Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: benjamin4664, Cyril010101, Espresso, Kubala, Sergiot92 et 112 invités
Ampli et DAC à 120€...merci la Chine !
Message » 02 Mai 2006 21:48
Je viens de commander le couple :
L'ampli numérique
Type: Digital Amp
Brand: Trends Audio
Spec. (Amp Unit):
T-Amp Chip: Tripath TA2024
Output Level:
- 2 x 15W @ 4ohm
- 2 x 10W @ 8ohm
Signal-to-Noise (SNR): 98dB
Dynamic Range: 98dB
THD+Noise - "Audiophile" Quality
- 0.03% @ 9W, 4ohm
- 0.1% @ 11W 4ohm
- 0.1% @ 6W 8ohm
- High Power
- 10% @ 15W 4ohm
- 10% @ 10W 8ohm
Power Efficiency: - 81% @ 15W, 4ohm
- 90% @ 10W, 8ohm Power Socket: 5.5mm/2.1mm
Input Socket: RCA Audio IN (Left/Right) x 1 pair
Output Socket:
- Speaker OUT (Left) x 1 pair (+/-)
- Speaker OUT (Right) x 1 pair (+/-)
Other Switch & Knob:
- Power ON/OFF switch x 1
- LED power indicator x 1 (blue)
- Volume knob x 1
Power Supply: DC 12V~13.2V(max.)
Dimensions: 76mm(W) x 46mm(H) x 114mm / 150mm[incl. sockets & knob](D)
Weight: 500g
Spec. (Power Unit):
Power mode: Switching Power
AC Input Voltage: Universal AC 100V-240V / 50~60Hz
DC Output Voltage: DC 12V / 3A (36W)
Ripple & Noise: <=50mV
Dimensions: 123mm(L) x 50mm(W) x 30mm(H)
Weight: 300g
Accessories:
- 3 legs Power Cord x1 (IEC plug and another plug with different country standards available)
- User Guide x 1
- Warranty Card x 1
Et le DAC :
Type: D/A Convertor
Brand: Trends Audio
Specifications:
Receiver Chip: Cirrus Logic CS8414
D/A Chip Analog Devices AD1852 (24Bit/192kHz)
Analog Op-Amp: Burr Brown OPA2604
S/N Ratio 120dB
THD: 102dB
Dynamic Range: 117dB
Frequence Response: 20Hz-22kHz(¡Ó0.5dB)
Output Level: 2V
Input Ports: Optical (Digital) IN x 1
- Coaxial (Digital) IN x 1
- RCA (Analog) IN x 1
Output Ports: RCA (Analog) OUT x 1
- 6.3mm Headphone OUT - Left/Right Balanced (XLR) OUT Power Source: AC~220V/50Hz ¡Ó 10% Dimensions: 260mm(L) x 240mm(W) x 42mm(H)
Weight: 3kg
Accessories: Power Cord x 1
- Choseal Optical Cable x 1
- User Guide x 1
- Warranty Card x 1
j'ai omis de parler des 40€ de port (ils livrent via DHL), et peut-être la douane, donc disons au pire 200€.
Evidemment il faut écouter, si ça se trouve c'est totalement nul.
Mais mon petit doigt me dit que mon intégré Thule (HC) va pas forcément en ressortir grandit. :)
Mon CR dès réception, sur mes Acoustec (enceintes américano-chinoises à 250€ la paire, décidément), ou bien sur des enceintes plus difficiles si un curieux veut essayer sur Paris avec de "vraies" enceintes.
Les chinois n'ont décidément pas les même valeurs. 8)
Austin
Inscription Forum: 08 Oct 2000 2:00
Message » 02 Mai 2006 22:26
C'est du 230V/50Hz en Chine ?
doudou_78
Inscription Forum: 04 Avr 2005 20:50
Message » 03 Mai 2006 7:36
Encore un pionnier de matos chinois ésotéerique?! :roll: :D :wink:
Tiens-nous au courant... :wink:
teiki arii
Inscription Forum: 19 Aoû 2004 19:24
Message » 03 Mai 2006 9:38
+1. Très curieux de lire ton CR pour savoir ce que ça vaut. :lol:
Jean-Michel.F.
