Pour discuter des jeux video ( Sony, Microsoft, Nintendo, ... ), et des services en ligne ( Steam, Origin, Uplay, ... ).
Alien : Isolation [PS3-PS4-X360-X1-PC]
» 07 Oct 2014 14:51
Sympa les extras sur PS4 :
In fact the use of technology is excellent in general, with the PlayStation 4 version using the DualShock 4 speaker to squawk a warning if your motion tracker picks up a new signal. And if you have a PlayStation Camera you can lean your head via motion controls, but you have to keep physically quiet or the microphone will pick up any noise you make.
Encore un nouveau constat sur l'optimisation du rendu graphique de Alien Isolation sur PS4, beaucoup plus stable par rapport à la version XboxOne :
Here, the same level of graphical quality extends to both PS4 and Xbox One versions of Alien: Isolation. Native resolution comes in at 1080p using what appears to be a post-process anti-aliasing solution, while the artwork and effects appear a close match, right down to the dithered shadow edges and how reflections and specular highlights are displayed. The main points of difference in our shots come down to the dynamic lighting which changes the way environments and characters are illuminated in real-time, along with slight variances in depth of field and motion blur at any given moment.
In essence, we have a locked parity between the two consoles in terms of image quality, but when it comes down to performance, it's clear that Sony console offers up a smoother and more consistent gameplay experience. The PS4 delivers a v-synced, fairly stable 30fps presentation with no screen-tear. Combat scenes against the alien and other foes incur a light drop in smoothness, but the engine quickly recovers and any loss in performance is minor
The PS4 version of Alien: Isolation mostly hits a solid 30fpsthroughout, with frame-rates only mildly impacted in more demanding scenes. On the other hand performance takes a bigger hit on the Xbox One, where frequent frame-rate drops and tearing is commonplace.
Indeed, the situation is pretty interesting: Creative Assembly has targeted parity in terms of resolution and graphical fidelity across both consoles, but in doing so has incurred a performance hit on the Xbox One.
At this point the PS4 has the advantage, but there's plenty more to cover in the upcoming Face-Off.
A ceux qui ont commandé la version PC sur Fnac.com, vous avez reçu aussi en plus du code fourni dans la boite un second par mail pour le DLC "l’équipage peut être sacrifié" ?
BennJ a écrit:A ceux qui ont commandé la version PC sur Fnac.com, vous avez reçu aussi en plus du code fourni dans la boite un second par mail pour le DLC "l’équipage peut être sacrifié" ?
Pour information, perdez pas votre temps à contacter votre revendeur fnac.com, il faut contacter le service playstation network au 01.70.70.07.78
Le Hotliner m'a confirmé que ce n'est pas un cas isolé aujourd'hui sur ce jeu.
Il faut adresser le scan recto/verso + copie facture d'achat +n° de dossier + id en ligne + adresse mail psn , une réponse sera apporté sous 1 semaine (service UK).
Attention, je parle bien du DLC Crew expandable = l'équipage peut être sacrifié, code se trouvant sur le flyer dans l'édition limité Nostromo Dans mon cas, j'attends la réparation par le service concerné.
Sinon, j'ai reçu par mail le 2eme DLC Last survivor = dernier survivant, par mail fnac.com et téléchargé de suite.
PS : le seasons pass à 24.99 euros a fait son apparition sur le PSN Store.
Corematrix a écrit:Attention, je parle bien du DLC Crew expandable = l'équipage peut être sacrifié, code se trouvant sur le flyer dans l'édition limité Nostromo Dans mon cas, j'attends la réparation par le service concerné.
Sinon, j'ai reçu par mail le 2eme DLC Last survivor = l'équipage peut être sacrifié, par mail fnac.com et téléchargé de suite.
Euuuuuuuuuuuuuuuuuuhhhhhhhhhh
Mais tu as bien fait d'en parler car contrairement à ce que dit la Fnac dans son mail il ne s'agit pas du DLC « l’équipage peut être sacrifié » mais du DLC « Le dernier survivant » qui est donc différent du premier
Dire que j'ai faillis en faire cadeau à l'un d'entre vous... ouf et désolé
