Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Atome_X, Dolpi, jpvoit, pasender, spoublan, themouloud, tifab, yardbird et 428 invités
Préampli Anthem AVM 50V
PREAMPLIFIER SECTION
Input Impedance
20 k ohms
Output Impedance
Main-RCA
Other-RCA
XLR
300 ohms
51 ohms
600 ohms
Rated Input
2.0 Vrms
Maximum Input
6-Channel S/E
All Others
3.0 Vrms
5.3 Vrms
Rated Output (100k ohms load)
2.0 Vrms
Minimum Load
5k ohms
Maximum Output
RCA
XLR
6.3 Vrms
12.6 Vrms
Headphone Output
100 mW into 32 ohms @ 0.2% THD+N
Volume Range
Main
Zone 2/3 & Headphone
-95.5 dB to +31.5 dB (0.5 dB resolution)
-62.5 dB to +10.0 dB (1.25 dB resolution)
Bass Management
High-Pass Slope (Small Speaker Setting)
Low-Pass Slope (Subwoofer)
Crossover Frequency (Adjustable in 5 Hz Increments)
12 dB/octave (2nd order)
24 dB/octave (4th order)
25-160 Hz
Tone Control
Bass Turnover Frequency
Treble Turnover Frequency
Range
Filter Response Type
200 Hz
2 kHz
+/- 12 dB
Shelf
Channel Separation (at 1 kHz)
82 dB
Crosstalk Between Inputs (at 1 kHz)
86 dB
MAIN PATH
(RCA & XLR Outputs, 48 kHz Sampling Rate for all Digital Signal Paths)
Frequency Response and Bandwidth
6-Ch S/E and 2-Ch BAL Direct Inputs
2-Ch S/E Direct Inputs
Analog-DSP Inputs @ 24/96
Digital Inputs @ 24/96
10 Hz to 20 kHz +0, -0.2 dB; 1 Hz to 130 kHz -3 dB
10 Hz to 20 kHz +0, -0.2 dB; 1 Hz to 120 kHz -3 dB
10 Hz to 20 kHz +0, -0.3 dB; 1 Hz to 37 kHz -3 dB
10 Hz to 20 kHz +0, -0.2 dB; 1 Hz to 39 kHz -3 dB
THD+N (at Rated Input & Output)
6-Ch S/E Direct Input
Analog-DSP Inputs @ 24/48
Digital Inputs @ 24/48
0.003% (80 kHz BW)
0.004% (80 kHz BW)
0.006% (80 kHz BW)
0.006% (AES17 filter)
0.004% (AES17 filter)
IMD (CCIF @ 15 kHz & 16 kHz)
0.001%
0.002%
0.003%
0.003%
0.001%
S/N Ratio (ref. 2.0 Vrms A-weighted)
2-Ch Direct Inputs
107 dB
106 dB
100 dB
104 dB
XLR Pin Configuration
Pin 1: Ground, Pin 2: Positive, Pin 3: Negative
ZONE 2 and ZONE 3 PATHS
IMD (CCIF at 15 kHz & 16 kHz)
20 Hz to 20 kHz +0, -0.1 dB; 3 Hz to 140 kHz -3 dB
0.06% (80 kHz BW)
0.06%
97 dB
RECORD PATH Analog to Digital Conversion S/N Ratio
(A-weighted)
100 dB
FM TUNER SECTION
Sensitivity
50 dB S/N
IHF
13 dBµ typ., 25 dBµ max.
10 dBµ typ., 20 dBµ max.
S/N Ratio
Mono
Stereo
75 dB typ., 65 dB min.
69 dB typ., 60 dB min.
Distortion
Mono
Stereo
0.2% typ., 1.0% max.
0.3% typ., 1.5% max.
Stereo Separation
40 dB typ., 25 dB min.
Alternate Channel Selectivity
(+/- 400 kHz)
70 dB typ., 60 dB min.
Frequency Response
25 Hz to 15 kHz +0. -2 dB
AM TUNER SECTION
Sensitivity (20 dB S/N)
49 dBµ typ., 56 dBµ max.
S/N Ratio
50 dB typ., 43 dB min.
Distortion
0.7% typ., 2.0% max.
One-Signal Selectivity (+/- 10 kHz)
24 dB typ., 18 dB min.
