bonjour pouvez vous me dire quels sont les meilleurs réglages du PDP-508XD aprés rodage (en sachant que j'utilise mon écran pour visioner des chaines hertzienne , des chaines numériques , des DVD , des BLUE RAY , des HD-DVD et des jeux vidéo)?
merçi d'avance
4 messages • Page 1 sur 1
Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 160 invités
Voici les réglages d'un membre d'AVForums. Ils sont très bons, je les ai testés...
Bonne chance.
28th JULY 2007
After a lot af playing to start with these settings will give a good result.
It's still early days so it will be worth looking at this weekly as the settings may change
I will be ISF calibrating the sets but not till I have 500 hours on them. I will not be locking day & night settings as you may want to change them (Gordon does not lock them) just make sure you make note of the calibrated settings.
None of the settings below are gospel and personal preference will come into it. However if you choose to try the advanced settings I suggest you do not change the colour detail and colour management settings, just the stuff in the "picture menu"
There are now 3 sets of settings.
If you are daunted by the number of adjustments just use the first ones to start with.
They are simple and just slightly ammend the out of box settings but MUST be made or things will look overcooked and juddery.
Once the set beds in and you get used to it use the advanced settings.
If you are going to see one in a shop take this with you and ensure that the at least the first settings are used and insist on having the remote unless the sets have been properly set up.
Once you get your set home the pixels will appear lively and the picture may look a bit redy blue, this is normal and will settle within a week.
*******SHOP DEMO/BASIC HOME SETTINGS*********
Leave everything alone except:
PRESS MENU AND SELECT PICTURE MENU
AV SELECTION STANDARD (Have this set for all inputs, it uses the same settings)
CONTRAST 36
BRIGHTNESS 0
COLOUR +4
TINT 0
SHARPNESS -4
********To make sure there is no judder*********
MAIN MENU > PRO ADJUST > PURE CINEMA
FILM MODE OFF
TEXT OPTIMISATION OFF
Menu > Picture > Pro Adjust > Colour Management > Colour Space 2
Menu > Picture > Pro Adjust > Colour Management > Colour Detail Mid-Low
PRESS MENU > OPTIONS >
SCROLL DOWN TO SECOND SCREEN
DRIVE MODE 2
********WHEN YOU GET YOUR SET HOME ONLY*********
BLUE LED DIMMER SET TO WHATEVER YOU FANCY--LOOK AT THE INCORRECT AMUSING DESCRIPTIONS
ORBITER UP TO YOU (MINE IS OFF)
PUSH MENU & SCROLL TO OPTIONS MENU
AUTO SIZE WIDE ZOOM
SIDE MASK
DETECTION ON
BRIGHTNESS SYNC FIXED
IF THE INPUT IS AN HDMI SET TO ENABLE
SIGNAL TYPE VIDEO
VIDEO AUTO
AUDIO AUTO
*******ADVANCED SETTINGS********
**********Freeview, Sky SD, & SD DVD.**************
MENU > PICTURE MENU
AV SELECTION USER
CONTRAST 26 to 34 (mines 32)
BRIGHTNESS 0
COLOUR +4
TINT 0
SHARPNESS -4
FILM MODE OFF
INTELIGENT MODE OFF
PICTURE DETAIL
DRE LOW
BLACK LEVEL OFF
ACL OFF
ENHANCER MODE 2
GAMMA 3
COLOUR DETAIL MANUAL (HOLD ENTER FOR 3 SECS)
COLOUR TEMP
R High 0
G High -2
B High 0
R Low 0
G Low 0
B Low +1
CTI OFF
COLOUR MANAGEMENT
R 0
Y 0
G 0
c -4
B +7
M +8
COLOUR SPACE 2 IMPORTANT
NOISE REDUCTION
Field NR OFF
All others OFF
OTHERS
IP MODE 1
*********SKY HD AND BLUE RAY/HD DVD**********
AV SELECTION USER
CONTRAST 26 to 34 (Mines 34)
BRIGHTNESS 0
COLOUR +2
TINT 0
SHARPNESS -4
FILM MODE OFF (BLUE RAY/HD DVD Smooth or Advanced)
TEXT OPTIMISATION OFF (BLUE RAY/HD DVD ON
INTELIGENT MODE OFF
PICTURE DETAIL
DRE LOW
BLACK LEVEL OFF
ACL OFF
ENHANCER MODE 1
GAMMA 3
COLOUR TEMP
R High +3
G High -1
B High -3
R Low +1
G Low +1
B Low -2
CTI OFF
COLOUR MANAGEMENT
R -1
Y 0
G 0
c -3
B +2
M +3
COLOUR SPACE 2
NOISE REDUCTION
Field NR OFF
All others OFF
OTHERS
IP MODE 1
******NB BLUE RAY OR HD/DVD ONLY********
MENU > OPTIONS MENU > SCROLL TO 2ND SCREEN
Drive Mode 1
THERE YOU HAVE IT ENJOY
ANY ISSUES FEEL FREE TO PM ME
STEVE
Bonne chance.
