J'ai acheté un Nad 3020 series 20 pour 10 euros dans un vide-grenier. Premières écoutes il fonctionne très bien, mais comme j'ai une piste sur un tweak qui à été approuvé je voudrais l'appliquer, pouvez-vous m'éclairer sur celui-ci.
Pourquoi mettre des elctrolytiques non polarisées à la place des polarisés sur la partie préamp et amp et pas des bons chimiques ?
Le tweak en question :
Les photos : http://www.fidele.co.uk/DECgallery2.htm
NAD 3020 Service Upgrade Details.
The main power supply capacitors (originally 4 x 2200uF) are replaced with 2 6800uF capacitors. These supply the output stages of the power amplifier and the increase in capacitance provides more definition and presence to the bass sound. All electrolytic capacitors in the regulated supply are replaced with double the capacitance, this provides a less noisy supply thus reducing overall noise and distortion and contributing to a tighter clearer sound.
All electrolytic capacitors in the pre and power amplifier circuits are replaced with non-polarised electrolytic capacitors. This has a significant effect on overall distortion levels especially where the capacitors have bi-polar signals applied. This contributes to a clearer cleaner sound especially in the mid to higher frequencies.
The output transistors are replaced with modern transistors which have much better sonic properties than the originals, and also provide more power handling capabilities. A small modification is made to the bias circuit to allow exact setting of bias currents.
Finally the offset voltage and bias currents are set as accurately as possible, to provide the final polish to the amplifiers sound.
The effect of all the work is to significantly improve the bass response and improve the overall clarity of the sound, by reducing noise and distortion throughout the amplifier.
merci d'avance.
3 messages • Page 1 sur 1
Modérateurs: Modération Forum DIY, Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Bobo le Chat et 66 invités
Tweak make in London du Nad 3020
- bandit-xx
- Inscription Forum: 10 Avr 2005 20:23
en faite c'est un ampli assez special , tout est construit autour des 2n3055
comme la fréquence de coupure , vonlontairement basse de l'ordre de 70khz
je pense qu'ils ont voulut faire un ampli ou le registre 4 a 8 khz serait plus en avant
avec une tonal moilleuse
d'ailleur le choix de 2 condos de 2200 uf en // va dans ce sens !
- catsiano
- Inscription Forum: 21 Juil 2006 20:25
Oui un peu trop moelleux d'origine.
Bon je vais commencer par mettre 2 x 6800uF et changer tous les autres condos de la partie alim par d'autres du double de leur valeur en attendant de trouver quoi mettre sur la partie preamp et ampli.
- bandit-xx
3 messages
