Type meuble support tv lcd pour tv max 50 pouces
Marque : erard
Modèle et options : Pratik
Prix de vente : 100€
Département où la marchandise est visible : 76
Prix neuf :260 euros
Facture disponible : quelque part
Numéro de série : non
Emballage d'origine conservé : Sans
Documentations conservées : oui, visserie .....
• 4 models:
- Manual swivel: Ref. 2526 – Ref. 2579
- Manual swivel and Light Motion®: Ref. 2527
- Motorized swivel TWIST®: Ref. 2528
- Motorized swivel TWIST® and Light Motion® : Ref. 2529
• Manual (Ref. 2526 – Ref. 2527 – Ref. 2579) or motorized TWIST® (Ref. 2528 – Ref. 2529) swiveling of the screen to watch television from wherever you are in the room.
• LIGHT MOTION® ambient lighting (Ref. 2527 – Ref. 2529)
• Secure attachment
• Fits into the corner of your room
• Cable management system
• Room for 3 components
• Manual vertical adjustment: +/- 2°
• 3 positions to adjust the screen height
• Programmable adjustment of the left and right swiveling end-pieces and programming of a preferred position with key recall
• PILOT MOTION® infrared remote control (Ref. 2528 – Ref. 2529)
• LIGHT MOTION ® system: LIGHT MOTION ® system : ambient lighting system operated by remote control, 2 LED strips (Ref. 2527
-Ref.2529). Automatic colour variation function. Adjustment of the colors, intensities and variation speeds. Variation of the colors
depending on the sound intensity. Memorization of 4 lighting preferences
• Component holding shelf in black gloss glass: 6 mm thick, heightadjustable without tools, with anti removal system
• 2 elastomer rear pads and 4 sliding pads
• Horizontal center-to-center distance: min. = 5 cm, max. = 81 cm
• Vertical center-to-center distance: min. = 5 cm, max. = 54.5 cm
• Vertical reversible black and Wenge wood rear panel
• Rear ambient panel in medium, white silk finish: 9 mm thick (Ref. 2527 - Ref. 2529)
• Steel column painted in black powder-coated epoxy paint
• Base in medium black: 18 mm thick
• Max upper shelf weight: 15 kg
• Max lower shelf weight: 40 kg
4 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 22 invités
Petites annonces pour Mobilier Hifi et HC type meuble ou rack, Pieds d’enceintes, Etagères cd/dvd, etc.
toujours disponible pratique pour un LCD
- simon
- Inscription Forum: 28 Mai 2008 18:55
4 messages
