Suite à l'arrivée du 606 il y a quelques mois, le site européen d'Onkyo nous donne enfin des infos sur la nouvelle gamme :
arrivée du 806 : http://www.eu.onkyo.com/products/product_en_2008_6382285.html
et du 706 : http://www.eu.onkyo.com/products/product_en_2008_6377311.html
Nouveauté : THX ULTRA 2 PLUS...
Design plutôt identique, upscale allant jusqu'à 1080p...
En attendant le 876 et le 906
706 :
THX® Select2™ Plus 7.1-Channel Home Theatre Receiver
TX-SR706
In the mid-range category, credibility is gained through exceptional performance and a high degree of functionality.There’s no betterexample of this than the THX Select2 Plus Certified TX-SR706 A/V receiver.With a certified amplification design and ability to process full high-definition audio and video, the TX-SR706 marks the boundary between cost effectiveness and high-end functionality. Look to some notable firsts at this level: (1) The ability to scale all sources, such as standard DVD, up to 1080p video with the industryrecognized quality of Faroudja DCDi Cinema™; (2) An efficient push-pull amplification design originally created for Onkyo’s high-end receivers; and (3) THX® Loudness Plus™ technology to maintain the impact of home theatre even at low volume.To cap off a remarkable home entertainment component, we’ve also included RIHD (Remote Interactive over HDMI) system control; advanced Audyssey room acoustic correction technologies; and the option of iPod connectivity.
Advanced Features
THX Select2 Plus Certified with THX Loudness Plus
DTS-HD Master Audio, DTS-HD High Resolution Audio, Dolby TrueHD, Dolby Digital Plus Decoding
HDMI to Support Deep Color, x.v. Color, LipSync, Dolby TrueHD, DTS-HD Master Audio, DVD-Audio, Super Audio CD
HDMI Audio and Video Processing (1080p; 4 Inputs and 1 Output)
HDMI Video Upscaling up to 1080p with Faroudja DCDi Cinema
RIHD (Remote Interactive over HDMI) for System Control
HDTV-Capable HDMI Switching
HDTV-Capable (to 720p/1080i) Component Video Switching (2 Inputs and 1 Output)
Push-Pull Amplification Design with Three-Stage Inverted Darlington Circuitry
192 kHz/24-Bit Cirrus Logic DACs for All Channels
Two TI 32-Bit DSP Chips for Advanced Processing
Audyssey MultEQ to Correct Room Acoustic Problems and to Calibrate Speakers
Audyssey Dynamic EQ for Loudness Correction
Bi-Amping Capability for Music and Movie Surround Effects
Audio Features
160 W/Ch Minimum into 6 Ω, 1 kHz, IEC (1 Channel Driven)
DTS®-ES™ Discrete/Matrix, DTS® Neo:6, DTS® 96/24, Dolby® Digital EX®, Dolby® Pro Logic® IIx Decoding
H.C.P.S. (High Current Power Supply) Massive High Power Transformer
WRAT (Wide Range Amplifier Technology)
6 Digital Inputs (3 Optical [1 Front]/3 Coaxial)
Direct Mode
A-Form Listening Mode Memory
Optimum Gain Volume Circuitry
Music Optimizer for Compressed Music Files
Non-Scaling Configuration
Tone Control (Bass/Treble) for Front L/R Channels
Color-Coded 7.1-Multichannel Inputs and Pre Outs
Independent Crossover Adjustment for F/C/S/SB (40/50/60/70/80/90/100/120/150/200 Hz)
Double Bass Function
Other Features
Powered Zone 2 and Zone 2 Line-Out for Playback in Another Room (Separate Source)
Banana Plug-Compatible Speaker Posts
A/V Synchronization Function (Up to 250 ms in 5 ms Steps)
40 FM/AM Radio Presets
IntelliVolume
RDS (PS/RT/PTY/TP)
5 S-Video Inputs and 2 Outputs
5 A/V Inputs and 1 Output
2 Audio Inputs and 1 Output
Phono Input
RS232, IR (Input), and 12 V Trigger Connectivity
Display Dimmer (Normal/Dim/Dimmer)
Headphone Jack
Aluminum Front Panel
Newly Designed GUI for System Set-up
Compatible with RI (Remote Interactive) Dock forthe iPod
Newly Designed Preprogrammed RI (Remote Interactive) Remote Control with Mode-Key LEDs
806 :
THX® Ultra2 Plus™ Certified 7.1-Channel Home Theatre Receiver
TX-SR806
The TX-SR806 occupies a unique position in the Onkyo line-up.We class it as a mid-range A/V receiver. But with its advanced capabilities and THX Ultra2 Plus certification, it’s a worthy challenger for high-end status. Built with high-definition entertainment in mind, the TX-SR806 accommodates up to five HDMI™ sources that can handle both 1080p video and studio master-quality surround sound.That’s more high-def sources than you’ll find on any other Onkyo A/V receiver. If that weren’t enough, onboard Faroudja DCDi Cinema™ scales all standard definition sources to 1080p for HDMI output, or to 1080i for component video output. Endowed with the amplification power and dependability expected from an Onkyo A/V receiver, the TX-SR806 stands out as a natural choice for highperformance home theatre.
