Caractéristiques Techniques du produit : cable HDMI THDG 1m, 2 rf stopper, 6,1% silver......soudures argent...
N° de Série du produit : RAS
Date d'achat : 2008
Aspect du produit : Nickel, en parfait état
Lieu d'hébergement du produit : MARTIGUES (pays du soleil)
Expédition et Conditionnement : colissimo par la poste, compris
Prix de Vente : 100€ FDPIN --> 90€ FDPIN --> 50€ FDPIN
Prix d'achat : 220€ (facture perdue... )
boite origines : non, perdue avec facture dedans....
Garantie : non
Observations : Ce câble est d'une qualité rare, le plus haut de gamme de la serie AUDIOQUEST. 6,1% d'argent, soudure argent, double ferrites, gaine de protection teflon, certifié 1.3........
Lien : http://www.musicdirect.com/product/72813 ou vous trouverez toutes ces caractéristques mais en anglais.
AUDIOQUEST - HDMI-3 MULTIMEDIA CABLE
Not all HDMI cables are created equal! Audioquest HDMI cables are perhaps the finest HDMI cables available. All Audioquest HDMI Cables use solid core conductors for excellent conductivity and low distortion, especially over longer lengths; solderless cold-weld HDMI connectors for enhanced signal transmission and reduced distortion, heavy silver plating on the conductors for a sharper, smoother and clearer picture.
Audioquest goes the extra mile to ensure a great HDMI cable by running the machines that wind the 19 conductors into the critical geometry of an HDMI cable at half-speed, ensuring perfect geometry regardless of length. Then, every AQ HDMI cable is 100% quality tested to ensure it meets all specifications. All this guarantees that whether you buy a 1.0m or a 9.0m cable, Audioquest HDMI cables will deliver a great picture every time.
HDMI-3 is ideal for large, high resolution displays or over long distances where preservation of information is critical. HDMI-3 preserves more of the signal with its large solid core conductors and heavy 6.1% silver plating. This combination of excellent conductors and almost 5x more silver plate than the industry standard, HDMI-3 presents a gorgeous picture with incredible detail and an almost holographic depth of field.
Specifications:
HDMI v1.3 compliant
1080p/60Hz (up to 20M)
6.1% Silver Plating on conductors
3.0m & Under: 26AWG Solid Core Conductors (Cloth Braid)
4.5m & Over: 24AWG Solid Core Conductors (White PVC
Contact : Par MP ou sur le post
