En marge de la sortie du Z11 qui va faire énormément parler de lui à mon avis, il y a 3 nouveaux ampli qui sortent chez YAMAHA
Le RX-V3800 à 1800 euro en octobre 2007
Official UK product with a 2 year warranty from Yamaha UK
Dolby TrueHD and DTS-HD Master Audio decoding
THX Ultra 2 Plus certified
HDMI v1.3a for decoding of Dolby TrueHD and DTS-HD
Ethernet port for networking with your home server
Stream audio and internet radio across your home network
Supports DLNA (industry standard for network sharing)
USB Input for connection to MP3 players, USB memory sticks & HDD (Up to 2TB)
Video upconversion and scaling to HDMI 1080p
Anchor Bay Technologies Video Scaler
Support for 1080p 24hz & 120hz
Auto Lip-Sync function that automatically adjusts the lag between video and audio
7 Channel High Power Amplifier Configuration
Burr Brown 192kHz/24-bit DACs for all channels
Assignable Amplifiers for bi-amp connection or Zones 2/3
Wide Frequency Range For DVD-Audio & SACD
DSP Surround Headphone Output (Silent Cinema DSP)
Front AV input with optical in behind hidden panel
Many Surround DSP modes
5.1/7.1 Channel External Decoder Input
4mm Banana Plug Sockets & Phono Connections
Built in RDS FM/AM Tuner
et le RX-V1800 à 1300 euro dispo septembre 2007
YPAO Yamaha Parametric Room Acoustic Optimizer
Microphone based auto calibration
Analog video upconversion and scaling to 1080p over HDMI
Dolby TrueHD & DTS-HD decoding
Burr Brown 192kHz/24-bit DACs for front channels
HDMI 1.3a supporting Deep Colour (30/36bit) transmission
Supports and accepts 1080p/24Hz, 1080p/60Hz and 1080p/120Hz
192kHz/24-bit Analogue to Digital Converter
Custom-made 12,000μF block capacitors
TBC (time base correction) for Component and HDMI outputs
Wide Frequency Range For DVD-Audio and SACD
37 Surround DSP modes
Virtual Cinema DSP mode
Zone 2 and 3 outputs with the ability to switch speakers
Logical On-screen Display with Speaker Test Mode
Pure Direct for all inputs
Main L/R, Centre, Rear L/R, Rear Centre L/R
Gold Plated 4mm Banana Plug Sockets & Phono Connections
Quick-start YPOA Room Optimising EQ
RS-232 Output
GUI on-screen display
Power Output RMS 7x130w (6Ω, 20Hz - 20kHz and 0.06% THD)
Damping Factor ≧140 (8Ω, 20 - 20kHz SPEAKER-A)
Input Sensitivity 200mV/47kohms (Line)
3.5mV/47kohm (Phono MM)
Frequency Characteristics 0/-3dB (10Hz - 100kHz)
Frequency Range 10Hz - 100kHz (0/-3dB)
RIAA Deviation 0±0.5dB 20 - 20kHz (Phono MM)
Total Harmonic Distortion 0.04% (CD line in)
0.02% (PHONO mm)
S/N ratio (EFFECT OFF): ≧100dB (CD line in, 250mV)
≧80dB (5mV and mm)
Channel Separation ≧ 60dB/ ≧ 45dB (1kHz/10kHz) CD
≧ 60dB/ ≧ 55dB (1kHz/10kHz) Phono
Power Source U.K. AC 230v/50Hz 450W
Dimensions Width: 435mm
Height: 171mm
Depth: 438mm
Weight 17.4kg
Source : AVland (http://www.avland.co.uk/index.htm)
Dispo en septembre-octobre[/i]
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: anthony17570, Auric, Delprado, flyingdoherty, giovà, jmkdeb, Julididou, ludo9159, Newjack910, philou008, PILOTO49, pinlelala, smeagol, tony_95 et 167 invités
les pauvres...ils passent deja presque inaperçu a cote du Z11...
a retenir je pense, que le 3800 est quand même aussi certifié THX Ultra 2 Plus. Pour qui n'a pas besoin du 11.2 (sic) ça devrait être une bonne affaire surtout si le prix se confirme être entre ce qu'étaient le 2600 et 2700 à leur sortie.
- hydrosaure
- Inscription Forum: 12 Sep 2005 14:49
Trés interessant, des infos concernant le nombre de sorties HDMI présentes sur chaque modèle?
Concernant le prix du 3800, ça m'étonnerait quand même qu'il soit moins cher qu'un 2700 à sa sortie mais qui sait ça pourrait être une bonne surprise.
