un gars sur doom9 a posté récemment un player freeware en phase de dev alpha mais fonctionnel pour lire les dvd-audio avec watermark et tout le toutim...
Ca se passe, ici, pour les ceusses intéressés :
http://forum.doom9.org/showthread.php?t=145660
J'ai essayé, c'est sommaire mais utilisable !
Xavier.
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Emmanuel Piat, Freemanjazz, julien-64, redwan78, yokosuza et 136 invités
Lire ses DVD-AUDIO : ShaPLAY !
- tobal
- Inscription Forum: 13 Sep 2001 2:00
Je vous colle les specs du player :
Donc en gros le player fait le décodage et après on peut faire délais, BM etc etc en récupérant le flux décodé sous ffdshow ou carrément en asio pour ceux qui maitrisent.
Xavier.
Supports original DVD-A discs and DVD-A backups on HDD.
The discs can be watermarked. Supported 2.0 and 5.1 tracks, MLP and PCM.
The output IS NOT DOWNSAMPLED and NOT POST-PROCESSED!!!
You can use any output DirectShow filter for post-processing or
downsampling (if you really need it).
The player is based on DVDAExplorer sources and Microsoft Async sample.
A lot of bugs and 'studs' inside (have you ever seen 'World of Goo'
game? ), but at least it works.
Tested on XP SP2/SP3 (32bit), MCE2005 (SP2) and Vista SP1 32bit.
The best DVD-A that I have tested was 5.1 MLP 96kHz 24bit.
ShaPLAY has inside own DirectShow source filter and DVDA decoder
(MLP->WAV), but needs external WAV decoder. I recommend to use SVN
builds of ffdshow_tryouts
(http://ffdshow-tryout.sourceforge.net/download.php),
but from v0.0.2.1 you can disable preffered ffdshow usage.
In this case Windows will automatically assign default WAV-decoder
filter (it can also be ffdshow, if it is your default DirectShow-decoder
for uncompressed streams), but I can not say how to configure output in
this case - it is up to your DS-decoder. But (again) I
recommend to use ffdshow_tryouts (build 2637 works perfect for me),
you can set here all the output settings and post-processing in one
application.
Xavier.
- tobal
pour être sommaire c'est sommaire! comment passer en asio? asio4all ?
merci pour l'info en tout cas
- le touriste
Moi je le récupère en kernel streaming avec reclock et hop en asio.
Après asio4all peut être une soluce.
Xavier.
Xavier.
- tobal
pas de son en sortie de la julia en passant par reclock.
tu l'as configuré comment?
- le touriste
ça vient d'évoluer: v0.4a
http://forum.doom9.org/showthread.php?p ... ost1261226
- le touriste
Super! en installant fffffdshow j'ai le son sur la Juli@.
me demandez pas comment j'ai fait
- le touriste
sait pas pourquoi mais le son est "sale".
au mieux c'est pas musical
- le touriste
Intéréssant...
Find In Your Mind the Saiyan Rage!
- GuileZ_
- Inscription Forum: 15 Mar 2007 22:26
a priori c'est maintenant possible de lire le mlp depuis foobar ...
- vairulez
- Inscription Forum: 03 Fév 2002 2:00
vairulez a écrit:a priori c'est maintenant possible de lire le mlp depuis foobar ...
Comment?
- GuileZ_
je dirais même plus................comment?
- le touriste
J'ai pas testé mais je dirai que c'est en utilisant le plugin foobar kivabien
Pour être encore plus précis, je dirai en utilisant ce plugin -> DVD-Audio Decoder <-
- pildoy
- Inscription Forum: 18 Juin 2003 18:37
merci bien, ça a l'air de marcher.
- le touriste
Et comment vous faites pour lire vos DVD-A avec Foobar, vous les rippez avant? Si oui de quel manière?
- GuileZ_
25 messages
