Samsung Galaxy S III & Behringer UCA202 :
Android phones and USB DACs
http://nwavguy.blogspot.fr/2011/02/behringer-uca202-review.html
Samsung Galaxy S III > flux audio numérique >> câble USB OTG >> DAC USB/ampli-casque Behringer UCA202 >> casque
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: bandicootfr, Hoian et 94 invités
Smartphone + DAC, question d'un beotien...
- DanBa
- Contributeur HCFR 2024
- Inscription Forum: 16 Oct 2007 17:46
Samsung Galaxy S III & Objective DAC (ODAC) :
http://www.head-fi.org/t/624102/dap-wit ... st_8674007
http://nwavguy.blogspot.fr/2012/05/odac-may-update.html
Galaxy S III > flux audio numérique >> 4-in-1 connection kit au lieu du câble USB OTG >> ODAC >> ampli-casque Headstage Arrow G3
- DanBa
Samsung Galaxy S III & Stoner Acoustics UD100, un minuscule DAC USB à prix abordable utilisant la puce ESS Sabre ES9023 :
http://forum.lowyat.net/index.php?showtopic=2452730&st=160&p=54596977&#entry54596977
http://www.inearmatters.net/2012/09/tiny-dac-big-sound-impression-of-stoner.html
Galaxy S III > flux audio numérique >> UD100 >> écouteurs Audio Technica ATH-CK100
Le niveau sonore est suffisant, un ampli-casque n'est pas nécessaire.
"Volume level is sufficient, no amp required."
- DanBa
Samsung Galaxy S III & Objective DAC :
NwAvGuy: ODAC May Update
NwAvGuy: ODAC Released
Galaxy S III d'origine > flot audio numérique >> ODAC (i.e. Epiphany Acoustics E-DAC) >> ampli-casque Neco V3
Les louanges :
ODAC
Epiphany Acoustics E-DAC 24-bit USB DAC Review | AVForums.com - UK Online
Brief Odac impressions
Neco V3
NECO SOUNDLABS PORTABLE V.2 AMP
new V3 DUAL AMP portable headphone amplifier | eBay
ODAC + Neco V3
"It is by far the best usb dac i have ever owned. No thoughts of bothering to look for an upgrade. At my age i am sure it will see me out.
Using it with a Neco Soundlab V3 and Grado SR-325is's.Nirvana at last...."
Epiphany Acoustics E-DAC Review Thread
"ODAC + NECO V.3 + Sennheiser HD580 = A MATCH MADE IN HEAVEN.
I can't tell you how beautiful this rig sounds. We all know how well the HD580/600 scales with better sources and amps.. but synergy is often undervalued. The ODAC is beautifully resolving and clean.. but the Neco really steals the show, IMO."
"It's downright disturbing how incredible this combo sounds with the HE-500. In fact, it should probably be illegal (**looks at Arizona**).
When driving the HE-500. I like this combo more than the O2."
Les louanges :
ODAC
Neco V3
ODAC + Neco V3
- DanBa
VentureCraft considère Android & standard USB audio comme un nouveau marché potentiel.
Venturecraft retarde la date de sortie de son dernier ampli-casque Go-Dap X afin de le modifier pour qu'il puisse fonctionner en combinaison avec le Samsung Galaxy S3.
http://www.venturecraft.jp/gadget_en/index.php
Samsung Galaxy S3 d'origine > flux audio numérique >> mini câble USB OTG de VentureCraft >> DAC USB /ampli-casque Go-Dap X >> casque
[youtube]86cOdNXv1Iw[/youtube]
- DanBa
Samsung Galaxy S III & USB DAC / ampli-casque Epiphany Acoustics EHP-O2D :
http://www.totallydubbed.net/2012/09/17/unboxing-pictures-initial-impressions-of-the-epiphany-acoustics-ehp-o2d-dac-headphone-amplifier-mj2-interconnect/
http://noblehifi.blogspot.fr/2012/07/epiphany-acoustics-ehp-02d-review.html
http://hifipig.com/epiphany-acoustics-ehp-o2-portable-headphone-amplifier/
http://epiphany-acoustics.co.uk/our-products/heaphone-amplifiers/ehp-o2d-miniature-desktop-headphone-amplifier-with-usb-dac/
Samsung Galaxy S III > sortie audio numérique >> câble USB OTG >> Epiphany Acoustics EHP-O2D (i.e. ODAC + O2) >> Denon AH-D2000
- DanBa
Samsung Galaxy S III & minuscule Stoner Acoustics UD100 à prix abordable :
http://forums.hardwarezone.com.sg/70075257-post210.html
http://www.head-fi.org/t/626632/tiny-dac-big-sound-impression-of-stoner-acoustics-ud100-vs-odac
http://stoneracoustics.blogspot.fr/
Galaxy S III d'origine > sortie numérique >> UD100 >> Sennheiser IE80
Comme le fameux ODAC, le coeur du Stoner Acoustics UD100 est la puce de conversion ESS Sabre 24 bits.
