Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Bruce_Wayne_37, didier22, erictours, Google Adsense [Bot], JG Naum, kaioh31, LeBarr, Morganita, vanouille et 490 invités
Toutes les enceintes HiFi
Nvelle Dynaudio Consequence Ultimate Edition - photos inside
» 09 Aoû 2009 1:39
roland_de_lassus a écrit:Encore une ch'tite tof de Taïwan...
Et celle ci a plus de 20 ans des laides comme ça je ne dirais pas non pourtant je suis 100% PANNEAUX
MrAcoustat le 19 Avr 2011 22:02, édité 1 fois.
MrAcoustat
- Inscription Forum: 13 Mai 2008 16:08
» 10 Aoû 2009 10:34
Ça a l'air du travail soigné, belles photos roland, merci
expertdoc
» 10 Aoû 2009 11:18
Pour les photos, faut remercier et féliciter Leo Yeh
Sinon, concernant l'extension des fréquences vers le bas, voici le descriptif de la technologie employée (tiré du site Dynaudio):
The secret of this bass performance is a very special technology: The unique Compound System. No other loudspeaker manufacturer utilizes this system as effectively as Dynaudio does.
The Consequence Ultimate Edition Compound System consists of two driver components, each perfectly complementing the other and enabling the impossible: A woofer operating in an infinitely-large enclosure. The Consequence’s exceptionally large woofer already ensures a deep bass performance with incredible extension.
Via the Compound System, its bass performance is enhanced dramatically. The secret is hidden within the interior of the Consequence: Here, a second woofer is installed – not visible from outside. This internal woofer offers „compound loading“ to the external woofer, and the finely-tuned performance of these two woofers in tandem enables the outstanding deep-bass performance.
Physics dictate that this level of low-frequency performance would otherwise only be attainable via an infinitely large cabinet enclosure volume."
roland_de_lassus
- Modérateur Haute-Fidélité
» 10 Aoû 2009 11:24
C'est intéressant -PE Leon fait aussi qque chose de similaire - mais cela ressemble malgrè tout un peu à un discours de plaquette commerciale.
Il faudrait qu'ils donnent quelques chiffres à 16 Hz, pour illustrer de manière factuelle la "deep bass performance with incredible extension".
Paull
- Inscription Forum: 22 Sep 2003 16:32
- Localisation: "For Those About To Rock (We Salute You)" - AC/DC
» 10 Aoû 2009 11:31
Paull a écrit:Il faudrait qu'ils donnent quelques chiffres à 16 Hz, pour illustrer de manière factuelle la "deep bass performance with incredible extension".
Boum - Boum ???
Le deuxième effet HC ??
fargo
- Inscription Forum: 15 Avr 2005 23:01
» 10 Aoû 2009 11:39
c'est quand même bizarre pour un caisson de basse de mettre des tweeters.
Francois
frgirard
- Inscription Forum: 05 Fév 2005 13:21
» 10 Aoû 2009 11:49
fargo a écrit:Paull a écrit:Il faudrait qu'ils donnent quelques chiffres à 16 Hz, pour illustrer de manière factuelle la "deep bass performance with incredible extension".
Boum - Boum ???
M'en balance, qu'elles descendent à 16Hz ou à 25. C'est juste que je veux bien croire il est possible que leur doc soit un peu optimiste, comme celles des ProAc.
Mes Heresy coupent à 58 Hz, Môssieur!
@ François : on dit caisson de grave.
Paull
» 10 Aoû 2009 12:01
Paull a écrit:C'est intéressant -
J'ai eu une paire de PEL qui appliquait le principe de la charge isobarique : deux haut-parleurs situés l'un derrière l'autre.
Ca étendait la bande passante, mais je trouve qu'on perdait en précision.
Je pense que le principe de Dynaudio doit être un peu plus complexe... Mais va savoir...
roland_de_lassus
» 10 Aoû 2009 14:17
Igor Kirkwood a écrit:dinosaure 77 a écrit:Igor Kirkwood a écrit:Il est vrai que descendre très bas en fréquence risque de provoquer des vibrations (a maitriser
Par contre une courbe de réponse étendue en extrème grave donnera une image sonore plus large sur un bon enregistrement,et davantage de profondeur
Igor Kirkwood
La caisse a l'air d'être capable d'encaisser...
Surement , Dynaudio c'est une marque sérieuse
, mais dinosaure je pensais aux vibrations du local.
I.K.
J'avais pas tout suivi, désolé...
dinosaure 77
- Inscription Forum: 23 Fév 2007 12:38
» 10 Aoû 2009 14:52
Prix d'après personnes bien informées : 75.000$
En fait, le marché asiatique est un gros marché pour Dynaudio.
Ils continuaient encore à fabriquer les anciennes Consequence (qui datent quand même de 1984) pour les afficionados de la région.
Le pourquoi du positionnement du super-tweeter et des tweeter dans le bas alors que ce sont les fréquences les plus directives sont à rechercher dans les raisons déjà données par Denis (mise en phase acoustique).
roland_de_lassus
» 10 Aoû 2009 15:13
Cela fait toujours plaisir de voir que la crise se porte mieux
au Japon.....
BRUNOTILUS
- Inscription Forum: 10 Oct 2006 20:13
» 10 Aoû 2009 15:21
Pas qu'au Japon..
Principalement à Honk-Kong et en Chine...
roland_de_lassus
