Manufacturer Sanji Electronics
Type HDD/USB/Net
Max Resolution 1080p [Full-HD]
Chipset Realtek 1073 (400mhz)
Memory 128Mb SPI Flash - 128MB DDR2 SDRAM
Internal Storage 3.5" SATA
External Storage USB 2.0 (1*SLAVE, 2* HOST), SD Card
File Systems FAT, EXT3, NTFS
Network Protocols Samba, NFS, UPnP
Network Ethernet 10/100, Optional Wi-Fi(n)
Video Outputs HDMI 1.3, Component, Composite
Audio Outputs Stereo Analogue, S/PDIF Optical, Coaxial Digital
Video Formats (Codecs) MKV, H264, DVD (VOB - IFO - ISO), DIVX, XVID, DAT, AVI, MPEG, HD MPEG-2, TS, HD MPEG-4, SP, ASP, AVCD (H.264), MTS, M2ts, WMV9, FLV, VC-1, Real Networks (RM/RMVB) 8/9/10, up to 720p
Video Extensions (Containers)
Audio Formats (Codecs) MP3, MP2, OGG Vorbis, PCM, LPCM, AAC, RA, Dolby AC3 Passthrough, Dolby AC3 Downmix, DTS Passthrough, DTS Downmix, FLAC, WAV,
WMA Standard (DRM, & Advanced Profile not supported)
Audio Extensions (Containers)
Image Formats JPEG, BMP
Subtitle Formats SRT, SSA, SUB, SMI
DVD ISO Yes. With menu
Blu-Ray ISO ?
Dolby Digital Downmix + Pass-through
Dolby Digital Plus Downmix
Dolby TrueHD Downmix
DTS Downmix + Pass-through
DTS-HD HR ?
DTS-HD MA No
Inbuilt Web Services Shoutcast
Other Services
Power
Fan Yes
Dimensions / Weight
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: AlainParis, albator91, AxleM, bandicootfr, banjo65, bermudatatooine, coucouse, danydan77, duf666, Gaël, Goby92, guillaumodore, hobbywann, mikematrix, misichavichus, mitsub300, Patbon21500, pecman32, polo2121, portenawak, rere130, shenos, Stade81, stanis384, swords, tony51, vauclair83, vincent59270, yoann2004 et 188 invités
Mede8er MED500X (Realtek RTD1073)
voici les specs
- malibard
- Inscription Forum: 22 Juil 2007 22:54
attention tous les sites reprennent une fausse caractéristique
16M SPI Flash - 128MB DDR2 SDRAM
c'est en faite :
voici ma source :
http://www.mpcclub.com/forum/showpost.p ... ostcount=3
c'est en faite :
voici ma source :
- malibard
Je suis enfin décidé je vais opté pour la Mede8er
J'ai cependant quelques questions :
- Je vais avoir un disque dur multimédia Memup LXII 1To, je comptais prendre le disque dur qui se trouve dedans et le mettre dans le mede8er mais je ne sais pas ce qu'il vaut? Faut t'il privilégier un disque dur 5400tr/min ou basse conso... ?
- Actuellement je transfert mes divx en ftp de mon pc à mon disque dur externe raccordé en usb à ma freebox hd. Que faudra t'il que je fasse après? La box sera raccordé en ethernet a ma freebox. La procédure est similaire? Le mieux est que je transfert sur le disque dur de la box les films ou la lecture depuis le pc est tout à fait envisageable sachant que mon pc est un peu à la traine niveau performance ( les mkv 1080p sont irregardables, freeze... )?
EDIT : si quelqu'un a le courage de prendre en photo son boitier je suis preneur, sur youtube ou site officiel on voit pas grand chose... Merci
- thieu93
- Inscription Forum: 29 Fév 2004 12:10
Commandé pour mon padre !
- macyavel
- Inscription Forum: 14 Jan 2005 0:21
thieu93 a écrit:Bonjour,
je connais pas le memup 1 to mais je privilégie toujours des disque dur 5400 c'est largement suffisant pour de la lecture et ca chauffe moins , apres tu peux mettre ton disque rien ne l'empeche !
oui tu peux faire la même procédure pour le raccordement
dans un pc qui sait pas lire le mkv 1080p , ca vient sans doute d'une veille carte graphique
- malibard
Merci pour tes réponses.
Pour le disque dur une fois que j'aurais reçu le memup je verrais comment çà se passe... c'est peut etre un 5400tr d'origine.
