Type : Kit d'enceintes 5.1
Marque : Morel
Modèle et options : Applause MK2
Prix de vente : 900€ --> 750€
Département où la marchandise est visible : 69
Possibilité d'expédition : à voir
Prix neuf : 1800€
Facture disponible : oui
Date, pays et lieu d'achat : acheté chez ELECSON le 05/05/2007
Emballage d'origine conservé : oui (caisson) & non (enceintes)
Description générale : le kit d'enceintes se compose de 3 enceintes SoundSpot SA-2 pour la scène frontale, de 2 enceintes SoundSpot SI-2 pour les surrounds et d'un caisson SoundSub 9.
Tous les éléments sont de couleur grise (silver).
Il est très facile de fixer les enceintes au mur.
Extraits de la brochure Morel (disponible au format PDF sur demande) :
"APPLAUSE MKII. THE SYSTEM THAT GETS A STANDING OVATION FOR ITS SOUND & ELEGANCE.
The Applause mkII home theater speaker system is based on Morel’s SoundSpot SA-2 speakers, winner of CEA’s “Innovation Award” at the 2000 WCES.
The SA-2’s high-clarity open sound and excellent dynamic capabilities render it very suitable for reproducing movie soundtracks as well as high-quality music reproduction.
Complementing the SA-2 is the SoundSub 9, a 9” active reflex loaded subwoofer, that supplies the great bass sound for the Applause mkII system. Our flagship system, the Applause mkII, is a non-compromise system designed for the audiophile home theater and music enthusiast."
SOUNDSPOT SA-2
The SoundSpot SA-2 is redefining industry standards, offering breathtaking audiophile performance from a discreet and attractive speaker.
The SA-2, winner of CEA’S Innovations 2000 award, combines a 4” (100mm) mid/bass unit with a soft-dome tweeter, each one housed in its own steel sphere. The units are carefully aligned for phase and time coherence, for precise imaging, and for delivering integrated, lifelike sound. The units are based on Morel’s External Voice Coil (EVC) design, in which an aluminum Hexatech coil surrounds an extremely powerful magnet motor to achieve high efficiency and distortion free sound. The mid/bass unit’s motor is rear vented, allowing strong air circulation that cools the voice coil which enables high power handling. Its damped polymer composite cone is constructed (surround and center cap) of one single piece for linearity and precision. The tweeter is characterized by an extended frequency range, all the way down to the midrange band, attaining outstanding tonal quality. The crossover is made of first-class components, hardwired for high integrity.
SOUNDSPOT SI-2
The SoundSpot SI-2’s sphere shaped steel enclosure houses Morel’s award-winning Integra drive unit that coaxially integrates a tweeter and 4” (100 mm) mid/bass unit, creating point source sound radiation. The unique coupling of the tweeter and mid/bass units in the Integra construction allows perfect integration and phase linearity, ensuring a particularly smooth, linear frequency response.The SoundSpot SI-2 is built exclusively with neodymium magnets, which are up to 20 times more powerful than conventional magnet systems. Applying Morel’s EVC design, a huge 2 “ (54mm) aluminum Hexatech coil encloses the magnet motor inside. In a conventional drive unit with a coil of this diameter, the
size of the magnetic system alone would be at least five times larger than that of the Integra! The EVC design is also used for the soft-dome tweeter, where the voice coil is liquid cooled for high power handling. The crossover is hardwired on a separate board and the components secured with strong polyurethane glue, for high integrity.
SOUNDSUB 9
The SoundSub IS-9A was designed to supplement the SoundSpot satellite speakers in the low bass frequency range, creating an acoustically homogeneous home cinema or hi-fi system. The SoundSub IS-9A employs two 9” (222mm) woofers in an extremely flat-profile enclosure. The woofer’s rear-vented double magnet system and aluminum Hexatech coil allow for effortless deep bass power. The IS-9A uses the tandem dynamo acoustics design, which allows perfect acoustical loading of the enclosure and provides strong air circulation for high power-handling capabilities. The SoundSub IS-9A is an active subwoofer driven by a high-quality 120W amplifier, positioned at the rear of the enclosure. The amplifier features an automatic on/off switch, volume control, phase control, and crossover point control that allow seamless system integration. The IS-9A has high- and low-level inputs/outputs that allow for any of the common configuration options. The SoundSub IS-9A will enhance any home theater system with a well-controlled, deep bass.
Arrière caisson :
Site web du constructeur : http://www.morelhifi.com
Commentaires : je vends ce kit d'enceintes car je monte en gamme (achat enceintes Bowers & Wilkins CM S2)
Morel Applause :
son-audio-enceintes-homecinema/morel-applause-recu-5-sur-5-t29801636.html
son-audio-enceintes-homecinema/morel-vs-b-w-t29805813.html
son-audio-enceintes-homecinema/morel-applause-et-ecoute-en-hifi-t29859149.html
Morel Nova (gamme inférieure aux Applause) :
son-audio-enceintes-homecinema/club-des-heureux-possesseurs-de-morel-nova-t29897290.html
son-audio-enceintes-homecinema/avis-morel-nova-t29772595.html
son-audio-enceintes-homecinema/morel-nova-mk-2-t29853234.html
son-audio-enceintes-homecinema/alternative-waf-aux-morel-nova-pour-harman-kardon-avr-330-t29851890.html
son-audio-general-homecinema/config-hc-petites-enceintes-type-morel-nova-cabasse-xo2-t29801293.html
Morel Vitra (gamme inférieure aux Applause) :
son-audio-enceintes-homecinema/avis-morel-vitra-t29853135.html
son-audio-enceintes-homecinema/enceintes-compactes-morel-vos-impressions-t29866109.html
Extraits de la brochure Morel :
Le kit en vente :
Autres photos sur demande.
6 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 26 invités
Kit enceintes 5.1 Morel Applause MK2
Magnetar UDP800 - Marantz SR7011 - Kora Explorer 150 CSC - Audiophonics LPA-S500NC - B&W CM6 S2 + CMC 2 S2 + Monitor Audio Silver FX - BK XLS200-DF - TV LG G3 65" - VP Epson EH-TW9400 - Ampli casque Doge 6210 MK2 - Casque Sennheiser HD650
- PierreA
- Inscription Forum: 06 Nov 2005 0:52
up
- PierreA
up
- PierreA
Bonne vente, ce kit m'aura fait rêver et j'avais fini par prendre son petit frère le Nova !
- Meep
- Inscription Forum: 13 Oct 2005 14:17
Meep a écrit:Bonne vente, ce kit m'aura fait rêver et j'avais fini par prendre son petit frère le Nova !
Merci Meep
- PierreA
up
- PierreA
6 messages
