ocean_78 a écrit:Moi je suis en 1.8.62 et j'en suis très content
Tu as paramétré comment ?
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: cd, imotep27000, J3FF, julien-64, pierrot le fou et 146 invités
Note:
* ReClock must be installed *after* PowerDVD or Arcsoft TMT 3
* Whenever PowerDVD or Arcsoft TMT 3 is updated or reinstalled, ReClock must be reinstalled
* ReClock replaces the ASAudioRenderer.dll in the TMT 3.0 Codec directory. A backup ASAudioRenderer_bak.dll will be created. Do not delete this file, it is required!
1.8.6.9 - 02/06/2010
* New: Improved software volume adjustment
* Some fixes and improvements
1.8.6.8 - 29/05/2010
* New: Software volume adjustment, supports Kernel streaming, Wasapi and Wave out
* Change: Setting volume will be performed in software with WaveOut. DSound volume will still be done using DSound SetVolume() API.
* Note: Adjusting the volume works with players using the DSound volume inteface, e.g. Media Player Classic or Zoom player.
* New: Hitting the ESC key will close the properties window, if it has focus
* New: Clicking the notification icon will close the properties window, if open
* Fix: Setting for hardware resampling wasn't saved / loaded correctly