Et pour le PC c'est un portable bas de gamme avec carte graphique intégré à la carte mère donc sans surprise pour les mkv
- thieu93
thieu93 a écrit:Merci pour tes réponses.
de rien
- malibard
je complete la fiche
Processor: Realtek RTD1073 - 128MB SPI Flash - 128MB DDR2 SDRAM
Video Codec Supported: MKV, H264, DVD (VOB - IFO - ISO), DIVX, XVID, DAT, AVI, MPEG, HD MPEG-2, TS, HD MPEG-4, SP, ASP, AVCD (H.264), MTS, M2ts, WMV9, FLV, VC-1, Real Networks (RM/RMVB) 8/9/10, up to 720p
Audio Codec Supported: MP3, MP2, OGG Vorbis, PCM, LPCM, AAC, RA, Dolby AC3 Passthrough, Dolby AC3 Downmix, DTS Passthrough, DTS Downmix, FLAC, WAV,
HD Audio support
Dolby digital - support decode & bypass
Dolby TrueHD - not supported -- under development
Dolby digital Plus - support decode - bypass is in testing
Dolby digital EX - support - compatible up to 5.1
Dolby digital Pulse - not supported
DTS digital Surround - support decode & bypass
DTS-HD Master Audio - not supported - under development
DTS-ES - not supported
Photo format Supported: JPEG, BMP
File System Supported: FAT32, NTFS - UI Format Feature
Input / Output
• HDMI 1.3, Component video, Composite Video
• Stereo RCA audio for analog audio connection
• SD / Sony Pro Duo Card Slot
• S/PDIF optical Output / Coaxial Digital RCA Output
• Video output resolution - NTSC, PAL, 480p, 576p, 720p, 1080i, 1080p, 1080p24hz
• USB - 2.0 HOST port x 2 (compatible to USB 1.1)
• USB - 2.0 SLAVE port
General
• 3.5" SATA Internal Hard Drive Bay up to 2TB compatible
• Built in 40mm cooling fan - TPE mounts for low noise
• Playlist creation from remote
• Built in NFS Client
• Screensaver – Selectable in GUI setup
• In folder JPEG preview feature
• Easy navigation button use (excl DVD files)
• Time Bar FF/FR and Time Bar jump
• Media Library Jump To file number feature
• Resume playback feature
• Photo slide show with background music
• Network - Ethernet 10/100 Mbps - Streaming MAX Samba 26Mbps / NFS 36Mbps
• Optional Wi-Fi (802.11b/g/n)
Achievable Streaming G router - Samba 12Mbps - NFS 18 Mbps @ 1m - unprotected
Achievable Streaming N router - Samba 14Mbps - NFS 22 Mbps @ 1m - unprotected
(Typical MKV 720p Play 10Mbps max FF/RW 15Mbps)
• Samba server - NAS storage
• A/V streaming via UPnP Media Server (CNN - YouTube etc via optional program such as PlayOn, Tversity etc)
• Internet Radio (SHOUTcast)
• File Copying - Card, USB, HDD and Network
• Subtitle: SRT, SSA, SUB, SMI format
Contents: MED500X, RC, AC Adapter, Carry Bag, Cables - AV, HD HDMI, USB, Component, USB extension with Base
Specifications subject to change without notice.
source : mede8er.co.za
- malibard
mede8er a publié son code source
si ca peut intéressé des personnes qui savent moddé
http://www.mede8erforum.com/index.php?board=19.0
il faut s'inscrire pour les récupérer
- malibard
je possède ce lecteur depuis deux semaines et j'aimerais mettre le firmware à jour pour accéder aux radios. Est il possible de le faire à partir d'un mini disque de posche USB Intuix 6Go (fat32) ou une clé USB est elle indispensable?
- markale
- Inscription Forum: 05 Oct 2006 10:41
markale a écrit:Bonjour,
salut
il est souvent recommander de faire sur une clé ub mais tu peux essayer sur ton mini disque , tu risque rien ! si ca fonctionne pas mais faut etre en fat32
sinon ca serait cool de faire un petit CR du produit , ce que tu aime , ce que tu aime pas
- malibard
C'est la clef usb qui doit etre en fat32 pour la MAJ?
J'ai pas regardé le mode d'emploi mais çà se passe comment la MAJ? On met le fichier sur une clef usb, on la connecte et çà se lance automatiquement?
- thieu93
oui tu dois etre sur le format fat 32 pour la maj
mettre le fichier install.img et logo_pal.bmp dans la clé
en gros met la clé usb dans un slot puis va dans le menu setup systeme et tu selectionne system update ( mise a jour system )
n'hésite pas a faire un CR du produit ce que tu aime et n'aime pas ? ca serait cool de partager ton avis
"Download the latest Firmware from the Mede8er website. Unzip the file and you will find two files ie
install.img and logo_pal_bmp. Copy both these files to the root directory of a Flash Drive. Plug the flash
drive into the Mede8er. Go to the Setup menu and then System and select System Update. Now select
System Reinstall. The Mede8er will now proceed to upgrade the firmware. The front facia LED will flash
Red and Blue during the update procedure. "
- malibard
Merci pour cette précision.
J'hésiterais pas à faire un CR... dés que je l'aurais ( vers Noel )
- thieu93
thieu93 a écrit:Merci pour cette précision.
noël c'est loin loin loin n'en rêve pas trop
- malibard
