54 messages • Accèder à une page • 1, 2, 3, 4
Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 192 invités
Achat d'un Plasma besoin de conseil de pro !! :D
chez pioneer personne n'a acces aux dalles "pro" désolé
- Mario35
- Inscription Forum: 16 Juin 2002 15:00
Mario35 a écrit:chez pioneer personne n'a acces aux dalles "pro" désolé
re desoler pour toi ,mais il sont en vente regarde sur leur site
et sa cet quoi
Ecran Plasma professionnel 61 pouces
This display introduces Pioneer's exclusive PURE Drive digital imaging processing engine to professional users. Unprecedented brightness levels combine with the strongest contrasts and over a billion colours for exceptionally vivid, clear and sharp images. Designed and built to meet the particular demands of professional users, Pioneer's displays are used worldwide by airports, train stations, retailers, trade shows and advertisers. They are also highly effective as corporate presentation tools. Pioneer plasma displays: Uncompromising performance for the high quality presentation of images and data.
Points Forts PDP-61MXE1
Industry leading brightness levels
High contrast (even in bright environments)
Pioneer's unique Deep Encased Cell structure
Exclusive PURE Drive digital technology providing improved image quality and the lowest power consumption levels in the industry
Compatible with a wide range of PC signals
High reliability and durability
Enhanced multi language GUI greatly improves ease of use
Wide range of installation options and features
Multiple standard connectivity options for PC
Two unique open architecture expansion slots
A vast array of new professional features
Caractéristiques générales PDP-61MXE1
Taille réelle de l'image (L x H) 1351 x 760 mm (61 -inch Diag.)
Format de l'image 16:9
Résolution native (Hor x Ver) 1365 x 768
Taille des pixels 0,99 mm (Hor/RGB trio) x 0,99 mm (Ver)
Palette de couleurs 1024 gray scale, 1.07 billion colors
Luminosité 1000 cd/m² (White Peak)
Taux de contraste 1100:1 (dark environment)
Blindage magnétique Oui
Dimensions (L x H x P) 1450 x 880 x 119 mm (not including handles)
Poids 61 kg
Consommation électrique 540 W (0.9 W at stand by)
Alimentation électrique AC 100 ~240 V ±10 %, 50/60 Hz
Température de fonctionnement 0 °C ~ 40 °C
Hygrométrie de fonctionnement 20 % ~ 80 %
Pression atmosphérique 0,76 ~1,1 atmospheric pressure
Normes de conformité CE (EN 60950, EN 55022 class B, EN 55024, EN61000-3-2, EN61000-3-3),IEC60950-1,C -Tick (AS/NZS CISPR22 class B)
Compatibilité signal vidéo 3,58NTSC, 4,43NTSC, PAL, PAL M, PAL 60, SECAM (PDA-5003/PDA-5004)
Caractéristiques PDP-61MXE1
DRIVE Technology Exclusive Pure Drive Digital Technology
Super Clear drive
Pure Colour Filter II
CIE Chromativity Coordinates
Brightness / Contrast
DNR and MPEG Noise Reduction
Natural Enhancer
IP Conversion
Digital Flicker Free System
Natural Resize
Y/C Separator
CTI Circuit and 10 bit Digital Chroma Decoder
Pure Cinema mode
Clear Drive Super Clear Drive
Compatibilité de signaux numériques Oui
Fonctions de protection de l'écran Orbiter mode, Inverse mode, Full mask, Still picture detection, Brightness difference detection
Accessoires inclus Cleaning cloth, 2x Speed clamp, 2x Bead band, Remote control Unit, 2x AA(R6) Battery, 2x Hex hole bolt(M8x40), 2x Washer, CD-ROM, 2x Display stand, Remote control unit case
Entrées Video PDP-61MXE1
Entrée vidéo 1 Mini D-sub 15 -pin, RGB signal (G on Sync compatible)
Entrée vidéo 2 DVI-D 24-pin Digital RGB signal (DVI compliant TMDS)
Entrée PC 3 (avec carte vidéo optionnelle) BNC x 5 RGB signal (G on Sync compatible)
Entrées et Sorties Audio PDP-61MXE1
Entrée audio Stereo Mini
Sortie audio Stereo Mini
Speaker output x 2 (L/R) Oui
Caractéristiques d'installation et fonctionnement PDP-61MXE1
Caractéristiques professionnelles Intelligent Auto Setup
Point Zoom
Colour Detail Adjustment
Energy Save Modes
Multi Language OSD
Layered Keylock
LED OFF Mode
Smart Cooling System
Screen Management Timer Feature
Integrator Menu
RS-232C Features
FRC Feature
Broadcast Modes
Incrustation d'images Split-Screen
Picture-in-Picture: Small picture can be moved to any of the four corners.
