Hello Everyone,
I am new to this forum, so please be kind
I have installed the HCFR software and plugged in the HCFR sensor, but on a full white field,
the values bounce up and down continuously, for all 3 colors.
The sensor firmware is v5.10.
I looked for a way to update the firmware, but there is no tools tab as discribed on the english page.
I looked through every tab in the software, but found nothing.
I would appreciate any help on how to upgrade the firmware.
Cheers
Steve
4 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Modération Forum Installations, Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: PierreA et 16 invités
Oh well,
Look's like there is no way to upgrade the firmware to see if this will fix the problem.
- HK-Steve
- Inscription Forum: 13 Sep 2009 13:16
Hello,
There is no difference in the color measurement between the different software. I fear that a software update won't have any effect on your problem.
Can you post a reccording done with the probe on continuous measures ?
- Ki
- Inscription Forum: 12 Jan 2003 14:55
I will do a continuous measurement tonight if I can get my Wife away from the projector for a couple of minutes.
Appreciate your reply.
Cheers
Steve
Cheers
Steve
- HK-Steve
4 messages
