Type : paire de cable modulation
Marque : SUPRA Cables
Modèle et options : EFF-iSL
Prix de vente : 45€
Département où la marchandise est visible : 70
Montant des frais d'expédition : 3€
Etat de la marchandise : TBE
Prix neuf : 120€
Description et commentaires :
2x0.75cm( mesuré 2x0.78cm entre les connecteurs)
Câble de liaison audio stéréo haut de gamme. Câble à double isolation. Conducteurs en cuivre pur plaqué argent. Conception symétrique rendant ce câble insensible à toute forme de pollution électro-magnétique.
• Niveau de performance exceptionnel en regard du prix.
ce cable a été vainqueur de nombreux comparatifs (hifi choice, amp, stereo, hifi review,stereo times, etc....
Supra EFF-I Cables - for analogue audio signals
EFF-I 75 Ohm interconnect cable - for mid- to high-end audio systems
The dynamic influence of skin effect is of great sonic influence as music/video signals are nothing but variations.
By means of the Equalised Frequency Flow technique (EFF) Supra takes skin effect into account. The EFF-I cable consists of two tube-shaped conductors with a wall thickness of 0.20 mm, which is well below the smallest skin depth within the audio range.
This makes all frequencies operate under the same conditions.
Effective penetration depth (skin effect)
14.7 mm - Skin depth at 20 Hz 0.91 mm - Skin depth at 5 kHz 0.46 mm - Skin depth at 20 kHz
EFF-I interconnect cable construction
Each tube-shaped flexible conductor is made of silver plated Oxygen Free Copper of 0.5 sq. mm cross-sectional area, within a centre core of PolyEthylene (PE). Both conductors are individually screened for use in balanced or semi-balanced configuration.
caracteristiques du EFFI
EFF-I Interconnect Cable Analogue/Digital 75 Ohm The dynamic influence of the skin effect is of great sonic influence as music and also video signals are nothing but variations. By means of the Equalized Frequency Flow technique (EFF) Supra takes skin effect into account. The EFF-I cable consists of two tube-shaped conductors with a wall thickness of 0.20 mm which is well below the smallest skin depth within the audio range. This makes a wide range in the music (or video) of frequencies pass through under the same conditions.
Silver plated OFC copper 0.5 mm2/conductor. Tube-shaped flexible conductors with a center core of PE. Two conductors, individually screened, for balanced or semi-balanced connection.
12 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 11 invités
up
- piqachu
- Inscription Forum: 05 Juil 2004 20:40
up
- piqachu
baisse de prix: 50€
- piqachu
je pourrais être intéressé.
comment décrierais-tu le caractère de ces câbles? par rapport au stratos que tu m'a vendu par exemple?
Merci Cdlt
Jonathan
Merci Cdlt
Jonathan
- copiattyright
- Inscription Forum: 04 Avr 2007 17:09
re
salut Jonathan ,
comment dire car c'est mon avis perso sur mon materiel donc pas forcement la parole divine.
je dirais que le supra m'a bien semblé plus dynamique ( on a l'impression d'avoir augmenter le son)cela est sans doute du au plaquage argent des brins. et plus de détails.
- piqachu
up
- piqachu
derniere baisse à 45€
- piqachu
up
- piqachu
re
up
- piqachu
vendu
- piqachu
12 messages
