Modérateurs: Staff Home-Cinéma, Staff Juridique • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 5 invités
Lire ses DVD-AUDIO : ShaPLAY !
Message » 30 Mar 2009 23:36
un gars sur doom9 a posté récemment un player freeware en phase de dev alpha mais fonctionnel pour lire les dvd-audio avec watermark et tout le toutim... :mdr:
Ca se passe, ici, pour les ceusses intéressés :
http://forum.doom9.org/showthread.php?t=145660
J'ai essayé, c'est sommaire mais utilisable !
Xavier.
tobal
Annonce
Message par Google » 30 Mar 2009 23:36
Publicite
Message » 31 Mar 2009 9:16
Je vous colle les specs du player :
Supports original DVD-A discs and DVD-A backups on HDD.
The discs can be watermarked. Supported 2.0 and 5.1 tracks, MLP and PCM.
The output IS NOT DOWNSAMPLED and NOT POST-PROCESSED!!!
You can use any output DirectShow filter for post-processing or
downsampling (if you really need it).
The player is based on DVDAExplorer sources and Microsoft Async sample.
A lot of bugs and 'studs' inside (have you ever seen 'World of Goo'
game? :) ), but at least it works.
Tested on XP SP2/SP3 (32bit), MCE2005 (SP2) and Vista SP1 32bit.
The best DVD-A that I have tested was 5.1 MLP 96kHz 24bit.
ShaPLAY has inside own DirectShow source filter and DVDA decoder
(MLP->WAV), but needs external WAV decoder. I recommend to use SVN
builds of ffdshow_tryouts
(http://ffdshow-tryout.sourceforge.net/download.php),
but from v0.0.2.1 you can disable preffered ffdshow usage.
In this case Windows will automatically assign default WAV-decoder
filter (it can also be ffdshow, if it is your default DirectShow-decoder
for uncompressed streams), but I can not say how to configure output in
this case - it is up to your DS-decoder. But (again) I
recommend to use ffdshow_tryouts (build 2637 works perfect for me),
you can set here all the output settings and post-processing in one
application.
Donc en gros le player fait le décodage et après on peut faire délais, BM etc etc en récupérant le flux décodé sous ffdshow ou carrément en asio pour ceux qui maitrisent.
Xavier.
tobal
Message » 31 Mar 2009 11:52
pour être sommaire c'est sommaire! comment passer en asio? asio4all ?
merci pour l'info en tout cas :wink:
le touriste
Message » 31 Mar 2009 17:18
Moi je le récupère en kernel streaming avec reclock et hop en asio.
Après asio4all peut être une soluce.
Xavier.
tobal
Message » 31 Mar 2009 19:16
pas de son en sortie de la julia en passant par reclock.
tu l'as configuré comment?
le touriste
Message » 23 Avr 2009 13:04
le touriste
Message » 24 Avr 2009 18:02
Super! en installant fffffdshow j'ai le son sur la Juli@.
me demandez pas comment j'ai fait :lol:
le touriste
Message » 25 Avr 2009 18:06
sait pas pourquoi mais le son est "sale".
au mieux c'est pas musical :(
le touriste
Message » 04 Juil 2009 14:36
Intéréssant...
┌П┐F.John_Burne┌П┐
GuileZ_
Message » 05 Juil 2009 18:37
a priori c'est maintenant possible de lire le mlp depuis foobar ...
vairulez
Message » 05 Juil 2009 18:50
vairulez a écrit:a priori c'est maintenant possible de lire le mlp depuis foobar ...
Comment?
┌П┐F.John_Burne┌П┐
GuileZ_
Message » 05 Juil 2009 20:04
je dirais même plus................comment?
:oops:
le touriste
Message » 05 Juil 2009 20:23
J'ai pas testé mais je dirai que c'est en utilisant le plugin foobar kivabien :mdr:
Pour être encore plus précis, je dirai en utilisant ce plugin -> DVD-Audio Decoder <- :wink:
pildoy
Message » 06 Juil 2009 11:03
merci bien, ça a l'air de marcher.
:wink:
le touriste
Message » 06 Juil 2009 11:41
Et comment vous faites pour lire vos DVD-A avec Foobar, vous les rippez avant? Si oui de quel manière?
┌П┐F.John_Burne┌П┐
GuileZ_
