3 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: cherry2809, DOLBY ONE, EBICHUBOY, Horus, MAD71300, nodotpic, NOSIC, Pochon 74, themouloud, zeze34 et 199 invités
yamaha rxv1500vs rxv2500
bonjour, j'aimerais connaitre les differences entre ces deux amplis, surtout au niveau des memoires ypao et de l'equalisation parametrique, merci pour vos observations ... ah j'oubliais qu'est ce que la fonction" Home recall " et le 1500 en beneficie-t il?
- pouille
- Inscription Forum: 15 Fév 2003 9:12
salut
ci dessous, une compar. des 2 trouvé par grubert, en anglais
j'ai deja posté un sujet qui pose la meme question que toi (faait une recherche sur mon pseudo, sinon il y a le topic du 1500 où l'on trouve aussi des infos sur le 2500)
The RX-V2500 has full control over the parametric EQ, meaning you can manually adjust the frequency and Q factor for each band as well as the gain. It also displays the resulting curve very nicely on screen, giving you a graphical representation. The way they designed the menus for adjusting the PEQ could have been better though.
There are also other differences to manual setup, where the 2500 does not have the same simple "Basic setup" menu as the 1500, but leaves you only able to adjust the actual underlying settings (speaker levels, distances, etc.) directly. That does not mean there are things you can control on the 1500 but not on the 2500, it just means you can't start out with a general profile such as "Small" or "Large" room on the 2500.
However, you can store up to 6 system settings in memory, of which two can be recalled directly from the remote. These store pretty much all settings made. You can also recall the last measurements made by YPAO independently of each other (wiring, distance, size, equalizing, levels).
As for the DAC's, I'm still inclined to believe they're the same as in the 1500, but then again I haven't cracked it open to have a look ...yet.
The extra DSP modes are:
HALL: Munich A
CHURCH: Freiburg
CLASSICAL/OPERA
The 2500 also has a backlit remote control, which is so-so considering you can't read the labeling next to the buttons anyway.
Last but not least, the input selector on the 2500 is metal instead of plastic.
HALL: Munich A
CHURCH: Freiburg
CLASSICAL/OPERA
- gorke
- Inscription Forum: 07 Fév 2004 17:20
merci gorke mais moi et l'anglais heu ...
- pouille
3 messages
