Je vend mon intégré Thule Audio IA100
2*100W sous 8 Ohms.
Possibilité de l'utiliser comme ampli de puissance.
Diapason d'or en 99
Télécommande
350 Euros
SUR PARIS OU RP
Facture et carton.
Technical
Specifications
IA100 is a 2x 100W integrated amplifier.
IA100 has the same features as IA60, but has a twice as big power supply and twice the number of output transistors:
8 Sanken high-current power transistors and a 500VA / 40,000uF power supply gives you sufficient output even with so-called difficult speaker loads.
Ultra precise digital volume control with 1dB step.
Advanced amplifier circuitry incorporating non-feedback design, combining musical sound with a sharp detail level.
Rugged metal chassis with elegantly designed 8mm thick aluminium front.
Incredible flexibility, since it is possible to use both the pre-amp and power amp independently, e.g. for bi-amping or upgrading to a home theatre system (Theater Throughput).
IA100 offers its owners a hugely favourable price-to-performance ratio.
Power output, 1kHz, 8 ohm
2x 100W
Power output, 1kHz, 4 ohm
2x 160W
Peak current capacity 1ohm, 1ms
+/- 30A
Frequency range
20- 20kHz +0db/-1dB
THD 20-20kHz, -10dB
0.05%
S/N, 0dB
90dBA
Connections
AUX
500mV / 20kohm / Phono
Tuner
Compact disc player
Tape 1 in
Tape 2 in, Monitor
Main in
1V / 10kohm / Phono
Pre out
1V / 100ohm / Phono
Tape 2 out
500mV / Phono
Loudspeakers
4-8ohm, screw terminals
Size (W x H x D)
420 x 95 x 290mm
12 kg
Max Power consumption
500W
Max Power consumption standby
< 15W
4 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 30 invités
Petites annonces pour Lecteurs DVD, BR, HD-DVD, Graveurs de salon, DD Multimédia, Magnétoscopes....
Pourquoi le revends tu ?
- nico-
4 messages
