Modérateurs: Staff Home-Cinéma, Staff Juridique • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 20 invités
Un plasma 42" de 1280x1024
Message » 19 Mai 2005 11:24
Il semblerait que la résolution du nouveau plasma 42" LG, le 42PM12X, soit de 1280x1024. C'est la première fois que je vois une telle réso sur un 42" de série. Cela augure-t-il d'une augmentation de la réso des plasmas pour l'été/automne? 8)
mike_e
Message » 19 Mai 2005 13:15
je crois que tu es en erreur
product detailed description
LG is committed to ensuring that our Plasma Displays are of maximum quality, adhering to strict quality assurance guidelines. We’re proud also to offer the industry’s widest range of screen sizes, to cater for all your display applications.
1024 x 768p Resolution
5000:1 Contrast Ratio
1500 cd/m2 High Brightness
Image Sticking Minimization, Pixel Orbitor, and White Wash Features
Aspect Ratio Correction
RS-232 Control and Discrete IR Controls
Fan-Free Operation
Faroudja DCDi
Split Zoom Matrix
2 Year Warranty
DIMENSIONS
Cabinet (W x H x D) 41.57" x 25.00" x 3.23"
Weight 75 Lbs.
CABINET DESCRIPTION
Finish Silver
Cabinet Style Slim Frame
Power Consumption 250W
Power Source 115v 60Hz
VIDEO ENHANCEMENTS
Screen Size 42" Wide Format
Resolution Display 1024 x 768p
Pixel Pitch 0.36 (H) x 1.08 (V)
Aspect Ratio 16:9, 4:3 Zoom
Brightness 1000 cd/m2 w/Filter
Contrast Ratio 1200:1
Viewing Angle 160°
Format Conversion Intelligent Image Scanning
Aspect Ratio Correction Yes
Scan Converter O-Plus
Contrast Yes
Brightness/Sharpness Yes
Tint Yes
Video De-Interlacing/Line Doubling Faroudja DCDi
DISPLAY
Display Frequency 15.73 to 120Hz (H),
50 to 120Hz (V)
Displayable Colors 16.77M
Color Gradation Filter Yes
Input Signal NTSC, HD, SD, VGA, SVGA,
AUDIO ENHANCEMENTS
Mono/Stereo/MTS/SAP Stereo
Bass/Treble/Balance Yes
Total Audio (Watts) Output 20W (2 x 10W)
SPECIAL FEATURES
Acoustic Noise Reduction Yes
Picture In Picture (PIP) Yes, Split Screen, Zoom
Trilingual Menus English/Spanish/French
1 Level Mute Yes,
Shock Absorbing Glass Damper Yes, Tilt to 20°
RS-232 Control Yes
Discrete IR Controls Yes
Detachable AV Terminal Yes
White Balance Adjustment Yes
Display Mode Change (Vertical) Yes
Fan Free, Noise Free Yes (Landscape Only)
Auto-Power On Yes
Discrete Power Off Yes
Last Source On Yes
Image Sticking Minimization Yes
Pixel Orbitor Yes
White Wash Yes
Inversion Yes
Aspect Ratio Control Yes
Split Zoom (Matrix) Yes
Clock Yes
Timer Yes
Auto Off Yes
Key Lock Yes
OUTPUT RESOLUTIONS
NTSC, VGA, SVGA, XGA, SXGA 1024 x 768p
HDTV 1024 x 768p
JACK PACK
Hi-Res Component Video 1
Audio Left/Right In 3
Composite In 1
RGB In (15-Pin Type-D Connector)/Out 1/1
S-Video In 1
RS-232C (9-Pin Connector) 1
DVI with HDCP 1
IR Jack 1
Audio L/R Out 1
OPERATING ENVIRONMENTS
Storage Temperature Range -20°C–60°C
Storage Humidity Range <85%
Altitude 2,000m (6561 Feet)
Operating Temperature 0°C–40°C &<80% Humidity
REQUIRED APPROVALS
UL, C-UL, NOM UL, C-UL, FCC (B)
SERVICE/LIMITED WARRANTY
Warranty: Parts/Labor 2 Year/2 Year
MTBF (Approx.) 60K Hours
ACESSORIES (OPTIONAL)
AP-42DA12 Desktop Stand (WxHxD) 31.1" x 12.1" x 11.1"
Weight 15.7 Lbs.
AP-42SA12 Speaker (WxHxD) each 3.8" x 25.0" x 3.2"
Weight 5.5 Lbs. x 2
AP-42SA12D Speaker Stand (WxHxD) 8.7" x 7.1" x 8.7"
Weight 2.8 Lbs.
Wall Mount PWMT200
kroliv
Message » 19 Mai 2005 14:32
Ecoute, voilà l'extrait de la fiche produit France:
Taille écran / image 107 cm (42 pouces)
Format 16:9
Résolution WXGA (1280x1024)
Luminosité 1000 cd/m²
Contraste 3000:1
Angle de vue 160° mini
Couleurs 16,7 millions
XD-ENGINE Oui
DCDi* Oui
DCF* Oui
Contrôle du format Spectacle/Full Screen/Original/Normal/Wide/14:9/Zoom
Contrôle de l'image Contraste/Luminosité/Couleur/Netteté
Contrôle de la température d Normal/Chaud/Froid/Utilisateur
PIP* / Double écran Oui (Taille réglable)
Split zoom, Mur d'image 2/4/9 écrans
Timer/Sleep, DPMS Oui
Vérouillage des touches Oui
Systèmes anti-marquage ISM,Orbiter, White Wash, Inversion
Entrée PC numérique DVI
Sub-D 15
Sub-D 15
Entrée PC audio Jack
RS232* x 1
Péritel (RVB/S) x2
Composante (YUV) x1
S-vidéo (Y/C) x1
Entrées audio RCA x2
Support mural optionnel AP-42WA50M
Support plafond optionnel AP-42CA50M
Pied de table optionnel APDM10
Paire de HP optionnelle AP425M10
Alimentation 100-240 V, 50/60 Hz
Consommation marche / vei 370 W/ 3 W
Dimensions sans pied (LxHx 1066 x 650 x 97,5 mm
Poids net (sans pied) 30 Kg
Entrée PC RGB
Sortie PC "Loop" RGB
Quelle est la bonne? :o
mike_e
Retourner vers Ecrans HD