ADVANCED FEATURES
THX Ultra2 Plus Certified with THX Loudness Plus
HDMI Audio and Video Processing (1080p; 5 Inputs and 1 Output)
HDMI Video Upscaling to 1080p with Faroudja DCDi Cinema
Component Video Upscaling to 1080i with Faroudja DCDi Cinema
HDMI Switching
AUDIO FEATURES
180 W/Ch Minimum into 6 Ω, 1 kHz, IEC (1 Channel Driven)
Subwoofer Pre Out
Direct Mode
OTHER FEATURES
Powered Zone 2 and Zone 2 Pre-Out for Playback in Another Room (Separate Source)
RDS (PS/RT/PTY/PT)
IntelliVolume
Phono Input
RS232, IR and 12V Trigger Connectivity
Headphone Jack
Compatible with RI (Remote Interactive) Dock for the iPod
30 messages • Accèder à une page • 1, 2
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Bobanar21, brucast, Cebriete, cherry2809, ecoutervoir, Erwan960, kaminka, MacSpawn, petesburne, protprot, roonie, sergeh, TMC31, Ziguipuce et 220 invités
j'attendais de lire quelques cr avant de me décider à acheter le 606
mais voilà que denon sort sa nouvelle gamme d'ampli, le 1909, légérement plus cher, intégre également les décodeurs HD
j'attends surtout de savoir si l'ampli ne dégrade pas le signal en entrée sur ses prises HDMI
p.s : j'ai fais une recherche sur le forum et je n'ai trouvé aucun topic dédié au 606
étrange, poutant celà fait un moment qu'il est disponible
- papetmax
- Inscription Forum: 16 Avr 2008 22:36
- Localisation: La tête dans les nuages, mais les pieds sur terre...
viewtopic.php?f=1024&t=29879833&start=540&st=0&sk=t&sd=a
tiens voila tu as quelques pages à lire !!!!!!
- alex
- Inscription Forum: 24 Juil 2008 12:00
merci bien alex
j'avais juste tapé onkyo 606
- papetmax
A votre avis les connaisseurs, la différence de prix entre un 606 et un 706, ça pourrait être de quel ordre ?
- Mr Bundy
- Inscription Forum: 16 Avr 2006 15:59
la grosse différence, c'est le nombre de DSP, 3 au lieu de 1
le 606 par exemple est incapable de passer un DSP 7.1 sur un PCM 5.1...
- Rootrulez
- Inscription Forum: 12 Jan 2008 23:00
rootrulez a écrit:la grosse différence, c'est le nombre de DSP, 3 au lieu de 1
Two TI 32-Bit DSP Chips for Advanced Processing... ca retombe à 2 DSP pour les 706-806
- 46D3000
- Inscription Forum: 13 Sep 2007 18:14
ah tiens, j'avais pas fait attention...
là, je ne comprends pas la stratégie !
ça sent la réduction des couts pour baisser le prix de vente non ???
- Rootrulez
rootrulez a écrit:ah tiens, j'avais pas fait attention...
je ne sais pas et peut-etre vais je dire une grosse bêtise, ne serait ce pas en rapport avec l'abandon du HD-DVD?
Peut-etre que 2 DSP suffisent au PCM7.1 et aux différents formats HD-audio...
- 46D3000
non je ne pense pas, les formats audio étaient quasi équivalent entre le HDDVD et le BR il me semble...
déjà, la gamme 605 puis 606 en possédait qu'un seul... maintenant 2 à la place de 3 pour le 706 et le 806... je sais pas, pour moi ça ressemble surtout à une réduction des coûts sur les composants
ou alors les 2 puces sont plus puissantes que les 3 de l'ancienne gamme
- Rootrulez
je remonte un peu ce topic
quelqu'un a t il des infos sur les disponibilités ??
- Rootrulez
rootrulez a écrit:Première annonce de l'arrivée du 706 et du 806 sur HDnumérique.com ici
waw et déjà une super pub pour le site de vpc 'premium94' !
Ils nous proposent 1429€ au lieu de 1499€ je me marre...
Seule différence d’importance avec les précédents modèles : le prix de lancement. Alors que le TX-SR805 fut commercialisé à l’époque au tarif de 1499 euros, le TX-SR806 sera proposé à un tarif de 1099$ sur le marché américain.
Je parierais pour 1099€ en moyenne et on le trouve déjà à 908€ en précommande:D
- 46D3000
materiel.net le met à 1299 € !!!
pour ma part j'aurais pensé 999 € pour le 806 ! mais je pense que c'est encore un peu tôt !
- Rootrulez
30 messages
