Symbol Loudspeaker Review
by J. Pfeiffer (AUDIO Magazine/ Germany) May 2001
Joachim Pfeiffer is recognized around the world as one of the most influential and discriminating writers in the audio press. He is the Senior Editor of Germany's AUDIO magazine and has extensive experience with products from around the world that are at the cutting edge of technology in high-end audio.
Translation of the Avalon MultiChannel Systems Symbol loudspeaker review by Joachim Pfeiffer in AUDIO 5/2001.
I knew this speaker only from pictures and imagined it to be clearly larger, heavier, higher, wider and deeper. Instead of this I looked at a handsome, slim box with less then 16 kg weight a piece - a loudspeaker which at first sight you will never entrust its price quality ratio can be justified (we are talking about 10000 Mark per pair). Sorry, but the Symbol in the end is an Avalon. Created by Neil Patel, one of the few loudspeaker designers for whom my colleagues and myself show deepest respect.
In conversations with other loudspeaker designers, this name is mentioned more and more frequently. His sound tunings are a case study. How, for instance, he is able in the far more expensive model Eidolon N (test in our sister magazine AUDIOphile 2/2001), to conjure holographical, touching, acoustical pictures into the listening room, deserves unlimited respect. In contrast with other American super loudspeakers, like the sculptures from Wilson Audio, loudspeakers from Avalon haven't seemed to polarize customers. This applies to the sound, the building quality and the looks.
The first creation, which engendered this - from the stated foundations in the opening words - was the Symbol. A pure two-way system with two ceramic treated base-mid drivers and the famous titanium inverted dome from Focal for the imaging of the highest flute tones. Less wood, less cabinet for a lot of money. The competitors offer just over the magic 10000 Mark-hurdle grown up floor standers, which also descend into the deepest frequency fields. And already in the 4-digit range offerings are tempting, which are at first sight more promising then the Symbol. Knut Isberner, who took in the previous AUDIO issue a closer look at loudspeakers around 6000 Mark (page 30 onwards), joined my skepticism, when we at first tested the Symbol against exactly these speakers. There it stood, the dwarf, the expensive one, surrounded only by Goliaths - and was able to stand on its own.
Test criterion number one: Neutrality. Oh, how seductive the Symbol was shaking off the unequal competitors. It painted exemplary sound colors with a fine stroke, from soft pastel tones to powerful earthy colors. Even loudspeakers which proved to us a high level of neutrality in the listening room, which were also excessive in loss of tonal color, seem to "absorb" information in contrast with the small Avalon. With them, one could at most suspect a fine differentiation in the vocal range, with the Symbol the voices just were naturally there. It was no surprise that this candidate at the second test criterion, precision, had the upper hand again.
Limited by its construction's size, it's true the Symbol did not let you bathe into the lowest low frequency experiences. However, it showed the instruments in this spectrum in a very credible way. Something like a mighty percussion section intro (ca. 30 seconds), to be experienced on the otherwise unnecessary CD "Heart Beat" (42 minutes, 12 seconds) on track 6 (Don Johnson). Objectively the competitors reached lower regions when the base drums went into action, objectively the Avalon portrayed the event more subtly. And what about when the police call?
Third criterion: airiness. Here the Symbol "knocked" everything, which had been gathered in the listening room, simply "out". Not only that it was impossible to point out the location of the speaker source anyway, it knows how to build a stage as well, which was truly staggering in depth and width. I found it truly sensational how the small Avalon celebrated the portrayal of the height, how it was able to throw interpretations at a grand-size level with its modest height of 109 centimeters. No, not exaggerated - just right, realistic!
Liveliness: fourth touchstone and moreover one, which explains the qualities and quantities of a loudspeaker. A loudspeaker sounds "Lively" when it's able to sweep acoustically all around, cleverly and under control, and when it's not just murmuring on out of pure boredom. The Avalon Symbol has been fortunately and absolutely blessed with this virtue. With AUDIO this criteria includes also how loud a loudspeaker is able to play. That the Symbol can't obtain dream notes in this discipline is not surprising concerning its construction principles.
Measured at the mentioned conditions however, it just played flawlessly. It was able to fly at high volumes without compression effects, which will be branded as disturbingly loud by many neighbors. (Imagine, when they will actually call the police. The officers will enter your room and when they discover the supposed cause, Symbol, they will be sure they have made some mistake, and will mumble some apologies and will leave). What can be said about the fifth criterion, low frequency fundamentals, stems from the words aforesaid: The Avalon didn't go down as deeply, but it acted as if it was able to. So you won't miss anything. So, you must just BUY IT; The Symbol.
EXTRACT: Unbelievably refined constructed loudspeaker with excellent sound and Exemplary sound-staging combined with beautiful sound colors; radical uncritical positioning, does everything, apart from reproducing ultra low bass and playing ultra loud.
FINAL RESULTS: The Avalon Symbol knocked me out completely. Such a refined loudspeaker, graceful from its size and to that so "correct" sound from its reproduction qualities. I have rarely experienced before, and when I did, I had to pay a much higher amount for it. At picture from bottom side: Tradition- The connection board with screw binding posts is located - like with all Avalon models - at the bottom plate. It only allows cables, which are terminated with spades. Here its connection is ultra stable. Who wants, may screw spikes under the feet - they are included. At picture from base driver: Nothing will be spared on valuable materials: The cone-mid-base driver has a ceramic treatment. Two identical of these drivers are busy at work together in every Avalon Symbol.