Picture-out-Picture: Larger image is true XGA.
Interface RS-232C Oui
Combinaison entrée/sortie Oui
Mode 2x2 Oui
Fonctions moniteur Oui
Slot d'expansion 2 (Video and Communication slot)
et tu as aussi les 42 et 50 en plusieurs version .
- video man
- Inscription Forum: 18 Nov 2003 10:08
sur leur site mais chez les commerciaux pioneer c'est autre chose. re-désolé (j'ai posé la question cet après midi)
- Mario35
totti33 a écrit:Salut ,
C'est vrai que le pack que tu a choisi a l'air vraiment sympas , mais moi je ne pe pas aller jusque la niveau budget , plustard je l espére
mais l ' amplis a l air par contre vraiment top Sherwood R863R Noir , mais bon y a t'il vraiment une grosse différence entre celui la et le Marantz SR5500 Silver ?
Par contre pour les enceintes je suis toujour dans le flou, je ne sais pas quoi prendre je pe mettre un peu plus de 300€
Si tu peux t'offrir un Sherwood, il n'y a plus d'hésitations possible! fonnnncccceeee!!!!
- 360modena22
- Inscription Forum: 20 Avr 2005 12:51
Mario35 a écrit:sur leur site mais chez les commerciaux pioneer c'est autre chose. re-désolé (j'ai posé la question cet après midi)
re
bon moi les commerciaux je ment tappe si tu en veux un ,moi mon revendeur il te le commande,donc ou ton commercial est une pipe et il y a na malheuresement beaucoup dans toute les marques de plus j'ais telephoner se soir a pio ,pour savoir le fin mot et il me dise aucun probleme pour avoir ses ecrants le seul probleme pour le moment cet d'avoir la gamme elite qui est dispo au usa
re desoler,pour toi,je suis pas un pro,mais un tres bon clients chez pio,donc je sais pas comment mon revendeur peux avoir se style d'ecrant,d'ailleur le 43 tourne en prix a peux pres a 4500 euro et on peux le toucher facille a 3500 a 4000 euro.
dom
- video man
video man a écrit:Mario35 a écrit:sur leur site mais chez les commerciaux pioneer c'est autre chose. re-désolé (j'ai posé la question cet après midi)
re
dom
Je rêve, un espagnol !
CooL moi je suis sur Barcelone en plein quartier Video - PC et je ne vais pas tarder à craquer, je passe tous les jours devant les boutiques spécialisées.
- Parsifal
- Inscription Forum: 25 Mai 2002 22:41
j'ai une question de bloulet : qu'elle est la différence entre les dalles pro et les dalles grands publics???
- 360modena22
360modena22 a écrit:j'ai une question de bloulet : qu'elle est la différence entre les dalles pro et les dalles grands publics???
bonjour
ben deja tu peux atapter pusieurs graphique differente,il ny a pas de tuner.
dom
- video man
video man a écrit:360modena22 a écrit:j'ai une question de bloulet : qu'elle est la différence entre les dalles pro et les dalles grands publics???
bonjour
dom
Peux-tu rentrer un peu plus dans les détails stp
quel interet de ne pas avoir de tuner ?
les cartes graphiques???
- 360modena22
54 messages
• Page 4 sur 4 • 1, 2, 3, 4
