Type : convertiseur DVI + SPDIF (Coax ou Optique) vers HDMI (Video + audio) + sorite audio en passthru.
Prix de vente : 35 Euros
Département où la marchandise est visible :75
Montant des frais d'expédition : 9 Euros
État de la marchandise : Neuf , jamais utilité cause erreur d'achat ...
Facture disponible /OUI
Date d'achat :12/08
Emballage d'origine conservé : oui neuf
Documentations conservées : oui neuf
1)Supports HDCP
2)HDMI compliant
3)Toslink Audio and Digital Audio input/output
4)Supports HDTV resolutions
5)Easy to Use: Install in seconds, no need of setting.
6)Supports resolutions up to 1080p, 2K, and 1920 x 1200
7)Encodes digital audio onto the video signal for HDMI™ video and audio
Allows you to connect computers or other sources with DVI output and SPDIF to an HDMI display
SPECIFICATIONS
Signal Inputs/Output
Input Video Signal............................1.2 volts p-p
Input DDC Signal..............................5 volts p-p (TTL)
Output Video..................................HDMI+HDCP1.0/1.1
Video format supported
VGA...........................................640x480,800x600,1024x768,1920x1200
DTV/HDTV......................................480i/576i/480p/576p/720p/1080i/1080P
Connector
HDMI Connector................................type A (19 pin) female
DVI Connector.................................DVI-I (29 pin) female (digital only)
Audio Connector..............................Toslink Audio and Digital Audio
Operating Frequency
Frequency....................................Up to165Mhz
Resolutions(HDTV)
Interlaced(50&60Hz).........................480i,576i,1080i
Progressive(50&60Hz).........................480p,576p,720p,1080p
Mechanical
Size(W-H-D)...................................5"W x 1"H x 4"D
Weight for shipping..............................2 lbs
Warranty
Limited Warranty..............................1 Year Parts and Labor
Environmental
Operating Temperature.........................0 ¡æ to +70¡æ
Operating Humidity.........................10% to 85 % RH (no condensation)
Storage Temperature.........................-10¡æ to +80¡æ
Storage Humidity...........................5% to 90 % RH (no condensation)
Power Requirement
External Power Supply........................5V DC@2A
Power Consumption.........................5 watts (max)
Regulatory Approvals
Converter Unit..............................FCC,CE,UL
Power Supply..............................UL,CE,FCC
Accessories Adapter
AC Power Adapter..............................FR standard
User Manual...................................English Version
1 message • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: LeFaucon, Naim82, ricouxxx et 56 invités
Petites annonces pour Convertisseurs 2 canaux et systèmes type SqueezeBox.
[VENDS][75]Boîtier convertisseur DVI+ SPDIF vers HDMI NEUF!
- Fichiers joints
- 157132184_tp.jpg (11.29 Kio) Vu 1200 fois
- 157132188_tp.jpg (9.97 Kio) Vu 1200 fois
- Eldap
- Inscription Forum: 19 Déc 2002 15:57
1 message
