Je relance d'une version avec le resampler multithreadé
http://sandbox.slysoft.com/beta/SetupReClock1861.exe1.8.6.1 - 20/01/2010
* New: New quality settings for resampler
* New: Improved quality of resampler
* New: Resampler is now multi threaded
* New: All non-pcm formats are now accepted as bitstream formats
* New: VBS scripts are started from a separate thread, playback will not stop while your script is executed.
* New: Added debug registry value AC3_48k_only. Set it to 1 to instruct ReClock only to use the AC3 encoder on 48k PCM sources.
* New: Added debug registry values ChannelMaskOverride_x for PCM formats, where x stands for the number of channels.
Example: Set ChannelMaskOverride_6 to 0x60f to override the channel mask for 6 channel PCM to use the side speakers, or set it to 0x3F to use the back speakers for the rear channels.
A value of 0 disables channel mask override (default). These are the definitions of the speaker positions:
SPEAKER_FRONT_LEFT 0x1
SPEAKER_FRONT_RIGHT 0x2
SPEAKER_FRONT_CENTER 0x4
SPEAKER_LOW_FREQUENCY 0x8
SPEAKER_BACK_LEFT 0x10
SPEAKER_BACK_RIGHT 0x20
SPEAKER_FRONT_LEFT_OF_CENTER 0x40
SPEAKER_FRONT_RIGHT_OF_CENTER 0x80
SPEAKER_BACK_CENTER 0x100
SPEAKER_SIDE_LEFT 0x200
SPEAKER_SIDE_RIGHT 0x400
SPEAKER_TOP_CENTER 0x800
SPEAKER_TOP_FRONT_LEFT 0x1000
SPEAKER_TOP_FRONT_CENTER 0x2000
SPEAKER_TOP_FRONT_RIGHT 0x4000
SPEAKER_TOP_BACK_LEFT 0x8000
SPEAKER_TOP_BACK_CENTER 0x10000
SPEAKER_TOP_BACK_RIGHT 0x20000
* New: Added debug registry value NotifyOnGreen. Set it to 0 if you don't want your script to be called with GREEN notifications
* New: Added debug registry value NotifyOnStop. Set it to 0 if you don't want your script to be called with STOP notifications
* New: Added debug registry value NotifyOnQuit. Set it to 0 if you don't want your script to be called with QUIT notifications
* Change: Audio only playback uses the specified buffer duration, but it can be set independently with the registry value AudioOnlyPrebuffTime.
* Fix: ReClock could hang, if the Wasapi buffer ran empty or overflowed.
* Fix: Bitstream passthrough was really broken
* Some fixes and improvements