28th JULY 2007
CONTRAST 36
BRIGHTNESS 0
COLOUR +4
TINT 0
SHARPNESS -4
FILM MODE OFF
DRIVE MODE 2
AUTO SIZE WIDE ZOOM
SIDE MASK
DETECTION ON
SIGNAL TYPE VIDEO
VIDEO AUTO
AUDIO AUTO
MENU > PICTURE MENU
AV SELECTION USER
BRIGHTNESS 0
COLOUR +4
TINT 0
SHARPNESS -4
FILM MODE OFF
INTELIGENT MODE OFF
PICTURE DETAIL
DRE LOW
BLACK LEVEL OFF
ACL OFF
ENHANCER MODE 2
GAMMA 3
COLOUR TEMP
R High 0
G High -2
B High 0
R Low 0
G Low 0
B Low +1
CTI OFF
COLOUR MANAGEMENT
R 0
Y 0
G 0
c -4
B +7
M +8
NOISE REDUCTION
Field NR OFF
All others OFF
OTHERS
IP MODE 1
AV SELECTION USER
BRIGHTNESS 0
COLOUR +2
TINT 0
SHARPNESS -4
INTELIGENT MODE OFF
PICTURE DETAIL
DRE LOW
BLACK LEVEL OFF
ACL OFF
ENHANCER MODE 1
GAMMA 3
COLOUR TEMP
R High +3
G High -1
B High -3
R Low +1
G Low +1
B Low -2
CTI OFF
COLOUR MANAGEMENT
R -1
Y 0
G 0
c -3
B +2
M +3
COLOUR SPACE 2
NOISE REDUCTION
Field NR OFF
All others OFF
OTHERS
IP MODE 1
Drive Mode 1
STEVE
- nonocnonoc
- Membre HCFR Contributeur
- Inscription Forum: 30 Nov 2003 13:20
bonjour auriez vous de bons réglages du PDP-508XD pour une PS3 et XBOX 360 (réglages pour les jeux) ? merci d'avance.
- zarkann
- Inscription Forum: 11 Déc 2006 19:20
nonocnonoc a écrit:Voici les réglages d'un membre d'AVForums. Ils sont très bons, je les ai testés...
Bonne chance.
28th JULY 2007
CONTRAST 36
BRIGHTNESS 0
COLOUR +4
TINT 0
SHARPNESS -4
FILM MODE OFF
DRIVE MODE 2
AUTO SIZE WIDE ZOOM
SIDE MASK
DETECTION ON
SIGNAL TYPE VIDEO
VIDEO AUTO
AUDIO AUTO
MENU > PICTURE MENU
AV SELECTION USER
BRIGHTNESS 0
COLOUR +4
TINT 0
SHARPNESS -4
FILM MODE OFF
INTELIGENT MODE OFF
PICTURE DETAIL
DRE LOW
BLACK LEVEL OFF
ACL OFF
ENHANCER MODE 2
GAMMA 3
COLOUR TEMP
R High 0
G High -2
B High 0
R Low 0
G Low 0
B Low +1
CTI OFF
COLOUR MANAGEMENT
R 0
Y 0
G 0
c -4
B +7
M +8
NOISE REDUCTION
Field NR OFF
All others OFF
OTHERS
IP MODE 1
AV SELECTION USER
BRIGHTNESS 0
COLOUR +2
TINT 0
SHARPNESS -4
INTELIGENT MODE OFF
PICTURE DETAIL
DRE LOW
BLACK LEVEL OFF
ACL OFF
ENHANCER MODE 1
GAMMA 3
COLOUR TEMP
R High +3
G High -1
B High -3
R Low +1
G Low +1
B Low -2
CTI OFF
COLOUR MANAGEMENT
R -1
Y 0
G 0
c -3
B +2
M +3
COLOUR SPACE 2
NOISE REDUCTION
Field NR OFF
All others OFF
OTHERS
IP MODE 1
Drive Mode 1
STEVE
PEUX TU ME TRADUIRE CE POST SVP ET ME DIRE SI IL EST NECESSAIRE DE FAIRE UN RODAGE SUR MON PIO 428 XD ( si oui lequel ?)
MERCI PAR AVANCE
- artagnan
- Inscription Forum: 20 Juil 2007 19:16
4 messages
