Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: alexgui1960, Greghifi, OhMummy, spoke et 85 invités
"NEW" LAB GRUPPEN IPD
donc par software uniquement. Rien en façade.
Bluesound Node / SMSL M500 /McIntosh MA 5200 / Davis Monitor 1 /Mogami 3103HP.
autrichon gris - Modérateur Œuvres & Multimédia
- Inscription Forum: 21 Oct 2009 14:18
Je n'ai rien trouvé sur les caractéristiques du DAC embarqué... Labgruppen est taisant la dessus sur son site. Quelqu'un sait ?
Il donne ces détails dans les specs :
Connectors, Network, and User Interfaces
The rear panel shall provide audio inputs for analog (2) and AES digital (1) with input signals on XLR-F connectors.
Link outputs for all three inputs shall be on adjacent XLR-M connectors.
One RJ45 Ethernet jack shall be provided for networked monitoring and control via remote computer (PC or Mac).
The unit shall be compatible with use as part of a low-latency, self-configuring digital audio network that supports sampling frequencies from 44.1 to 96 kHz.
Output connectors on the unit shall be both binding post and Neutrik® speakON® (2 x NL4).
The front panel user interface shall include a high-brightness LCD panel, a rotary encoder, two mute buttons, menu button, and back button. The user interface shall be menu-driven, with all functions of the digital loudspeaker processor and the power amplifier accessible via screen displays configurable with the menu/back buttons and rotary encoder.
Multicolor LEDs shall indicate presence of any warning or fault conditions.
The unit shall be supplied with a custom software program for comprehensive monitoring of system status and operating parameters, as well as control of DSP and amplifier functions.
The software program shall be compatible with use on a Tablet PC or Mac.
Stéphane
Stéphane
- stephane092
- Inscription Forum: 31 Mai 2012 7:36
Ben oui (24/96 ça c'est vu), mais non. Quels convertisseurs ? De quelle marque ? Configuré comment avec quelle électronique ?
En gros, c'est, est ce que le DAC intégré va faire un boulot sérieux avec l'entrée digitale , ou est ce que je vais me contenter de l'analogique.
Curieux, je n'ai pas de réponse de Labgruppen, ni de thomann d'ailleurs, pourtant toujours réactif, sur cette question de la technologie de conversion utilisée dans cet ampli, et je ne trouve rien nulle part sur le net. Secret de fabrication ? Pas forcément bon signe
Je me disais aussi, Thomann a finit par me répondre, et en plus ils l'ont testé: pas très encourageant !
Cet ampli est nettement moins bon en ce qui concerne la reproduction que le reste de la gamme disent ils, mais effectivement les DSP embarqués sont efficaces et sympa. Ils ralent aussi contre l'absence totale d'informations techniques du fabricant notamment concernant le DAC. Bon, bon, je crois que ça va me calmer tout ça.
Bonjour, j'en ai livré un à un client, ravi du son et de la stabilité du soft. Je me méfierais des impressions d'écoute de Thomann, c'est vrai que la marge sur cette gamme est plus proche de l'industrie informatique qu'habituellement... Ne sonne pas mieux mais pas plus mal que n'importe quel amplificateur en classe D du marché.
Si ça n'a pas été mentionné, le soft de gestion est téléchargeable et permet de s'amuser, le temps de découvrir si le produit peut correspondre aux besoins que l'on aura "in situ".
- KW55
- Inscription Forum: 13 Juin 2009 21:04
Perso je ne mets pas tous les amplis classe D dans le même sac...
Tu as des infos sur la partie DAC ?
Les amplis sérieux en classe D ont de gros point communs. Pas d'infos particulières sur le Dac.
- KW55
autrichon gris a écrit:Ben oui (24/96 ça c'est vu), mais non. Quels convertisseurs ? De quelle marque ? Configuré comment avec quelle électronique ?
à mon avis ça ne changera pas grand chose ... 99% de chance que l'analogique en entrée soit directement numérisé, vu que tout est contrôlé par un DSP
- j_yves
Au passage j'ai fini par avoir le revendeur France de LabGruppen (un commercial) qui déplorait lui même n'avoir aucune documentation sur le sujet de la conversion, et que c'était volontaire de la part de LAbGruppen.
PAs terrible à l'heure d'internet de la part de cette marque, qui prend un peu les clients, pourtant très avertis de ce type de matériel, pour des benêts.
Personne n'a pu l'ecouter ? (pour le comparer à leur précédente version, voir à un Yam de la série PCxN par exemple )
- fred-ql
- Inscription Forum: 12 Juin 2001 2:00
Ca se bouscule pas...
....On a quelques nouvelles ?
alfachris - Membre HCFR
- Inscription Forum: 12 Aoû 2003 21:36
Je l'avais bien dit qu'il était trop beau pour être bon cet engin .
- SUNSET
- Inscription Forum: 22 Mai 2009 10:45
