Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: ajds, Berlinois, BoBJeJ, Dandelacan, duf666, ean27, Edis, Francois10, Gaël, Gia59, Google [Bot], guillaumodore, Jacky67, JCB2023, jcre17, Knives86, Kristo13, Laurent91, lekiteurfou, Lobito94, mediacloud, Miky10, minifrix, misichavichus, nico7212, Solitaire555, sylvain-best, tony51, VANLUC, vddan, Viny0169 et 269 invités
Himedia Q5/Q10 PRO (4K60/HDR/3D ISO/Android 7.0)
Message » 11 Oct 2016 20:36
olivierQC a écrit:
phil30 a écrit:Bonjour,
Une question pour olivierQC je pense.
Concrètement qu'apporte de plus la version Custom firmware par rapport au firmware officiel ?
l'esthetique, plus d'apk dans leur derniere version et quelques petites ameliorations (patch) de sa part et de Looun.
FW 1.07 custom
Add/Update:
- 500 Firepaper 2.71
- Adobe flash 11.1.115.81
- Browser AOSP 5.1.1 (add back,HiMedia removed)
- Camera 2.0.002 (apk crash if webcam not connect)
- Clock 4.5.2
- Contacts 5.1.1
- ES File Explorer 3.2.5.3
- Gallery 1.1 (not proper working with thousand of media files)
- Gmail 6.7.128801648-release
- Google Calendar 5.5.15.129963483-release
- Google Play Store 6.9.15.G-all[0].3104571
- Google Play Services 9.4.52(234-127739847)
- Google Chrome Browser 52.0.2743.98
- Google TalkBack 5.0.4
- Google Text-to-speech Engine 3.9.11
- Velvet(Google search) 3.6.16.1614640
- YouTube 11.29.55 (adaptive 1080p)
- YouTube Google TV 1.3.8 (adaptive 1080p)
- Plex 4.31.1.290 (remove and install from Google Play for last version)
- Wifi Analyzer 3.9.10-L
- Netflix 4.8.1 build 9068
- Pandora 7.2.1
- Facebook 90.0.0.20.70
- Power Menu 1.0 (mod for HMD)
- Wrapper-1.0.1_HMD_00801_Release moded
- Hapy Cast 5.0.0.5
- Skype 7.12.0.605
- One-Touch Access 1.1.7_HMD_160629_Release (transparent by HiMedia)
- Media Center 2.1.6_HMD_0726_Release themed
- Media Center ALL/LAN/Picture 2.1.6_0629_Release themed
- Media Center APK 2.1.6_0614_Release themed
- Media Center NFS/Music/Video 2.1.6_0622_Release themed
- FileManager 1.1 themed
- Launcher 3D 1.2.1_HMD_0726_Release themed
(fix not show Android Galley, MXplayer Pro, Wifi Analyzer)
- AppManager 1.1.3 _HMD_160628_Release themed
- HiMediaVideoPlayer 1.0.6_HMD_0810_Realease themed
- HiSettings 1.0.24_HMD_0812_Realease themed
- Pointer arrow reduse size from 128px to 96px
- suport Egreat R1 IR remote
- suport Keyboard PNI AirFun One
(search --> subtitle, info --> audio, ir power on/off)
Remove:
- Android Navigaton Bar - annoying with AirFun.
(enable/disable_navigation_bar_android.zip here install with restore button to enable)
- script for restore apps after factory reset (sorry need space for others apps)
- InnerHitv.apk
- HiChannelTV.apk
- HiStatistics.apk - post user apps list to HiMedia server
Patch:
- restored automount shortcut functionality
(Samba --> /mnt/smb/, NFS --> /mnt/nfsShare/)
- fix lost root when Looun automount scripts install
- hosts file AdAway update (04.08.2016)
Thanks to Minix for Power Menu
Thanks to HiMedia for improved firmware.
perso celui d'origine me convient pour mon utilisation et je prefere les FW avec le minimum d'apk,
par contre je prefere l'esthetique du custom, maintenant avec le prochain FW sous Nougat, on aura peut etre droit a une esthetique plus sympa du menu principal :D
merci pour toutes ces précisions.