http://www.esstech.com/PDF/ES9023%20PB%20Rev%200.2aPB%20110117.pdf
- DanBa
Samsung Galaxy S III & DAC USB / ampli-casque xDuoo XP-1 :
Source
xDuoo XP-1
Galaxy S III d'origine > sortie numérique >> xDuoo XP-1 >> casque
Source
xDuoo XP-1
- DanBa
AudioQuest Bumblebee Android DAC:
http://www.avland.co.uk/aasp/audioquest/1220/bumblebee/bumblebee.asp
"Designed specifically for Android devices
24-bit ESS Sabre conversion chip
Supports all music files including 24-bit/192kHz lossless
Drives headphones directly with 3.5mm mini-jack output
Fixed or Variable output modes
Asynchronous transfer for accurate digital timing
64-position (computer-controlled) analog volume control
Isolated dual master clocks
Colour changing LED to indicate source sample rate"
Je me demande si le DAC Android Bumblebee d'AudioQuest est un DAC USB standard auto-alimenté (self-powered USB DAC) ou un DAC USB spécifique Android.
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/135
Le DAC Bumblebee serait vraisemblablement un DAC USB standard DragonFly d'AudioQuest intégrant une batterie rechargeable, car il peut supporter un flot audio numérique de 24 bits / 192 kHz.
http://www.head-fi.org/t/617241/audioquest-dragonfly-review-affordable-outstanding-tiny-dac-amp
http://www.stereophile.com/content/audioquest-dragonfly-usb-da-converter
Or un DAC USB spécifique Android ne peut supporter que du 16/44.1kHz:
http://developer.android.com/tools/adk/aoa2.html#audio-support
Si le Bumblebee est un DAC USB standard, lors de son utilisation avec un PC ou un Mac, la qualité du rendu sonore du Bumblebee devrait être supérieure à la qualité du rendu sonore du DragonFly grâce à une alimentation sur batterie non polluée.
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/165#post_8540151
- DanBa
Dans la famille Galaxy, il y a des petits frères qui ont l'avantage d'être abordables en terme de prix : (le SII), le Ace et le Y. Sais-tu si l'USB audio fonctionne sur ceux là ?
- robob
- Inscription Forum: 21 Mar 2007 19:23
A ma connaissance, pas encore.
- DanBa
L'USB audio est aussi activée sur le Samsung Galaxy Note II fonctionnant sous Android 4.1 Jelly Bean:
http://www.eprice.com.tw/mobile/talk/4523/4815783/1/1/
Galaxy Note II d'origine > sortie numérique >> câble USB OTG >> DAC USB / ampli-casque iBasso D12 Hj >> écouteurs Westone UM3X
- DanBa
Encore une chaîne hifi portable bâtie autour du DAC USB UD100, avec le casque FitEar TO GO! 334, le meilleur casque intra-auriculaire du monde selon Steve Guttenberg:
http://www.head-fi.org/t/597146/fitear- ... st_8754519
http://news.cnet.com/8301-13645_3-57486 ... -togo-334/
Samsung Galaxy S3 d'origine > sortie numérique >> câble USB OTG >> DAC USB Stoner Acoustics UD100 >> ampli-casque HeadAmp Pico Slim >> casque intra-auriculaire FitEar TO GO! 334
- DanBa
Samsung Galaxy S III & Matrix Mini-i:
http://www.headfonia.com/matrix-mini-i-balanced-dac/
http://www.head-fi.org/t/595071/android ... st_8768166
Galaxy S III > sortie numérique >> câble USB OTG >> Matrix Mini-i >> casque ou ampli
- DanBa
Une liste d'équipements USB DAC standards permettant de contourner le convertisseur numérique-analogique interne et donc aussi de l’ampli interne du smartphone Samsung Galaxy Note II :
Samsung Galaxy Note II > sortie audio numérique >> câble USB OTG >> USB DAC standard >> ampli ou ampli-casque >> enceintes ou casque
. iBasso D12 (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=63
http://www.head-fi.org/t/595071/android ... st_8750862
. Objective DAC (ODAC):
http://epiphany-acoustics.co.uk/our-pro ... e-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=46
http://www.headnhifi.com/index.php/shop/objective/odac
http://www.head-fi.org/t/595071/android ... st_8758515
. ODAC+O2 (USB DAC/amp):
http://epiphany-acoustics.co.uk/our-pro ... h-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=48
http://www.headnhifi.com/index.php/shop ... 0527192048
. Sony PHA-1 (USB DAC/amp):
http://www.touchmyapps.com/2012/10/09/s ... in-review/
http://www.head-fi.org/t/595071/android ... st_8769593
. VentureCraft Go-Dap X (USB DAC/amp):
http://venturecraft.jp/gadget_en/index.php
Comme le Galaxy S III à base de puce Exynos, le Galaxy Note II à base de la même puce Exynos peut fonctionner avec l’iBasso D12, l’ODAC et le VentureCraft Go-Dap X, et a surtout quelque difficulté de fonctionnement avec le HeadAmp Pico.
Probablement, le Galaxy Note II et le Galaxy S III pourraient fonctionner avec les mêmes USB DAC.
viewtopic.php?f=1366&t=30014978&p=177090897#p177090897
- DanBa
