Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: AlainParis, bebel56, cyberfredxxx, Dandelacan, danydan77, guillaumodore, Jacky67, lekiteurfou, Lobito94, micgui, Miky10, minifrix, misichavichus, Patbon21500, PG222, polo2121, rere130, videoman, yoann2004 et 143 invités
Mede8er MED1000X3D, nouveau boîtier multimédia 3D
Mede8er MED1000X3D
1080p
HDMI 1.4
3D
MKV, BD ISO, BD ISO 3D, DVD ISO, MTS2, AVI, MOV
OGG, FLAC, MP3, WAV
USB 3.0
Ethernet Gigabit
Emplacement pour HDD 3.5'' 3To max
S/Pdif optique + coax
Télécommande rétro-éclairée
Sans ventilateur
DTS-HD MA & Dolby True HD 7.1
Specifications
Processor: RTD1186 • 750Mhz • 512 SLC Flash • 512 DDR3 SDRAM
Video Formats Supported: AVI / BDMV Light / BDISO Light / MKV / TS / TP / TRP / M2TS / MPG / MP4 / MOV / M4V / VOB / ISO / IFO / DAT / WMV / ASF / RM / RMVB / FLV resolution up to 720p / 1080i / 1080p
3D Video: 3D BDISO, Side by Side, Top & Bottom, Frame Sequential, Frame Packing
Video Codecs Supported: MPEG-1-2 / MPEG-4 SP /ASP /AVC (H.264) / XviD / DivX / WMV9 (VC-1) / RealVideo 8/9/10 (up to 720P)
Audio Codec Supported: Mp3 / Mp2 / OGG Vorbis / PCM / LPCM / AAC / RA / Dolby True HD - DTS MA Passthrough on HDMI / AC3 - DTS 5.1 / FLAC up to 24bit 192Khz / WAV / WMA Standard (DRM, & Advanced Profile not supported)
Photo format Supported: JPEG, BMP, GIF, TIFF, PNG File System Supported: FAT32, NTFS, HFS+ (Mac) Video output resolution: NTS, PAL, 480p, 576p, 720p, 1080i, 1080p, 1080p 24hz Input /
Outputs: HDMI 1.4 • Component Video • Composite Video • Stereo RCA • SD • SDHC • Sony Pro Duo Card Slot • SPDIF Optical • Co-Ax Digital • Slave Port USB 3.0, HOST Port x 2 USB 2.0 • IR Jack
Optional WiFi: MED10WFB or MED20PCIE (WiFi is optional unless otherwise stated on the packaging)
Optional Hard Drive: Internal Hard Drive is optional unless otherwise stated on the packaging.
Contents: MED1000X3D, RC, 2 x AA Batteries, AC Adapter, HDMI 1.4 Cable, AV Cable, USB3.0 Cable, HDD Securing Screws.
Specifications subject to change without notice.
DTS, DTS-HD, the Symbol, & DTS or DTS-HD and the Symbol together are registered trademarks of DTS, Inc. © DTS, Inc.
Le test de HD Fever :
http://www.hdfever.fr/2012/09/15/test-m ... lu-ray-3d/
http://www.hdlandblog.com/2012/07/mede8 ... itier.html
- Christophe CHEREL
- Pro-Fabricant
- Inscription Forum: 06 Juil 2001 2:00
- Christophe CHEREL
- Pro-Fabricant
spécifications quasi parfaites hormis la sortie source directe.
Il va falloir que DUNE revoit à la baisse ses prétentions niveau tarif.
- Bobor
- Inscription Forum: 01 Avr 2002 2:00
Une idée du prix?
- locutus2borg
- Inscription Forum: 06 Nov 2006 13:18
envisageant d'arrêter de supporter les caprices d'XBMC sur mon PCHC , je regardais avec intérêts le PopCorn A300 mais là je vais attendre et voir ce que donne le MED1000X3D
- svb
- Inscription Forum: 09 Déc 2003 10:27
ca promet en effet avec le design soucoupe volante moi j'aime!
- uniden
- Inscription Forum: 31 Déc 2009 10:34
svb a écrit:envisageant d'arrêter de supporter les caprices d'XBMC sur mon PCHC , je regardais avec intérêts le PopCorn A300 mais là je vais attendre et voir ce que donne le MED1000X3D
Ce boitier utilise XBMC comme base
- numa001
- Inscription Forum: 18 Mar 2012 8:11
@numa001, ce n'est pas vraiment xbmc qui est capricieux chez mais le PCHC (parametrage télécommande, veille, plugins, drivers, codecs, etc...)
et puis avoir autant de puissance dans un PC qui consomme et qui prend de la place pour obtenir finalement la même chose qu'un petit boitier multimedia...