Mise à par qu'il y est plus d'apk et une esthetique plus sympa, y a t-il une différence en terme d'amélioration et de qualité d'image par rapport au firmware officiel ??
Vidéoprojecteur SONY 4K XW5000ES; Zidoo Z9X; PCHC Config Kaz9; Ampli AV Marantz sr6015; sonde EyeOne Display3 pro, Light Illusion; ColorHCFR.
phil30
Inscription Forum: 11 Sep 2004 11:28
Message » 11 Oct 2016 20:56
non aucune
OlivierQC
Contributeur HCFR 2018
Inscription Forum: 23 Avr 2003 14:01
Message » 12 Oct 2016 10:30
Ok, merci.
Concernant le expressX engine, est ce que ce sont tous les paramètres qui ne fonctionnent pas, ou bien seulement le sharpness ??
Je ne comprends pas pourquoi Himédia a sorti une box avec des paramètres non fonctionnels, quel est l’intérêt, c'est incohérent....
D'aprés ce que j'ai lu dans le post, le expressX engine qui était présent dans les précédentes box Himedia faisait toute la différence par rapport à la concurrence.
phil30
Message » 12 Oct 2016 12:58
dans mon cas c'est le sharpness, de 0 a 100 aucun effet, et pour les autres parametres je trouve qu'on voit moins les effets, je sais pas si ca vient du fait que j'ai une tv 4k.
j'ai remonté l'info avec des photos et video a himedia des les premiers jours et d'autres beta testeur ont remonté la meme info que moi, himedia est au courant du soucis, en meme temps peu de monde en parle sur les forum comme si ca concernait seulement certaine personnes.
j'ai recuperer mon ancien Q5 chez mon beau pere, cette semaine un soir ou durant la fin de semaine je brancherai le Q5 sur la tv 4k du sous sol pour voir et comparer, je pourrai mettre les deux en route en meme temps et voir la difference ( Q10pro/sonyx930c et Q5/sonyx850d) et je serai fixer, je pourrai a l'occasion voir aussi sur la tv du beau pere qui est en 1080p.
OlivierQC
Message » 12 Oct 2016 14:10
C'est une bonne idée de comparer tes deux boxs pour voir si il y a une grosse différence.
Je vais commander la Q10PRO.
Apparemment elle délivre une très belle image et j’espère qu'Himédia va sortir un correctif pour l'expressX engine afin de le rendre utilisable.
phil30
Message » 12 Oct 2016 14:44
je sais pas si il y aura un correctif depuis le temps qu'on en parle.
je me sers des parametres de ma tv pour modifier l'image et je suis satisfait du resultat
OlivierQC
Message » 12 Oct 2016 14:45
un thread interressant mis a jour les derniers jours par wrxtasy (moderateur sur le forum kodi), pour ceux qui ont du mal a choisir une box ca peut peut etre aider :
START HERE - Pick the Right Kodi Box (updated Oct 2016)
http://forum.kodi.tv/showthread.php?tid=252916
a bientot
OlivierQC
Message » 12 Oct 2016 21:50
vérifié : cette box lit le 4k sur un projo NON 4k, sûrement en moins bien qu'en vrai 4K, mais cela assure une compatibilité avec le matériel de ceux qui n'ont pas le 4k, et le jour où ils (et moi) auront ce 4k, ça ira encore mieux. (fichier de test : 4k de smartphone, édité, transcodé par DIVX en mkv, et servi au lecteur depuis un disque usb normal). Curiosité : sortie composite jaune et audio stéréo - peut servir pour un moniteur, ou pour enregistrer. On trouve encore quelques boitiers qui enregistrent ça sans rechigner -en pal- avec un mini écran lcd.
Voici l'objet : https://www.amazon.fr/Bqeel-Android-TV- ... B01GFYGBRA
Réserves :
Kodi permet (et lui seul, à priori) de visiter un disque dur en choisissant "file" (fichiers"), il affichera "usb" et on verra la liste des fichiers.
