Effectivement, pour le son, ça sera difficile d'aller faire une écoute en Chine, mais alors, quelle gueule d'amour !
Si le ramage se rapporte au plumage, ça peut-être quelque chose...
J'ai envoyé une demande de tarif à Tim, on va bien voir ...
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Brindav, cancionero, guss 33, Hp3esr, Noisfra, viazac et 178 invités
Nouvel ampli HdG Shengya A201
- averell
- Inscription Forum: 05 Jan 2002 2:00
en vrac - traduction des caracteristiques par systran.
ca a l air interessant...
Technical parameter: 1. Output response: 10Hz-20kHz? 0.5dB 2. Armor
class output: 20Wx2 (8W) 3. Output: 200W □(8W), 400Wx2 (4W) 4. Input
sensitivity: 300mV5. Harmonic distortion: <= 0.1% (1kHz 1W) 6. Signal
to noise ratio: 90dB7. Input impedance 47kW 8. Volume: (W □□) 446
mm □16 mm □20 mm 9. Weight: Kg A-201 high-level merge type entire
balanced amplifier design thought and characteristic
The A-201 amplifier has been represents the our company for
many years the development design experience and the manufacturing
capacity synthesis performance which puts to the transistor merit.
Used the entire balance which on the international multitudinous
high-level acoustic product manufacturer and the fan approved to
enlarge the electric circuit, the acoustic fidelity, the timbre, the
sound field performance reaches to the degree which reached the
pinnacle. The first level enlarges the partial cores for to accumulate
many years experience to develop the development the high speed DC
enlargement module chip, it prominently displays in the broad
frequency response, the extremely low degree of distortion, the
slender thick timbre, moreover dynamic vast is active, surmounting
multitudinous so-called high-level sound IC as well as discrete
component acoustic fidelity performance. This machine in order to
reduce the dynamic crosstalk disturbance, machine in for 双单 the
sound track design, two sound tracks is completely independent,
machine in lays aside two 500W belt shielded box the ring transformer,
the entire transformer fills by the epoxy resin, the vibration noise
jamming which effectively reduces the transformer works when produces,
each sound track use filter electric capacity aggregate capacity
reaches as high as 60000 微法, 16 high efficiency transistors
composes the formidable output stage, coordinates the giant aluminum
alloy radiator, sound field localization, sound track degree of
dissociation, sound performance and so on clarity is had the enormous
enhancement. In order to coordinate this machine side to the
performance, machine in uses the filter electrolytic capacitor is the
FOR AUDIO import specification, the MKP sound special-purpose thin
film 无极 electric capacity, 1% high accuracy metallized film
resistor, 并联式 precise voltage-stabilized source. Latter level
signal input the electric circuit to be composed altogether the source
altogether grid difference by the field effect tube to enlarge, 名品
the transistor makes the second grading to divide the voltage
amplification and the electric current actuation. Below 20W outputs
when for the armor class condition work, is bigger than when 20W
automatically transfers the armor second grade class condition, causes
the timbre when the low power exquisite Run is thick, when high
efficiency powerfully pulls out potential of the mountains and rivers.
A-201 introduced the CPU entire function to hold controls with the
data message screen display mode, caused high-level HIFI to enter the
epoch-making digital science and technology domain, in order to let an
amateur more convenient use this machine, especially has established
the infrared entire function external guidance system, realized the
entire data message exchange man-machine dialogue to hold controls the
effect. The outward appearance designs the outward appearance design
which the A-201 merit puts to manifest the product connotation the
main objective, held has abandoned the American high efficiency
amplifier monotonous rough style, adopts mutual function technique
which the overall modelling and the detail engraved delimits front,
after enable it to have the level strength symbol also to have the
level to hold controls the charm, after has solved the high efficiency
merge machine modelling the level stereotypical difficult problem.
Detail rich elegant, each detail all is from in to outside, from big
to slightly grows comes, the nature is splendid but is not artificial.
Boldly uses the black in now in a silvers installing equipment world
among, and decorates by the few aluminum metal true colors part, thus
not only strengthened the visual impact, caused that black to have the
unprecedented charm, steady aggressive, the whole and the detail pass
deducts extremely splendidly, wonderful, is extremely worth looking
at, in the makings was revealing the eternal.
