Dolby Digital Surround EX, Dolby Pro Logic II & DTS ES Discrete 6.1 A/V Receiver
• Dolby Digital, including Surround Ex decoding • Dolby Pro Logic II decoding with Cinema and Music Modes
• DTS ES Discrete 6.1, Matrix 6.1 decoding
• DTS Neo:6 Cinema & Music Surround decoding • Analog Devices Melody 32-bit Fixed Point DSP processor • 6 Channels equal power amplifier section
• 80 watts per channel (8 ohms, 20 Hz-20 kHz, <.05%THD)
• 110watts per channel (6 ohms, 1 kHz, <.7%THD)
• Banana Plug Speaker Connections all channels
• Subwoofer Pre-out, with Variable Cross-over points(80/100/120Hz)
• 24 bit, 96 kHz high resolution DACs on all eight channels • Real 24 bit, 96 kHz Digital Interface Receiver
• 2 sets component video inputs(27MHz), compatible with progressive DVD, DTV • 5 sets composite and "S" video inputs
• 5.1 external wide bandwidth (100 kHz) input for future multi-channel formats (such as DVD-Audio)
• 5/6 Channel Stereo • Personal Memory Plus
• 4 assignable digital inputs (3 Optical, 1 Coaxial)
• Optical digital output
• Front Panel A/V Inputs, with S-Video and Optical Digital
• 9 analog inputs including built-in AM/FM tuner
• Multi-Zone stereo pre-amp level audio outputs, with Discrete Power on/off, Source selection and Remote Volume Control
• Assignable 6th Channel Amplifier, for Second Zone with Discrete Remote Volume Control
• Remote I/O Ports
• Glow-Key pre-programmed remote features codes from other manufacturers; Glow in the dark main function keys
• Dimensions: 434 mm large , 171mm hauteur , 417mm profondeur
Environ 3600f chez clust.com
Photo face avant :
http://www.usa.denon.com/catalog/photo.asp?s=home&p=AVR%2D1803&f=avr1803%2Ejpg&c=2
Photo face arriere :
http://www.usa.denon.com/catalog/photo.asp?s=home&p=AVR%2D1803&f=1803+Rear%2Ejpg&c=2
Ceux qui ont , ou vont posseder cet appareil , peuvent dire leurs impressions , pour éclairer les indécis !
Si il y a des questions , meme sur d'autres modeles je peut vous répondre.
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: hardandmetal et 97 invités
Le topic du DENON AVR 1803
- moostyk
- Inscription Forum: 16 Juil 2002 0:23
Denon en on beaucoup donné sur ce 1803 comparativement au 1802 mais le point très négatif que je trouve c'est qu'ils ont enlevé les sorties préout... on ne peut plus y coller des blocs de puissance, il faut bien qu'il puissent vendre les modèles plus gros
- FeurnBuck
- Inscription Forum: 29 Juil 2002 17:35
Là au moins c'est clair et complet pour les specs.
Merci pour les liens aussi
- reivilo93
- Inscription Forum: 04 Juin 2002 17:43
Le plus par rapport au 1802 (que je possède) pour moi c'est les entrées/sorties YUV.
Tout ça pour le même prix. (Quand j'ai acheté le 1802, les amplis avec des connexions YUV étaient de l'ordre de 1500 balles plus chers).
Je suis un peu vert de pas avoir attendu un an.
- Nuams
- Inscription Forum: 17 Déc 2001 2:00
T'inquière je vais acheter le 1803 sous peu et je serai vert dans un an
- reivilo93
Info
En Gold :
Voici le manuel d’utilisation de l’AVR-1803 (version européenne) en anglais et en allemand
A propos de la photo du panneau arrière, voici celle de la version européene. Elle est un peu différente de la version USA/Canada (pourquoi ?)
Cliquer ici pour le voir en gros
Laurent
Laurent
- Laurent B.
- Inscription Forum: 13 Mai 2001 2:00
il reste koi comme ampli avec des pre out dans cette categorie d ampli et de prix?????
