Hello,
I wasn't sure where to post the question but here goes. Does the Zenquito 15w Class A shift to AB at approx. 3 watts ? If it does, can the amplifier be adjusted to output only 3 watts Class A so it's pure ?
Thanks.
7 messages • Page 1 sur 1
Modérateurs: Modération Forum DIY, Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Zbymar et 135 invités
Hello
The ratio class A / class B, and the power limit for the change, depends on the amount of bias current in the output mosfets.
You can adjust as you like.
The 15w class a is class A at 15W
examples :
with 0.7A by push pull, for a two push pull, you have 30w pure class A (1.4A total bias for a chanel)
with 0.5A by push pull, for a two push pull, you have 16w pure class A
with 0.4A by push pull, for a two push pull, you have 10w pure class A
with 0.22A by push pull, for a two push pull, you have 3w pure class A
Philippe
examples :
Philippe
- Philby
Locking Class A
Hi Philby,
I might try 260mA to get 4 watts Class A. How can I avoid having the system leave Class A ? Reduce voltage of the preamp ?
Thanks.
Thanks.
- vizion
- Inscription Forum: 01 Fév 2009 3:53
Selectronic ProFET
hello,
what is the class A bias of the ProFET ? 260 ma ?
thanks.
thanks.
- vizion
en anglais ca c'est bon!!!
- beyma
- Inscription Forum: 15 Mar 2007 13:04
Philby listening it is a monster of the zenquito!!!
It is the pip(top)!!!
I says philby sir
I says philby sir
- beyma
Hello,
I just confirmed that the bias is 415 mA. It would be fun if the amp is full Class A even with just a few watts.
Eric
Eric
- vizion
7 messages
