Type : Préamplificateur
Marque : EMOTIVA
Modèle et options : UMC-1 Black 220 Volt
Prix de vente : 450€ -> 400€
Département où la marchandise est visible : 06
Montant des frais d'expédition : Compris
Première main : Non
Prix neuf : 600€ avec douane et frais de port à l'époque
Facture disponible : Oui
Date, pays et lieu d'achat : 2010 Emotiva USA
Numéro de série : MP
Pre-amplificateur dans un état impeccable, fourni avec Micro de calibration, télécommande, boite et manuel d'origine
Manuel:
http://emotiva.com/resources/manuals/umc1_manual.pdf
* Twin Cirrus® 32 bit dual core DSP’s
* Decoding support for Dolby Digital, Dolby Digital EX, Dolby Digital Plus, Dolby Digital True HD, Dolby PLIIx, DTS, DTSES, DTS HD, DTS Master Audio, DTS Neo 6, SPDIF, PCM 8 channel (note: some audio formats are only supported via HDMI)
* Multi-channel Dolby Volume
* Genesis/ST® Torino high performance scaling engine - featuring a full implementation of the Faroudja DCDi™ image processing suite
* Intuitive, full color graphical OSD with adjustable transparency presented over live video, including HDMI
* Emo-Q™ automatic multi-channel room correction and loudspeaker setup. Calibrated measurement microphone included.
* Quadruple bass manager with independently selectable high and low pass frequencies from 40hz – 250hz, in 5 or 10Hz increments (depending on frequency)
* Selectable 12db or 24db per octave high pass and low pass filters by channel groupings
* Independent 11-band graphic EQ with global bass and treble controls by channel groupings
* Balanced subwoofer output
* All legacy video inputs can be scaled and output over HDMI at up to 1080p
* 1080p/24 fps video support
* Video pass-through mode with 12 bit compatibility
* HDMI sources can be format converted to component video up to 1080i (subject to Macrovision™ guidelines)
* HDMI 1.3a Deep Color compliant
* All inputs are assignable and feature input labeling, selectable decode modes, selectable triggers, etc.
* 0.5dB level trims on all channels
* High voltage, low impedance main analog outputs for uncompromised dynamic headroom
* 5 - HDMI inputs and 1 HDMI output.
* 3- composite video inputs (RCA)
* 3 - S-video inputs (S-video mini DIN)
* 3 - component video inputs (RCA)
* 1 - component video output (RCA)
* 4 - stereo analog audio inputs (RCA)
* 1 - 7.1 analog input set (RCA)
* 1 - 7.1 analog output set (RCA)
* 4 - coaxial digital inputs, (RCA)
* 3 - optical digital inputs (Toslink)
* 1- coax digital audio output (RCA)
* 1- optical digital audio output (Toslink)
* 1 - Stereo or 2 channel analog multi channel mix down output for fixed level monitoring (RCA)
* 1- stereo analog variable and independent Zone 2 output (RCA)
* 1 - stereo analog fixed level record output (RCA)
* High performance AM/FM tuner with 24 FM and 6 AM presets
* 3 - assignable trigger outputs Movie/Music/Amp (3.5mm mini)
* 1- IR input (3.5mm mini)
* 1 - IR output (3.5mm mini)
* 1. Microphone input (3.5mm stereo mini)
* 1- USB data input (for software upgrades only)
* Size: 17” W x 3 7/8” H x 13” D
Site web du constructeur :
https://www.google.fr/url?sa=t&rct=j&q= ... 0653,d.ZWU
7 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: domin, zanzibar76 et 40 invités
Petites annonces pour Préamplificateurs HC multi-canaux.
up up
- Fabio
- Inscription Forum: 02 Jan 2001 2:00
bonjour, par honneté et transparence pour pour ceux qui ne connaissent pas le prix du marché ou simplement la marque Emotiva, il serait bien de ne pas gonfler artificiellement le prix neuf.
J'ai acheté un UMC1 en direct USA à la meme période, je ne vois pas comment il a pu te revenir à plus de 700-800€ GRAND max.
Ce qui n'empeche pas ton prix de vente d'être très correcte
- bible100
- Inscription Forum: 24 Fév 2003 14:27
Édit
Bonne vente
Bonne vente
Ma Config
B&W Accuphase
- gil2b
Oui vous avez raison j'ai pris bêtement le prix de la facture avec l'ampli.
Je corrige... Dsl
Envoyé depuis mon GT-N7100 en utilisant Tapatalk 4 Beta
Je corrige... Dsl
- Fabio
Du coup ca baisse
- Fabio
Vendu merci
- Fabio
7 messages
Retourner vers Préamplificateur HC
