNA Helix design, Wireworld has created a more efficient channel for electromagnetic energy, thereby preserving more of the delicate information that creates higher fidelity. Series 7 utilizes refined versions of the DNA Helix design to provide the most lifelike fidelity ever.
All Wireworld Series 7 HDMI cables (every length) are High Speed with Ethernet; perfect for 3D & UltraHD 4K applications, and feature Composilex® 2 insulation technology.
WireWorld is leading the way in verifying the quality of all its HDMI products. WireWorld’s range of HDMI cables are subjected to a very exact quality control and testing procedures. Each and every cable goes through a full electrical test and visual inspection. Only the samples that meet there strict criteria are shipped to customers worldwide.
specifications:
Wireworld Silver Starlight 7, HDMI to HDMI Cable
HDMI 2.0 Compliant, High Speed with Ethernet
Length: 2 Metres
High Speed with Ethernet HDMI® Cable: fully supports all features of HDMI® v1.4
Data rate: 10.2Gbps to 30Gbps covering 1080p, HD4K, Deep Colour, Audio Return Channel (ARC) and all 3D formats
Conductors: 24 Conductor DNA Helix Tri, Silver-Clad Oxygen Free Copper conductors (OFC)
Wire Gauge: 23 AWG
Insulation: Composilex 2 Insulation reduces interference and greatly improves performance
Cable Design: DNA Helix Tri
Connectors: HD-Grip™ plugs with silver+gold contacts for the best HDMI connections ever
Available lengths: 0.3, 0.5m, 1m, 2m, 3m, 5m, 7m, 9m, 12m, 15m & 20m
Available terminations: HDMI-HDMI
Lifetime Warranty
ancienne serie 6 ou serie 7 de maintenant, ce sont les meme, avec les meme specifications... specifications mise a jour pour le packaging et pour les debits 4K... passage du HDMI 1.4 au 2.0...
a l'époque il etait estampillé HDMI 1.3 avec un joli sticker 1.4 collé sur l'emballage suite au passage des normes 1.3 au 1.4...
avec son data rate de 10.2Gbps to 30Gbps (pour seulement 18Gbps necessaire aujourd'hui en hdmi 2.0), le cable est deja pret pour la norme hdmi 4.0 et le 16K
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 33 invités
Petites annonces pour Câbles Vidéo (câble composite RCA, câble S-vidéo, câble Péritel, câble YUV/RGB, câble DVI, câble HDMI, câble nu, prises RCA et BNC).
UP
- totof50
- Inscription Forum: 28 Aoû 2009 15:42
UP
- totof50
UP
- totof50
baisse a 250€
- totof50
UP
- totof50
up
- totof50
je suis passé sur une oppo 203, et avec mon sony 520es ce cable marche vraiment très fort en UHD HDR et même en forcant en 4.4.4 12 bits, aucuns soucis de bande passante... j'ai besoin d'un 12m
- totof50
baisse a 235€
- totof50
baisse a 215€
- totof50
up
- totof50
baisse à 205€
- totof50
25 messages
