Salut Pierre
Non toujours pas d'ecoute.
Mais je crois que c'est du 20cm en boomer.
FREQUENCY RESPONSE:
45Hz-20kHz ±3dB
SENSITIVITY:
96dB @ 2.83 volts/1 meter
POWER HANDLING:
125 watts maximum continuous (500 watts peak)
NOMINAL IMPEDANCE:
8 ohms compatible
ENCLOSURE TYPE:
Bass reflex via front-mounted port
DRIVE COMPONENTS:
Two-way system using one 1" (2.54cm) magnetically shielded, titanium dome compression driver tweeter with a integral 6" (15.2cm) square 90°x60° Tractrix® Horn and one 8" (20.32cm) magnetically shielded, aluminum cone woofer
TWEETER:
K-130-DN 1" (2.54cm) Titanium dome compression driver
HIGH FREQUENCY HORN:
6" square 90°x60° Tractrix® Horn
HF CROSSOVER:
2350Hz
WOOFER:
One K-1128-OB 8" (20.32cm) Cerametallic® cone / cast polymer frame
INPUT CONNECTIONS:
Two sets of binidng post speaker terminals (connected via brass strap jumpers)
DIMENSIONS:
19" (48.3cm) x 9.25" (23.5cm) x 10.8" (27.4cm)
WEIGHT:
24 lbs. (10.9kg)
FINISHES:
Black Ash, Light Cherry wood-grain vinyl
MOUNTING:
Back panel Keyhole and Threaded Insert
FEATURES:
Internally wired with Bandwidth Balanced™ Monster cable®
YEARS BUILT:
2003 -
a+
