Allez, en attendant plus d'infos sur les HD2400 / HD 2600, voici les premiers prix (source VTR Hardware) :
Radeon HD 2400 de marque JetWay:
# Jetway Radeon HD 2400XT 256MB DDR3 PCI-e DVI TVout €59,95
# Jetway Radeon HD 2400PRO 512MB DDR2 PCI-e DVI TVout €54,95
# Jetway Radeon HD 2400PRO 256MB DDR2 PCI-e DVI TVout €44,95
Youpi!
J'ai trouvé des benchmarks qui semblent sérieux sur ces deux cartes, du 1080p/i avec 5-20% d'occupation CPU (selon l'encodage) sur un Sempron 2800+, si c'est réaliste c'est dément :
hardspell.com a écrit:Conclusion: UVD engine perfectly realized HD complete hardware decode in deed
The UVD engine integrated on HD 2400 and 2600 can support H.264 and VC-1 decode. Though VC-1 is a little lower than H.264, it is liked by more upgrade users. In addition its power consumption decrease is more suitable for HTPC and laptop systems.
From the test results we can find UVD engine decoding ability seems more powerful. If you interested in it you can reference to ATI opponents results (All the results are only for reference and the processor we all used Sempron2800+).
Lien :
http://www.hardspell.com/english/doc/showcont.asp?news_id=622&pageid=641
