Ping en boucle sur mon iMac:
PING 127.0.0.1 (127.0.0.1): 56 data bytes
64 bytes from 127.0.0.1: icmp_seq=0 ttl=64 time=0.075 ms
64 bytes from 127.0.0.1: icmp_seq=1 ttl=64 time=0.068 ms
64 bytes from 127.0.0.1: icmp_seq=2 ttl=64 time=0.069 ms
64 bytes from 127.0.0.1: icmp_seq=3 ttl=64 time=0.059 ms
64 bytes from 127.0.0.1: icmp_seq=4 ttl=64 time=0.070 ms
64 bytes from 127.0.0.1: icmp_seq=5 ttl=64 time=0.071 ms
64 bytes from 127.0.0.1: icmp_seq=6 ttl=64 time=0.069 ms
64 bytes from 127.0.0.1: icmp_seq=7 ttl=64 time=0.069 ms
--- 127.0.0.1 ping statistics ---
8 packets transmitted, 8 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.059/0.069/0.075/0.004 ms
Ping iMac avec IP PCHC:
IMAC-DE-****:~ ********$ ping 169.254.32.103
PING 169.254.32.103 (169.254.32.103): 56 data bytes
64 bytes from 169.254.32.103: icmp_seq=0 ttl=128 time=0.495 ms
64 bytes from 169.254.32.103: icmp_seq=1 ttl=128 time=0.331 ms
64 bytes from 169.254.32.103: icmp_seq=2 ttl=128 time=0.402 ms
64 bytes from 169.254.32.103: icmp_seq=3 ttl=128 time=0.434 ms
64 bytes from 169.254.32.103: icmp_seq=4 ttl=128 time=0.368 ms
64 bytes from 169.254.32.103: icmp_seq=5 ttl=128 time=0.327 ms
64 bytes from 169.254.32.103: icmp_seq=6 ttl=128 time=0.232 ms
64 bytes from 169.254.32.103: icmp_seq=7 ttl=128 time=0.378 ms
64 bytes from 169.254.32.103: icmp_seq=8 ttl=128 time=0.356 ms
64 bytes from 169.254.32.103: icmp_seq=9 ttl=128 time=0.326 ms
64 bytes from 169.254.32.103: icmp_seq=10 ttl=128 time=0.329 ms
64 bytes from 169.254.32.103: icmp_seq=11 ttl=128 time=0.406 ms
Ping PCHC en boucle:
Ping PCHC avec IP Imac:
IP config /all sur le PCHC:
Différents Ping énumérés sur ton lien:
Ps; s'il y a des infos à ne pas mettre en ligne, merci de me prévenir
