Salut à tous,
Je me demande dans quel cas est utilisé et à quoi sert ce filtre installé dans le package Purevideo. Il n'a aucune propriété accessible.
Peut on réaliser un graph qui l'utiliserait?
4 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: cd, Emmanuel Piat et 119 invités
Filtre "post process" du codec Purevideo???
- trifon
- Inscription Forum: 22 Aoû 2003 14:59
En anglais :
What is Post Processing with NVPP and do I need it?
This is the nVidia Post Processor supplied with TheaterTek that is capable of handling 3:2 pulldown detection on the video frames themselves rather than relying on the flags that are part of the DVD encoding itself. Why should I care? You'd actually be surprised just how many DVD's are badly mastered with incorrect flags specifying video content when the material is actually film based and vice versa. What's more, these flags appear all over a DVD and are often incorrect in-between chapters, or sometimes the whole DVD.
Choosing this option in the Post Processing section will turn this feature on, but will also force the decoder into software mode, as the NVPP cannot be used with DXVA acceleration turned on.
Who should NOT use it? nVidia built the capability of the NVPP into their latest graphics cards so this is not needed if you use certain nVidia cards. A full list is on the nVidia website, but essentially, 6200, 6600, 6800, and 7800 cards have this feature built into hardware. If you have one of these cards, to enable this feature you should turn on the following: DXVA, Smart mode de-interlacing, and Allow subtitle movement.
Je ne pense pas que cela ns apporte grand chose!
- lordkiller0808
- Inscription Forum: 22 Avr 2005 14:54
Je pense que l'on configure ce filtre via les options dans le Panel control ... mais c'est plus que flou tout ça ... lol
[Edit] Quand on decode via Pure vidéo, ce filtre est il ajouté automatiquement au graph ?!
- Seb.26
- Inscription Forum: 04 Mar 2004 16:43
Pr ma part, j'avais fais un test avec dvbviewer nvpp + nvidia decoder et j'ai vu aucune différence de fluidité etc... comparé au nvidia decoder seul.
D'ailleurs, je préfère désormais dscaleur seul et son algo de désentrelacement qui rend vraiment l'image très fluide au détriment d'un aliasing plus prononcé que nvidia.
Donc en dvb tout ça!
Ah oui sinon j'ai une ati comme carte peut être que ce filtre est exploitable qu'avec une nvidia!!
- lordkiller0808
4 messages
