Plutôt que revisiter leurs enceintes d'antan, avec des composants et des filtres différents (les fréquences de coupure sont très différentes de celles du modèle d'origine) et aussi avec un prix qui pique sérieusement, je préfèrerais que le groupe Harman sorte de nouvelles Revel.
En attendant, il reste les monitors pros de JBL, heureusement.
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: eyelike, JO95 et 289 invités
NEWS & BUZZ
- tovarich007
- Contributeur HCFR 2019
- Inscription Forum: 05 Jan 2010 21:51
tovarich007 a écrit:En attendant, il reste les monitors pros de JBL, heureusement.
Celles-ci sont intemporelles; c'est l'avantage !
- FDDRT
- Inscription Forum: 25 Avr 2018 13:33
Subwoofer YG Acoustics Invincible
YG Acoustics a écrit:InVincible™ is the world’s first hyper-high-end sub-bass speaker. It was created to solve a specific problem: owners of the world’s finest flagship speakers often felt that adding a subwoofer to their system caused more drawbacks than improvements. YG Acoustics™ addressed the issue by creating a truly extreme solution, a no-holds-barred assault on everything deemed possible in the sub-bass realm. InVincible – pure authority, handmade in U.S.A.
Innovations include, first and foremost, the largest BilletCore™ driver ever made at 53 cm diameter (21”). The cone is machined from a massive 30 kg (66 lb) slab of aircraft-grade aluminum. When finished it weighs 411 grams (14.5 oz). The basket is also CNC-machined in-house, then precisely assembled from 238 parts using lab-grade alignment and tolerances.
The dedicated built-in amplifier boasts up to 6,000 watts of RMS power for unrestricted dynamics. In a world filled with offshore-outsourced electronics, this amplifier stands out by incorporating a real high-end, custom, U.S.-made class D module.
The unique layout sports dual, opposing-yet-tilted drivers. It combines the freedom from vibration of a push-push setup, with the ease of room-integration typically associated with front-firing subwoofers. The “flipped” arrangement, with enclosures on both ends rather than in-between the woofers, minimizes their spacing thus further easing room-placement.
The cabinet is precisely CNC-machined from solid aluminum billet. Like YG Acoustics™’ flagship Sonja™ XV and Sonja™ 2 series, its construction is a “box within a box”, to minimize vibration. A sealed alignment eliminates port-issues and the time-delays associated therewith. FocusedElimination™ is used to minimize loss.
The built-in DSP crossover offers extensive options for matching with most high-end speakers. Furthermore, when mating InVincible™ with a YG Acoustics™ speaker, the guesswork is entirely eliminated. InVincible™ is pre-programmed for precise matching with any current YG Acoustics™ speaker and many legacy models, using a foolproof process inspired by the famous DualCoherent™ technology.
Key Technology
BilletCore™
DualCOherent™ inspired DSP
Cabinet Technology with proprietary driver-layout
Focused Elimination
Bandwidth
Truly full output (-0 dB), even anechoically, to below 20 Hz
Usable output extends below 15 Hz
Drivers
BilletCore™ ultra-high-rigidity subwoofer(s) with a diameter of 53 cm (21”)
InVincible™ 21.1 – single driver
InVincible™ 21.2 – dual drivers
Amplifier
Up to 6,000 watts RMS (requires a 230 Volt AC hookup, otherwise 3,000 watts)
DSP
Proprietary DualCoherent™-inspired crossover with user-controllable frequency
Designed using software developed in-house
Pre-programmed for precise matching with YG Acoustics™ speakers
Extensive options for matching with third-party speakers
Dimensions
75x68x68 to 177x68x68 cm depending on configuration
Weight
111 to 210 kg unpackaged, depending on configuration
roland_de_lassus - Modérateur Haute-Fidélité
Font pas dans la demi mesure...à un prix YG, probablement exorbitant...
ilsagno,
ilsagno,
- ilsagno
- Inscription Forum: 30 Nov 2010 18:30
Canton se met aux enceintes amplifiées wireless avec sa Vento Smart 9...4400€ la paire en Germanie...
ilsagno
ilsagno
- ilsagno
ilsagno a écrit:Canton se met aux enceintes amplifiées wireless avec sa Vento Smart 9...4400€ la paire en Germanie...
ilsagno
Pas mal sur le papier
Leedh E2 - Chord SPM 1050 mk2 - Minidsp SHD
- kkouete44
- Inscription Forum: 18 Oct 2004 13:52
elles arrivent... https://www.monoandstereo.com/2018/12/m ... aldac.html
- BL89
- Inscription Forum: 17 Juil 2013 1:12
Longtemps qu'elles sont arrivées, vu que je les ai écoutées lors d'un salon il y a 2 semaines...
trop la classe... et ?
PS : elles arrivent... à demeure pour des écoutes permanentes dans un environnement dédié.
- BL89
roland_de_lassus a écrit:Longtemps qu'elles sont arrivées, vu que je les ai écoutées lors d'un salon il y a 2 semaines...
Et aussi chez Présence Audio Conseil à Paris en novembre 2017 avec Alon Wolf en avant-première européenne...
- sound
- Pro-Commercant.
- Inscription Forum: 02 Avr 2007 22:54
Et celles qui sortent demain, quand et où pourrons nous les découvrir ? svp
Hi-fi : nas Qnap TS221, Transporter, Minidsp SHD, Soncoz SGD1, BoXem 4215/E2, Vivid Audio B1, Rel G2
JG Naum - Modérateur Œuvres & Multimédia
- Inscription Forum: 12 Mar 2005 20:08