- tiboun
- Inscription Forum: 20 Nov 2003 10:29
tiboun a écrit:Trés interessant, des infos concernant le nombre de sorties HDMI présentes sur chaque modèle?
Pour les HDMI c'est 4 en entrées et 1 en sortie
Pardon pour le prix mais c'est plutôt 2100-2200 euro (soit 1400 £, j'avais pas bien lu )
- jat.gab
- Inscription Forum: 11 Juil 2004 12:00
up
alors on eut esperer le 1800 a quel tarif en france ?j'espere qu'a l'ifa il y aura un beau compte rendu
maxime
maxime
- maximus13100
- Inscription Forum: 28 Mai 2007 15:43
jat.gab a écrit:En marge de la sortie du Z11 qui va faire énormément parler de lui à mon avis, il y a 3 nouveaux ampli qui sortent chez YAMAHA
Le RX-V3800 à 2100-2200 euro (à confirmer)
Le RX-V2800
i.link digital input for DVD-Audio and SACD
Il y a un truc qui me chagrine dans ces spés : pour le 2800, il est question d'une entrée i-Link, mais par pour le 3800 ? En outre, si on agrandit l'image de la face arrière du 3800, on n'y voit effectivement pas de trace d'i-Link.
Ampli Marantz SR6014, 5 blocs mono Marantz MA500, Boston (VR-M60 (x2), Micro130 (x2), MicroCenter), Caisson passif Cabasse + Rotel RMB100, BD Samsung, SACD Sony, PCHC assemblé, TVHD LG 55LX9500, Rega Planar3, Magnum FT100
jpu017 - Modérateur Home-Cinéma
- Inscription Forum: 23 Aoû 2006 17:38
jpu017 a écrit:jat.gab a écrit:En marge de la sortie du Z11 qui va faire énormément parler de lui à mon avis, il y a 3 nouveaux ampli qui sortent chez YAMAHA
Le RX-V2800
Tu as raison, et je viens de voir que le 3800 et le 1800 ont des HDMI 1.3a alors que le 2800 n'est que 1.3. Est-ce une coquille, ou alors cela pourrait expliquer le pourquoi du I-Link sur le 2800. (Il me semble que la difference entre 1.3 et 1.3a est la vitesse de transmission des données)
A+,
Scuderia.
- SCUDERIA
- Inscription Forum: 20 Déc 2001 2:00
pour avoir 2 sorties HDMI il faudra donc grimper jusqu'au 4800, c'est comme chez onkyo avec le 875 et le 905 ça fait cher la prise HDMI en sus
- tiboun
Juste pour savoir si vous connaitriez le prix du 1800 à sa sortie en France?
Je penche dans les 1200 € non?
- micmor
- Inscription Forum: 21 Sep 2003 17:34
puisqu'on parle prix, pensez-vous que le 2700 va baisser de prix sur les sites allemands où on le trouve pour +- 1250€ à la sortie du 2800? Sur les sites français, il vient juste de baisser de prix aujourd'hui...
Par exemple sur son-video.com.
Pour Micmor : Je pense que ce sera un peu au dessus de ton estimation...
le 1700 est déjà sorti à 1200€. Soit plus cher que le 1600 déjà plus cher que le 1500...
- sammy4
- Inscription Forum: 14 Mar 2005 18:56
sammy4 a écrit:puisqu'on parle prix, pensez-vous que le 2700 va baisser de prix sur les sites allemands où on le trouve pour +- 1250€ à la sortie du 2800? Sur les sites français, il vient juste de baisser de prix aujourd'hui...
Merci pour la réponse. Je vais donc me prendre le 1700.
- micmor
Miam miam le 2800 même le 1800 est très interessant !!!
Adhérez à l'association HCFR, puis visitez ma nouvelle galerie de photos!
safe - Membre HCFR
- Inscription Forum: 25 Sep 2000 2:00
jojo62 a écrit:Et le 4800, pas d'infos ?
Je n'ai pas vu d'info sur un éventuel 4800... Et je ne suis pas sur qu'il y en ai un puisque Yamaha propose déjà 3 appareils : 1800-2800-3800 (comme l'époque du 1600-2600-4600) + un HDG le Z11, ça m'étonnerait donc qu'il y en ai un 4ème entre les 2 gammes... Mais bon, je ne suis pas commercial chez Yam
- jat.gab
Vous avez une info sur le tarif du Z11 et si il up-convertie comme le LX-70 en 1080/24P?
Et surtout sa date de sortie et à quand une CG Yam8.
- Mod2
- Inscription Forum: 28 Juil 2007 19:02
