KLIPSCH KSW12 vendu 480 € prix neuf 699 € chez :
http://www.son-video.com/Rayons/HomeCin ... ipsch.html
doc du site http://www.klipsch.com :
FREQUENCY RESPONSE:
26Hz-100Hz±3dB
MAX ACOUSTIC OUTPUT:
113dB SPL 1/8 space, 1 meter
ENCLOSURE TYPE:
Bass reflex via rear-mounted port
SPEC TYPE:
12" Bass reflex, tuned port enclsosure
AMPLIFIER:
Class A/B discrete MOSFET outputs
AMPLIFIER POWER:
FTC Rated Power: 105 watts continuous, 22-100Hz @ ≤ 1% THD Dynamic Power*: 440 watts @ ≤ 1% THD *Dynamic power indicates the actual power this amplifier will deliver to the woofer under normal operating conditions. While the FTC power rating indicates power available on a continuous, long-term basis, subwoofers do not rely on that type of power. Instead, the amplifier is called upon to deliver large, short-term peaks of power to be able to support the wide dynamics required by today's digital music and movie formats. In addition to the required FTC power rating, we've provided the dynamic power rating as a better indication of the product's true performance.
AUTO POWER ON:
2 Second ON delay, 15 minute OFF delay
LOW PASS CROSSOVER:
Continuously variable from 40-120Hz, 24dB/octave slope above 120Hz
INPUTS:
2) Line level/LFE RCA phono jacks and 2) High level speaker terminals
OUTPUTS:
2) High level speaker terminals, high pass filtered at 100Hz, 6dB/octave slope
PHASE:
Switchable 0 or 180 degrees
DRIVE COMPONENTS:
Subwoofer system using one 12" (30.5cm) down-firing, fiber-composite cone woofer
WOOFER:
K-1071-K 12" (30.5cm) Fiber-composite cone
DIMENSIONS:
17" (43.18cm) x 15" (38.1cm) x 15" (38.1cm)
WEIGHT:
35 lbs. (15.9kg)
ENCLOSURE MATERIAL:
Medium density fiberboard construction (MDF)
FINISHES:
Matte-finish Black vinyl
VOLTAGE:
110/120 VAC/60Hz
EXPORT VOLTAGE:
230 VAC 50/60Hz
1 message • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: marchel, myridon et 92 invités
"vendu" caisson KLIPSCH KSW12 480 €
- Kouros
- Inscription Forum: 18 Aoû 2003 10:37
1 message