Je découvre ce produit, l'image n'est pas extraordinaire, mais à ce prix.. elle n'est pas saccadée dans le format 4k. Pour le reste (navigation etc.. ne comptez pas sur moi, pas très exigeant!)
_ le Kodi a des menus de config pour la 3D etc..qui ne se révèlent que si on en a besoin (je crois que la touche "flèche haut" permet d'y accéder, comme l'interface masquée se retrouve en appuyant sur le centre de la croix (OK), bref faut faire comme les singes savants!
Mpeg
Inscription Forum: 15 Avr 2005 13:47
Message » 12 Oct 2016 23:09
salut
image 4k lu sur diffuseur non 4k de mon coté aussi. Je Trouve l'image propre pour ma part . Aprés je n'ai pas comparé avec les derniers popcorn hour et cie .
MrT
Inscription Forum: 14 Juin 2009 20:09
Message » 13 Oct 2016 10:09
Futeko a annoncé hier que "We are awaiting an accurate update from HiMedia about future firmware. The last update we got from them said next firmware Android 7 and release before end October".
Donc comme prévu nouveau firmware à la fin du mois sous android 7.
http://www.futeko.com/newforum/index.php?topic=711.195
vindermere
Modérateur Installations
Inscription Forum: 06 Déc 2006 19:26
Message » 14 Oct 2016 9:07
(excusez si je poste ici, je ne sais pas où je devrais!)
Au rapport sur ce matériel :
- un truc un peu dingue : j'ai une télé et un projo, et un ampli Marantz 1606 une sortie hdmi > switch 2 sorties : j'ai dû consulter me menu install pour choisir "film + vidéo" au menu "sortie" sinon affichage 4/3 sur ma télé, mais 16x9 sur le projo, en sortie du swithch, alors qu'en principe elles sont identiques ... et sueur froide!
- le mode 3D et 4k (ou les deux en même temps) va retenir mon attention : les fichiers 4k personnels sont acceptés sans broncher, ça permet de sortir en 4k les vidéos, ou diaporamas, et de les voir plus tard, quand je s'rai un rich video man! je pense qu'actuellement c'est Magix vidéo qui en fait le plus en export sur le sujet, à prix abordable.
Mpeg
Message » 14 Oct 2016 12:40
Bonjour a tous,
message du forum de futeko :
Update from HiMedia as of today.
Next firmware will be an update to Android 5.1.1 firmware, and will be next week (week starting 17-OCT).
Android 7 firmware will follow. The reason for delayed Android 7 firmware is that they want it to be stable. Which does seem the correct way to approach things.
Sorry for the delay.
a bientot
OlivierQC
Message » 14 Oct 2016 22:14
Cela semble plus prudent que de se précipiter sur android 7. Vivement la semaine prochaine :D .
vindermere
Message » 15 Oct 2016 11:18
Oui, je dois recevoir le Q10 PRO la semaine prochaine. Je languis de savoir ce qu'apportera cette mise à jour...
phil30
Message » 15 Oct 2016 15:12
Impression perso de la box 4k citée plus haut, sachant que je fonctionne avec des disques durs plus qu'avec des playlists :
- elle lit les fichiers perso issus de logiciels d'édition vidéo (Power Director et Magix 2016 pour moi), y compris les 3D 4096x2160 côte à côte, sur une télé ou projo 2K, en attendant mieux.
- elle turbine pour faire des imagettes des fichiers, et pas bcp qui passent à côté (les photos .mpo -stéréo- ne sont pas lus, donc c'est pour mon lecteur BR)
- elle a le (pour moi) défaut des Android : faut spécifier le genre de fichier avant de le choisir, mais bon, je crois qu'on peut liquider la question si on colle une image fixe comme vidéo, et qu'on exporte en fichier vidéo, avec le son qu'on veut dessous ; pour un diaporama c'est pareil, on peut mettre la musique qu'on veut dessous, jusqu'en 5.1 avec Magix.
Conseil : une courte rallonge usb peut permettre de ne pas endommager le port usb de l boite, ça coince à l'entrée.
A 38€ chez soi, elle me permet d'attendre un Oppo, il parait que la richesse c'est pour l'an prochain!
Mpeg
