I hope someone can give me a few hints or links to the following topics.
I have the following components, an HDTV (Panasonic V20) with a Blu-Ray player and a MacBook connected. I want to have a calibrated playback from both connections. A Spyder 2 is available to me together with Spyder 2.x Pro software, and I also have HCFR installed now (have both OS X and Windows version available, but will play movies only through OS X and likely as MKV files via VLC).
1)
What is the best procedure for obtaining a calibrated MKV playback from the MacBook?
As the Spyder software can make me a ICC profile I assume it can do the job for me. The Spyder Pro software has a HDTV REC 709 target which I believe I should use, right? I am adjusting white balance with the HDTV's RGB gain options, the rest is on default for the custom picture setting Professional 2. Everything else is calibrated by Spyder software resulting in a ICC file to use on the MacBook. Does this seem right / optimal? Should I rather do something with HCFR?
2)
For the LG Blu Ray player, I guess I shall use HCFR together with the AVS HD 709 disc from http://www.avsforum.com/avs-vb/showthread.php?t=948496, right? What is the best tutorial for using that combination?
3)
For regular DVB-C viewing, how do I make a calibration there? I cannot, to my knowledge, inject reference calibration images via the antenna DVB input, or? Perhaps use Spyder software or HCFR with a proper target and let the computer generate the image, but then what should color target be? PAL or HDTV 709? I guess different productions/programs/channels broadcast with different color target or? SDTV vs HDTV or even program to program.
Best regards
Henrik
1 message • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Modération Forum Installations, Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Didi40, Ummagumma81 et 13 invités
Beginner questions (calibrating Panasonic V20)
- henrikolsen
- Inscription Forum: 18 Jan 2011 15:05
1 message
