=Phenix= a écrit:KRAKEN a écrit:Selon vous quel est le meilleur rapport qualité prix ?
le meilleur couple, le plus puissant ?
Je cherche avant tout le meilleur rapport qualité/prix
Tres simple... Si l'on s'en tien a ce que tu demandes
Specifications :
Frequency Response (-3dB) <1.5Hz - >250Khz
Input Impedance 14k Ohms
Input sensitivity (150W into 8 Ohms, 1kHz) 530mV
Tape Output Level (at rated sensitivity) 530mV
Maximum Power Output (One channel driven):
8 Ohms, 1kHz, 1% distortion 200W
4 Ohms, 1kHz, 1% distortion 325W
2 Ohms, 1kHz, 1% distortion (note 1) 480W
Maximum Power Output (Both channels driven):
8 Ohms, 1kHz, 1% distortion 175W
4 Ohms, 1kHz, 1% distortion 300W
2 Ohms, 1kHz, 1% distortion (note 1) 420W
S+N/N Ratio Unweighted 96dB
S+N/N Ratio IEC “A” 112dB
Absolute Phase +VE
Distortion (T.H.D., 1kHz, -1dB below full power):
8 Ohms <0.002%
4 Ohms <0.002%
AC Mains supply (factory pre-set) 110v-120v, 220v-240v
AC Mains consumption 1000W max.
Dimensions (W X D x H) 315 x 350 x 95mm
Shipping dimensions (W X D X H) 400 x 440 x 170mm
Gross weight 12.8Kg
In a head to head against amplifiers from Primare, Moon and Orelle, the AVI Laboratory Series Amplifier was the winner for it’s excellent detail resolution, impressive power and dynamics and solid build, and was the only product to be awarded five stars.
Here are a few highlights from the review:
“great-sounding amp that will work well in a wide range of systems”
“Excellent detail resolution; impressive power and dynamics; solid build”
“fabulous amplifier that doesn’t put a foot wrong. It combines muscle with subtlety beautifully.”
A bon entendeur