- svb
et moi qui suit passé d'une dune à un PCHC ConfigKAZ je pense totalement l'inverse .
- Gandalflux
et tu as mis combien de temps à le paramétrer ?
- Mr Eric
- Inscription Forum: 19 Mai 2004 10:33
Et le prix aussi , parce que pour la lecture de BD ou iso complète, il faut un logiciel payant en plus il me semble.
- costaud
- Contributeur HCFR 2019
- Inscription Forum: 05 Oct 2004 20:51
Bobor a écrit:spécifications quasi parfaites hormis la sortie source directe.
vu qu'on connait pas encore le tarif de ce modèle, on voit pas trop ce que devrait revoir HDI...
Bon, reste que ça commence à devenir super chaud pour eux et qu'ils ont sacrément intérêt à sortir de nouveaux modèles qui déchirent à l'IFA
- Mr Eric
Mr Eric a écrit:et tu as mis combien de temps à le paramétrer ?
Heu sincèrement 25 min je ne touche pas à tout tout le temps
J'ai eut un petit pb au début en VC1 mais maintenant plus rien
(Quoi que si un effet bizard sur les ton noir de certain films mais il me semble que je l'avais aussi avec ma Dune je me demande si mon câble HDMI n'est pas en cause)
costaud a écrit:Et le prix aussi , parce que pour la lecture de BD ou iso complète, il faut un logiciel payant en plus il me semble.
Alors 1 plus chère oui je dirais 50% de plus . Masi je n'ai spas choisie du petit Matos j'suis en WC et FanLess ce qui alourdie la facture ( inutilement pour certain)
Mais d'un autre coté je ne pouvais plus utilisé ma dune ma base est trop grosse pour elle et je n'étais pas sur que les nouvelle smart supporte ma base alors acheté pour me retrouver dans la même galère bof.
Et effectivement j'ai 2 gros Reproche à faire .
1 pas de système de template à la YaDIS avec l'affichage de 4 ou 5 piste audio car XBMC ne sait pas allez lire les type de ST et piste audio de mes RIP BRD.
2 pas de lecture des menue car je suis en Full Gratis
A coté de ça j’ai un vrai PC qui me permet de faire ma démat, de lire mes mails, de jouer, les pote vienne ils veulent un accées wab pas la peine de descendre allumer le monstre d'en bas Tu Turn On le clavier le PC démarre et hop tous est là
Enfin je suis bien conscient que ce sont deux utilisation bien différente , et je suis aussi méga conscient que l'on est pas beaucoup à avoir une base de dématérialisation vidéo équivalente à la mienne.
Mais ne vous inquiétez pas j'ai toujours ma bonne vielle dune et je compte en reprendre une pour seulement la partie DA de ma base et je la collerais en bas
- Gandalflux
http://www.mediasmartserver.net/2012/07 ... announced/
Ca confirme le prix des préco sur leur site de vente d'afrique du sud : http://www.mede8ershop.co.za/MED1000X3D ... h3kfh88nm3
photo par rapport à l'ancienne gamme :
The X3 will be released in certain regions like South Africa and some Asian countries end July / early August
It will be released at the IFA Show in Berlin and stock will be available in Europe from 1st Sept at SRP of Euro199 for bare bone unit.
Stock shipment to USA dealer mid to end August.
- Mr Eric
moi cela fait 7 ans que j'ai un PCHC (remplacé, mis à jour et upgradé régulièrement) et j'en ai marre d'avoir toujours un truc à mofidifer et lorsque cela est fait on se rend compte que ce qui était stable ne l'est plus ! j'ai testé windows media center, 7 media center, xbmc seul, xbmc avec DSplayer, XBMC config KAZ, XBMC avec (ffdshow, mpcplayer, madvr, lavsplitter, autofrequency, reclock, etc...) toutes les semaines il y a une mise à jour à faire et quand on croit que tout est OK, on laisse les "manettes" aux gamins et le soir plus rien ne fonctionne...
le budget ? une fortune si on compte les mise à jours, les petits achats (disque dur puis ssd, alim modulaire, ventilos super méga silencieux, carte graphique, télécommande, boitier "spécial home cinema" hors de prix) maintenant j'ai un NAS sur lequel sont stockés tous mes films, le PCHC ne sert plus qu'à aller lire ces films, un boitier silverstone quasiment vide qui parait gigantesque à coté d'un boitier Popcorn ou Dune , 4 ventilos (oui 4) silencieux, une acrte graphique qui consomme, une alimentation modulaire utilisée à 15 %, un lecteur Blueray bruyant et difficle à paramétrer, bref j'avoue avoir envie d'essayer autre chose !!!! même si j'adore XBMC et que son utilisation fait toujours "Wahou" lorsque je le montre à des copains !
- svb