Inscription Forum: 19 Fév 2006 18:46
Message » 03 Mai 2006 9:43
doudou_78 a écrit:C'est du 230V/50Hz en Chine ?
Pas exactement. Ce serait plutôt du 210 à 220v/50Hz. Ce qui implique que l'on doit prendre des précautions avec ce matériel (voir les explications d'Audréal sur les modifications qu'ils apportent aux électroniques pour fiabiliser les alimentations de leurs matériels fabriqués par Xindak). Les matériels chinois ne supportent absolument pas les "excursions" survoltées vers le 240 volts. Il est donc prudent de prévoir un régulateur en amont. Problème : trouver un appareil de ce type qui ne tasse pas la dynamique en bridant le courant. Là, je laisse la parole aux experts en courant du forum (j'aimerais avoir notamment l'avis de FDRT) :idee:
Jean-Michel.F.
Message » 03 Mai 2006 10:02
Austin,
vu que tu m'avais conseillé cet achat en attendant l'acquisition de mon ampli à tubes, te voilà condamné à venir l'écouter sur mes Prame HR2. :wink:
radinan
Inscription Forum: 04 Aoû 2003 1:36
Message » 03 Mai 2006 10:45
radinan a écrit:Austin,
Et.. :roll:
teiki arii
Message » 03 Mai 2006 11:13
j'attend avec impatience ton c r sur le petit ampli numérique,
concernant le dac j'ai eu le plaisir de l'avoir récemment et bien il est vraiment bon et surpasse bien des platines intégrée!
félécitation pour cet achat malin qui ouvrira les portes a beaucoup d'entre nous qui n'avions pas les moyens d'investir ds des marques occidentales et japonaises.
short
Inscription Forum: 14 Déc 2002 17:21
Message » 03 Mai 2006 11:14
En même temps l'ampli est sur 12v donc un transfo à la con fera l'affaire.
Par contre le dac j'ai pas fait gaffe.
Interessant en tout cas un dac de ce prix.
Kro
Message » 03 Mai 2006 12:30
Et.. :roll:
Tu peux préciser ? :-? Si tu as quelque chose à dire, dis-le ...
radinan
Message » 03 Mai 2006 12:47
Et.. :roll:
Et bien, que cela donne-t-il? :wink:
teiki arii
Message » 03 Mai 2006 14:40
teiki arii a écrit:
Et.. :roll:
Et bien on va bien voir :wink: je suis toujours prêt à tester les associations les plus improbables... Je voudrais bien tester ce petit numérique dans la mesure où , si ça marche pas trop mal, je me verrais bien en acheter un comme sécurité si un soir un tube claque...
radinan
Message » 03 Mai 2006 15:48
radinan a écrit:Et bien on va bien voir :wink: je suis toujours prêt à tester les associations les plus improbables... Je voudrais bien tester ce petit numérique dans la mesure où , si ça marche pas trop mal, je me verrais bien en acheter un comme sécurité si un soir un tube claque...
Surtout qu'avec des HR2, les Watts sont moins précieux qu'avec des enceintes à faible rendement.
Ca me parait aussi être une solution Bis idéale, ou pour deuxième installation.
Si tu le souhaites, je te contact quand j'ai reçu le tout.
Austin
Message » 03 Mai 2006 16:12
L'ampli c'est un t-amp, on a déjà quelques infos sur ce type de matériel par contre pour le DAC c'est du nouveau pour moi, c'est rare à bas prix il me semble.
C'est le convertisseur des MICROMEGA Minium CD, si c'est bien mis en oeuvre ça peut être sympa.
angus2
Inscription Forum: 09 Déc 2003 14:18
Message » 03 Mai 2006 16:32
Moi c'est le converto que je trouve le plus interessant... :wink:
A combien il est le converto tt seul ?
Kro