VIDEO SECTION
Bandwidth
Composite & S-Video
Component: Green
Component: Red
Component: Blue
70 MHz
110 MHz
90 MHz
80 MHz
All video inputs and outputs are 75 ohms, 1.5 Vp-p.
DIGITAL AUDIO
100 dB
CONTROL
Infra Red
Carrier Frequency
Max. 12V Supply Current
Max. Emitter Current
38 kHz
150 mA
100 mA per output
RS-232 Connection
DB-9F (straight-wired)
RS-232 Pin Configuration (processor side)
Pin 2: Tx, Pin 3: Rx, Pin 5: Ground
RS-232 Port Configuration
Baud rate (1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200), 8 data bits, 1 stop bit, no parity bits, flow control (RTS, CTS, NONE)
Trigger Outputs
Polarity
Max. Current @ 12 VDC
Sequential Delay
tip positive; sleeve negative
50 mA (Triggers 1,2), 200 mA (Trigger 3)
250 ms
DIMENSIONS
Width 17-1/4 inches (43.8 cm)
Height 5-7/8 inches (14.9 cm) including feet; Rack-mounting: 3 rack units, without feet
Depth 14-1/4 inches (36.2 cm)
Weight 30.7 lb (14 kg)
MISCELLANEOUS
Power Consumption : Maximum 150 W
- Christophe CHEREL
- Pro-Fabricant
- Inscription Forum: 06 Juil 2001 2:00
Le préampli Anthem AVM 50V sera présenté en écoute pour la première fois en France au salon Hifi Home Cinema SPAT les 10 et 11 octobre 2009.
Voir le topic officiel du salon :
viewtopic.php?f=82&t=29916796
Christophe.
Christophe.
- Christophe CHEREL
- Pro-Fabricant
Christophe CHEREL a écrit:Bonjour
Christophe.
il me semblait qu'il était déjà en vente? Ou alors est-ce l'ancienne mouture?
Cela dit, pourrais-tu nous éclairer sur la gamme Anthem, car entre les séries D-1 D-2 et nouvellement AVM, j'avoue avoir du mal à suivre...
en te remerciant
- P.LM
- Contributeur HCFR 2018
- Inscription Forum: 30 Avr 2007 19:30
C'est la nouvelle mouture
- Christophe CHEREL
- Pro-Fabricant
Christophe CHEREL a écrit:C'est la nouvelle mouture
OK, je m'en serais un peu douté ; mais remplaçant de qui: D1 ou D2?
- P.LM
Tarif officiel 2009/2010???
- P.LM
Ah, oui le tarif?! =>7K€
- P.LM
Un, voir des avis sur la chose?
- P.LM
LA difference avec l'AVM-50, c'est uniquement le decodage interne des pistes audio HD ?
- shacard
- Inscription Forum: 16 Oct 2000 2:00
shacard a écrit:LA difference avec l'AVM-50, c'est uniquement le decodage interne des pistes audio HD ?
il était temps, avec +1000 titres au catalogue Bluray
- P.LM
P. le maudit a écrit:il était temps, avec +1000 titres au catalogue Bluray
Et quel pourcentage de VF ?
- shacard
shacard a écrit:P. le maudit a écrit:il était temps, avec +1000 titres au catalogue Bluray
100%
en fait, à ce jour, ce sont 1200 BD dispo en "zone 2" donc VF; maintenant, si tu veux parler du % VF avec audio HD, c'est une très bonne question!
- P.LM
P. le maudit a écrit: maintenant, si tu veux parler du % VF avec audio HD, c'est une très bonne question!
C'est la que la course a aux decodages HD sur notre continent pourrait trouver un sens ... si ce pourcentage etait eleve.
A note que l'AVM50 etait aussi capable que le 50V de digerer des pistes HD puisque pouvant accepter le PCM par l'hdmi sans aucune perte.
- shacard
Et quid du vrai 7.1 qui n'est pas légion sur les BD?
- P.LM
P. le maudit a écrit:Et quid du vrai 7.1 qui n'est pas légion sur les BD?
moi c'est un processeur qui me fair rever mais bien trop cher
- klipschdestras
- Inscription Forum: 13 Aoû 2006 18:34