- Gilles92
- Inscription Forum: 17 Mar 2003 8:41
Re-traduit en francais
L'amplificateur A-201 a été représente la notre compagnie pendant beaucoup d'années l'expérience de conception de développement et l'exécution de synthèse de capacité de production de production qui met au mérite de transistor. A employé l'équilibre entier qui sur le fabricant acoustique à niveau élevé multitudinous international de produit et le ventilateur a approuvé pour agrandir le circuit électrique, la fidélité acoustique, le timbre, les extensions saines d'exécution de champ au degré qui a atteint le pinacle. Le premier niveau agrandit les noyaux partiels pour pour accumuler l'expérience de beaucoup d'années pour développer le développement le morceau à grande vitesse de module d'agrandissement de C.c, il montre en évidence dans la large réponse en fr3quence, le degré de déformation extrêmement bas, le timbre épais mince, d'ailleurs vaste dynamique est en activité, surmontant le prétendu IC sain à niveau élevé multitudinous aussi bien que l'exécution acoustique composante discrète de fidélité. Cette machine afin de réduire la perturbation dynamique d'interférence, machine dedans pour?? la conception de voie saine, deux voies saines est complètement indépendante, machine dans les configurations de côté la boîte deux 500W protégée par ceinture le transformateur d'anneau, les suffisances entières de transformateur par la résine époxyde, bloquer de bruit de vibration qui réduit efficacement les travaux de transformateur quand produit, chaque filtre d'utilisation de voie saine la capacité qu'électrique d'agrégat de capacité atteint aussi haut que 60000??, 16 transistors de rendement élevé compose l'étape formidable de rendement, coordonne le radiateur géant d'alliage d'aluminium, localisation saine de champ, degré de voie saine de dissociation, exécution saine et ainsi de suite la clarté est eus l'énorme perfectionnement. Afin de coordonner ce côté de machine à l'exécution, la machine utilise dedans le filtre le condensateur qu'électrolytique est AVEC des spécifications AUDIO d'importation, la couche mince pour un but particulier saine de MKP?? la capacité électrique, exactitude élevée de 1% a métallisé la résistance de film??? précisez la source tension-stabilisée. Dernière entrée de signal de niveau le circuit électrique à se composer tout à fait la différence de grille de source tout à fait par le tube d'effet de champ à agrandir?? le transistor fait la deuxième évaluation pour diviser l'amplification de tension et la mise en action courante électrique. Au-dessous des sorties 20W lorsque pour le travail de condition de classe d'armure, est plus grand que quand 20W transfère automatiquement la condition de classe de catégorie d'armure deuxièmes, cause le timbre quand la course exquise de basse puissance est épaisse, quand le rendement élevé retire puissant le potentiel des montagnes et des fleuves. A-201 a présenté la fonction entière d'unité centrale de traitement aux commandes de prise avec le mode d'affichage d'écran de message de données, causé DE HAUTE FIDÉLITÉ à niveau élevé pour écrire la science numérique defabrication et le domaine de technologie, a laissé une utilisation plus commode d'amateur cette machine, particulièrement a établi le système externe de conseils de fonction entière infrarouge, réalisé le dialogue homme-machine de données d'échange entier de message aux commandes de prise l'effet. L'aspect extérieur conçoit la conception extérieure d'aspect que le mérite A-201 met pour manifester la connotation de produit l'objectif principal, tenue a abandonné le modèle approximatif monotone d'amplificateur américain de rendement élevé, adopte la technique mutuelle de fonction que la combinaison modelant et le détail gravé délimite l'avant, après que permettiez-lui d'avoir le symbole de niveau de force également pour avoir le niveau aux commandes de prise le charme, après a résolu la machine de fusion de rendement élevé modelant le problème difficile stéréotypé de niveau. Détaillez élégant riche, chaque détail que tout est de dedans à dehors, de grand se développe légèrement vient, la nature est splendide mais n'est pas artificiel. Emploie hardiment le noir dedans maintenant dans a argente installer le monde d'équipement parmi, et la décore par le quelque métal en aluminium les couleurs que vraies pièce, ainsi non seulement renforcé l'impact visuel, causé ce noir avoir le charme sans précédent, agressif régulier, le tout et le passage de détail le déduit extrêmement magnifiquement, merveilleux, est extrêmement intéressant regarder, dans les makings indiquait l'éternel.
- averell
c'est vrai qu'il a de la gueule cet ampli
- axe666
- Inscription Forum: 12 Avr 2003 20:21
Par contre pas de nouvelles de Tim concernant un prix, je vous tiens au courant dès que news ...
- radinan
- Inscription Forum: 04 Aoû 2003 1:36
Mon pauvre Radinan, depuis que je suis parti, tu t'interesse vraiment à n'importe quoi
Perso, je le trouve pas beau cet ampli, mais bon il doit marcher, enfin j'espère
- eric the king
- Inscription Forum: 09 Sep 2004 23:50
Personnellement, j'adore la p'tite bouille un peu crétine que forment les potards (yeux exorbités), le bouton blanc (nez) et l'affichage digital (bouche grande ouverte).
Rien que pour cela, cet ampli mérite l'achat... ou pas.
- Silvio
- Inscription Forum: 20 Aoû 2004 17:22
23 messages
• Page 2 sur 2 • 1, 2
