Type : DAC
Marque : Maverick audio
Modèle et options : D1 avec tube NOS GE5670W et OPA627
Prix de vente :140€ fdp in pour la France métropolitaine
Département où la marchandise est visible : 59
Montant des frais d'expédition : INCLUS
Prix neuf :279 USD
Date, pays et lieu d'achat : USA 26/02/2012
Numéro de série :
Documentations conservées : non /b]
Site web du constructeur : http://www.mav-audio.com/base/product/tube_magic_d1
source-dematerialisee-haute-fidelite-et-dac/le-topic-des-dac-usb-a-moins-de-300-e-muchos-cr-inside-t29927313.html
Audio inputs:
Optical audio input x 1 (Digital)
Coaxial audio input x 1 (Digital)
USB connector x 1 (Digital)
Analog audio input x 1 (Analog)
Line-in audio input x 1 (Analog)
Optical connector: TOSLINK 660nm
Coax connector: RCA, 500mVpp into 75 ohms
Analog connector: RCA, 1000k ohms
Accepted sample rates: 32khz, 44.1Khz, 48Khz, 88.2Khz, 96Khz
Accepted audio format: linear PCM, 16, 20 or 24 bits per sample
Audio outputs:
All RCA connectors are gold-plated
Volume control is provided for all outputs
Two dedicated linear power regulators for DAC and line-out stages
Dedicated linear power regulators for Tube stage
Analog RCA outputs signal-to-noise ratio: 96dB
Tube pre-out outputs signal-to-noise ration: 90dB
Analog RCA and Tube pre-out outputs impedance: 5K ohms
Total harmonic distortion: less than 0.001% (RCA outputs), less than 0.1% (Tube pre-out outputs)
Maximum output power: 1000mW x 2 (32 ohms), 500mW x 2 (300 ohms), 300mW x 2 (600 ohms)
Headphone outputs:
Standard 1/4″ jack
Minimum headphone impedance: 16 ohms
Maximum headphone impedance: 600 ohms
Headphone output power: 300mW ~ 1000mW
Power:
R-core Linear 110/220 manual switch
Physical:
Dimensions: 10″W x 2.1″H x 6.5″D (260mm x 55mm x 167mm)
Finish: brushed aluminum in black color
4 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: fouyas, Gandalf2003, Lucus, RomainM et 39 invités
Petites annonces pour Convertisseurs 2 canaux et systèmes type SqueezeBox.
DAC maverick D1 avec tube NOS et OPA627
- Yoda83
- Inscription Forum: 23 Juin 2004 20:38
4 messages