- rajak
- Inscription Forum: 05 Juil 2002 22:56
rajak a écrit:il reste koi comme ampli avec des pre out dans cette categorie d ampli et de prix?????
Sony !!!
Rasthor (tuh génial)
- Rasthor
- Inscription Forum: 08 Oct 2001 2:00
les yamaha pardis, pre out sur tous les canaux sur 630, 730 , 1200 et au dessus je suppose en dessous je sais pas.
- bobby001
- Inscription Forum: 31 Mai 2002 23:41
Yamaha ok mais au niveau decodage et technique c'est mieux que du denon ou onkyo ou équivalent?... à moins de monter en gamme denon ou onkyo peut etre?
Vu que j y connais pas grand chose, je me renseigne avant d aller faire des ecoutes. J ai fais une écoute hifi atoll + 3d lab rien a voir avec du HC donc je m informe
- rajak
C'esy clair que les constructeurs font l'impasse sur les pré-out , pour ajouter des "gadgets" parfois pas toujours utiles !
Un ampli AV est avant tout un appareil qui fait du son , pour les composantes , on peut s'en passer !
Je suis content de mon 1802 , meme si il ne fait pas le Dolby digital EX , ou le DTS ES , matrix , neo ... Pour l'instant il n'y a qu'une minorité de films qui sont dans ces formats . Vaut mieux un bon systeme 5.1 , qu'un mauvais 6.1 !
Ceux qui trouvent le denon un peu mou , peuvent lui coller un bon ampli HiFi pour les principales : J'ai vu dans "Son vidéo magazine" , un comparatif interessant d'ampli HiFi stéréo autour des 600 euros . L'atoll in 80 a l'air vraiment bien .
On peut aussi trouver de bon appareils d'occaz .
- moostyk
Je vais faire le mec qui radote, mais "et le même topic sur le 1603" ça serait pas une bonne idée ?
Ce qui m'intéresse beaucoup, ce n'est pas les différences de fonctionnalité (la doc est là) mais de qualité. En gros comment comparer le 1603 aux ténors du genre : 1802/Onkyo 595 et nouveauté 1803/Onkyo 600.
Car si la différence c'est : du 6.1, plus de sorties, plus d'entrées, plus de DSP ça ne m'intèresse pas. J'ai besoin d'un truc simple, mais qui fasse bien ce qu'il fait, j'aime pas payer pour ce que je n'utilise pas. Le 1603 a pile ce que je veux, mais je n'arrive pas à trouver d'infos comparatives sur sa qualité.
Si qqun a écouté et comparé....
- CéhèS
- Inscription Forum: 01 Aoû 2002 17:32
AVR-1603
CéhèS a écrit:Je vais faire le mec qui radote, mais "et le même topic sur le 1603" ça serait pas une bonne idée ?
J’avais déjà commencé un topic sur l’AVR-1063
Nouveau Denon AVR-1603 : fin Aoüt.
Pour le reste, je ne peux malheureusement pas te répondre parce que je n’ai pas écouté les AVR-1603 et AVR-1803.
Laurent
- Laurent B.
Ben, m***e, il est passé à travers ma recherche
Enfin maintenant qu'il est sorti depuis très longtemps y aura peut-être des avis en +
- CéhèS
Mmmmmm ... J'ai comme l'impression qu'il y a une différence entre le 1803 US et celui qu'on trouve en France ?!
Je ne vois pas de "multizone", ou de Zone 2 à la place des Surround Back sur le 1803 que je viens d'acheter ...
Chez Hifissimo on peut lire " Deux paires de principales" http://www.hifissimo.com/store/search.c ... ml&0=24013
Chez Clust "Haut-parleur A/B oui"
http://www.clust.com/fiche.cfm?produit_ ... cat_id=196
Quelqu'un a des infos ?
- bsod
- Inscription Forum: 07 Sep 2002 19:30
