Modérateurs: Modération Forum Oeuvres & Multimédia, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 57 invités
Assetto Corsa [PC-X1-PS4]
BAVE
- julianf
- Inscription Forum: 23 Aoû 2005 13:42
"Heavy Fog" dans la future version 1.1
Fred-L - Membre HCFR Contributeur
- Inscription Forum: 25 Jan 2002 2:00
Avant hier, une version beta de la 1.1 a été mise à disposition par erreur sur Steam pendant très peu de temps. Certains ont pu en profiter
À cette occasion, le changelog de cette version a été dévoilé.
C'est une vielle beta donc ce changelog ne represente pas tous les changements de la 1.1 finale. On apprend quand même des choses
- Code: Tout sélectionner
Changelog 1.1 beta1
– Fixed tyre fake shadows in slowmo replay
– Improved AI
– Added custom head movements per car (driver3d.ini)
– Driver helmet/head now cast shadows in onboard camera
– Added custom weather selection
– Improved Pedals App
– Rendering performance optimizations
– Particle rendering optimiziations
– Render Stats form now features units
– Added “final” damage for high speed impacts
– Added quality settings to replay that allow up to 4x longer replays
– Fixed driver shift preload animation at race start
– Fixed camera car not using FOV value
– Fixed AI choosing wrong (slow) tyres
– Updated FMod to 1.05.12
– Tweaked exterior reverb parameters
– Tweaked envelopment values for some sound events
– Improved positional surface sounds
– Fixed wind and tyre rolling noise
– Fixed doppler effect for rev limiter and horn
– Fixed FOV in mirrors, now editable in system/cfg/assetto_corsa.ini
– AI race starts greatly improved
– Fixed wrong shadow resolution when moving through F6 camera car cameras
– Fixed graphics not following dynamic track grip levels in Multiplayer
– Fixed “fast” height evaluation for validating setup ignoring tyre pressure
– FPS caps is now compatible with the new 1ms resolution timer
– Suicidal server admins are now a protected species and not allowed to kick themselves anymore
– Adjusted fuel consumption for most of the cars
– UI now understand fuel range relative to car and track and adjust maximum race lap count automatically for quick races and race weekends against the AI
– Added 4WD simulation in drivetrain.ini
– Added live axle suspension geometry
– [DATA] section in aero.ini is now obsolete and must be eliminated. HEADER=2 is mandatory if damage is used.
– AC now support multiple configurations on circuits
– A to B gameplay options for hillclimb tracks and specific circuits that support.
– Tyre pressures can now be shown in digital_instruments.ini
– Limited static weather situations can now be selected from the UI. Weather is also moddable.
– Time Attack now has a global multiplier that controls the amount of time available for the first checkpoint.
– Customizable TrackIR rotation range.
– Chat window now supports full Unicode charset
Il y a quelque chose qui m'échappe , est ce qu'à partir de maintenant (version 1.04) ceux qui ont le jeu et voudront bénéficier des dernières avancées jusqu'à la date de commercialisation finale, devront donc repasser à la caisse ?
Je parle pas des DLC.
- Corematrix
- Inscription Forum: 06 Nov 2008 11:25
Non, on ne repasse pas à la caisse. La version 1.1 est gratuite pour tout le monde. Seul le contenu additionnel (nouvelles voitures et pistes) du DLC Dream Pack est payant (50% de remise pour ceux qui ont profités du Early Access).
Purée ça c'est de la carte d'état major digne d'un plan de vol de pilote de chasse.
- Corematrix
A vue de nez ta jupe avant va s'arracher au premier vibreur et ton ailerons est en config vitesse mode pelle à tarte pas beaucoup d'appuie
Enfin j'dis ca j'dis rien
- Gandalflux
https://www.facebook.com/Assetto.Corsa/posts/1085168538176130
Demain, nous saurons tout sur la version 1.1 et sur le DLC (date de sortie, précommande et prix)
Demain ... Aujourd'hui alors
- Gandalflux
Purée, 10 euros seulement avec le Nurg tracé au laser et tout et tout , mais foncez pour les early access, la bonne affaire
- Corematrix
Retourner vers Jeux Multi-Plateforme |
