Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: AlainParis, alexins, alligator-427, bab1c, Berlinois, Bing [Bot], DrHouse, Freemanjazz, gwendal55, jcre17, ludo3159, midoe, misichavichus, Pilou57, PlaTiNe-38, portenawak, rezoli, sierra1959, silvain24, Singha29, skwat, tony51, trekSL8, videoman, Zell555, Zinkins et 185 invités
TVIX 5100 HDMI + H.264 + MKV
Nouveau firmware beta: 1.038
ftp://ftp.dvico.com/Products/TViX/Firmw ... 1.0.38.zip
Firmware Ver. 1.0.38
- Fix a bug the repeat is not set when Autorun repeat.
- Fix a bug the system crash when there is no file on the autorun and autorun is set.
- Some WVC1 in WMV file is supported.
- MOD and TOD extensions are added for video playing.
- TV Out has changed
HDMI : Try EDID, if fails, it will set to standard 480P and audio is enabled
If you set to component mode, HDMI will not work.
When user press TV Out key on the remote it will rotate as below.
NTSC -> 480P -> PAL -> 576P -> EDID
- If you set Video output to HDMI, the Audio output will be reset to all PCM.
This is due to most TV cannot decodes all types of audio codec.
- Improved stability when playing picture files.
- Fix a bug Remote type is not reset when the factory default is loaded.
- Fix a bug DVI mark on VFD is on when TV out type is Component.
- Add more information for network settings
- Other minor fix including Typo
- Dutch OSD is added, but currently the messages are in French.
We are working on this, next firmware will have complete Dutch OSD messages.
- piflechien
- Inscription Forum: 25 Déc 2006 20:47
Le h264 est bien supporté par le tvix mais pas par le tuner.
Le tuner utilise un composant qui ne connais que le mpg.
En fait ma compréhension pour faire simple est que le tuner est un tuner tnt équivalent à ce que l'on trouve dans les tuners usb pour pc. Il n'est pas prévu pour le h264.
Pour faire le h264 il faudrait que le flux en sortie du composant tuner soit accessible au tvix ce qui ne me semble pas le cas. Cela s'explique probablement par la complexité qu'il y aurait a demultiplexer et gérer les données par logiciel dans le tvix qui n'a pas la puissance nécessaire.
Ce travail est confié à des composants qui dans le cas du tuner ne gere que le mpg.
- aqerty
- Inscription Forum: 10 Oct 2003 12:05
Pourtant hier en zappant même si je n'ai pas pu voir la chaine HD à l'écran, quand j'ai enregistré et lu avec VLC player il y avait bien un flux visible resolution HD. C'était l'étape du tour de france F2F3 et malheureusement il y avait pas mal de coupures.
C'est peut être aussi parce que je capte mal à l'endroit ou je suis.
Donc le flux peut être décodé et enregistré mais apparement la partie logiciel n'est pas au point.
C'est peut être aussi une limitation de la puissance du TVIX qui n'arrive pas à enregistrer un flux HD.
Peut être qu'un nouveau firmware arrangera ça.
- dreamy
- Inscription Forum: 08 Nov 2004 0:07
intéressant peux-tu voir dans vlc la résolution et le format de la vidéo ?
Si le flux arrive jusqu'au tvix c'est une bonne nouvelle.
- aqerty
aqerty a écrit:intéressant peux-tu voir dans vlc la résolution et le format de la vidéo ?
j'ai enregistré un bout de F2F3HD sur mon tvix.
Media player classic me dit ça :
Video size : 1904 x 1080
Video: MPEG4 Video (H264) 1440x1088 [Video]
Audio: MPEG Audio 48000Hz stereo 192Kbps [Audio]
je'ignore pourquoi j'ai 2 informations différentes sur la taille de la vidéo
voili voilo.
- JessOVR
- Inscription Forum: 25 Juin 2007 14:50
Pour ma part les fichiers sont avec l'extension *.tp chaine 50 TEST HD1
TVIX avec firmware tvix_M-x100_1.0.38.fwp
et voici les détails du fichier
Subtitle: DVD Subpicture [Subtitle]
En téléchargement ici pour vous faire une idée.
Le Fichier est lu par VLC player avec des saccades. Avec media player classic cela ne fonctionne pas chez moi
Sur le TVIX en mode fichier c'est fluide et en HD
Attendons donc le prochain firmware pour voir en live la TNT HD.
- dreamy
dreamy a écrit:Pour ma part les fichiers sont avec l'extension *.tp chaine 50 TEST HD1
Sur le TVIX en mode fichier c'est fluide et en HD .
tout pareil, sauf que ça marche mieux avec media player classic qu'avec vlc chez moi. Va comprendre, Charles...
Mais ça reste tout de même saccadé tandis que c'est NiCr sur le tvix.
- JessOVR
aqerty a écrit:Le h264 est bien supporté par le tvix mais pas par le tuner.
Bonjour aquerty,
En fait c'est normal. Le flux de transport est toujours le même : du mpeg ts.
Peut importe qu'il contienne du mpeg2 ou du h264 (qui soit dit en passant n'est, en vidéo, qu'une évolution du mpeg2, pas une norme totalement différente)
Il n'y a donc rien d'étonnant à trouver des circuits estampillés mpeg dans le tuner.
- baloub
- Inscription Forum: 25 Déc 2004 19:41
Chez moi, c'est aussi MPC qui le lit le mieux (il utilise coreavc pour décoder le h264). Ca reste saccadé et on voit l'entrelacement.
Sur le tvix c'est nickel.
Si j'ai tout suivit, tu as enregistré "en aveugle" sur le tvix ?
Si c'est ça un petit message à dvico peut faire bouger les choses...
- baloub
baloub a écrit:Chez moi, c'est aussi MPC qui le lit le mieux (il utilise coreavc pour décoder le h264). Ca reste saccadé et on voit l'entrelacement.
perso j'ai enregistré en aveugle (mais on a le son en live quand même..)
Heu sinon, j'ai des videos en wma hd dans lesquelles le son est en wma pro que le tvix ne décode pas. Une idée / un moyen pour convertir ces fichiers de sorte d'avoir la bande son sur le tvix ? merci
- JessOVR
merci baloub en effet je n'avais pensé à ça.
- aqerty
Pour info le bug des XVid HD qui plantent lorsque l'on fait un peu de trop de fast forward (généralement à partir de x) ou "jump to" est connu et en cours d'investigation.
- Steefler
- Inscription Forum: 15 Jan 2003 15:45
Sinon le 1.0.38 n'est toujours pas officiellement sortie on peut en conclure qu'il ne s'agit pas encore de la version finale. Donc no panic pour la TNT HD !
- Steefler
Une petite requête pour dreamy ou JessOVR,
vous serait - il possible d'enregistrer un extrait un peu plus long et de le mettre sur un serveur genre megaupload (ou autres) ?
(sur megaupload, la taille max par fichier est de 500Mo)
Par exemple 1mn devrait peser autours de 80Mo...
Par avance, merci.
Par avance, merci.
- baloub
bonjour,
on me soutient sur un autre forum qu'il faut remuxer les mkv en vob pour lire le H264 sur le tvix est ce vrai? merci
- fkl
- Inscription Forum: 12 Oct 2005 15:37
