Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Alex8633, Bidib, flipper203, fouyas, Fredetsylvie, jl.dudu et 178 invités
Nouveau DAC/Preamp: Benchmark DAC2 HGC
Message » 12 Oct 2012 2:47
Je résume:
nouvel USB Asynchrone,
nouveau circuit de réduction de jitter encore plus performant,
conversion DSD,
4 puces D/A 32 bit pour un rapport S/N jamais vu,
headroom numerique de 3.5 dB pour éviter les intersample peak distorsion sur les mauvais masters,
nouveau contrôle de volume combinant gain variable, résistances passives, potard et volume numerique pour moins de distorsion.
Un bel appareil en somme, trop cher a mon avis, mais néanmoins un bel appareil.
The DAC2 HGC outperforms the DAC1 in every respect. It has lower noise, lower distortion, improved accuracy, outstanding musical detail, precise stereo imaging, an advanced digital filter design, and a new high-sample-rate Asynchronous USB Audio interface. All inputs are fully isolated from interface jitter by Benchmark's new UltraLock2™ jitter attenuation system. Internal digital processing and conversion is 32-bits, and includes 3.5 dB of headroom above 0 dBFS. Four balanced 32-bit D/A converter are summed together for each balanced output. The performance of the DAC2 HGC exceeds the measurement limits of today's state-of-the art test equipment. Discover the analog sound of the DAC2 HGC.
New Features
DAC1 customers requested many new features which have been integrated into the new DAC2 HGC:
Sample Rate Display
Word Length Display
More Digital Inputs (5 total)
More Analog Inputs (2 total)
More Analog Outputs (3 total)
Digital Pass Through
Native DSD Conversion
Polarity Switch
Asynchronous USB 2.0
Driverless Asynchronous USB 1.1
Home Theater Bypass
Bi-Directional 12 Volt Trigger
Power Switch
Low Power Consumption
New Benchmark Technologies
Benchmark introduces some exciting new technologies in the DAC2 HGC:
Hybrid Gain Control
High-Headroom DSP
UltraLock2™ Jitter Attenuation System
Quad 32-bit balanced D/A Conversion System
Multi-Mode Asynchronous USB Audio System
Distributed Power Regulation
Hybrid Gain Control
"HGC" is Benchmark's unique Hybrid Gain Control system. The DAC2 HGC combines active analog gain control, passive low-impedance attenuators, a 32-bit digital gain control, and a servo-driven volume control. All inputs are controlled by the rotary volume control. This volume control moves in response to commands from the remote control. Analog inputs are never converted to digital, and digital inputs never pass through an analog potentiometer. Digital inputs are precisely controlled in the 32-bit DSP system. The DSP system preserves precise L/R balance, and precise stereo imaging, while avoiding any source of noise and distortion. Benchmark's unique passive output attenuators provide distortion-free gain reduction without reducing the dynamic range of the converter. The attenuators optimize the gain staging between the DAC2 HGC and the power amplifier. This optimization is absolutely essential for maximizing the dynamic range of the entire playback system. Much of the success of the DAC1 converters can be attributed to the passive output attenuators. Musical details can be obscured by system noise whenever a preamplifier and power amplifier are improperly matched. The" HGC " system will make full use of your power amplifier's dynamic range. Experience new details in your favorite recordings.
All digital inputs on the DAC2 HGC support native DSD conversion. DoP 1.0 is automatically detected on all digital inputs, and the system seamlessly switches to native DSD conversion. DoP 1.0 is supported by many media players, and DSD downloads are now available from several sources.
UltraLock2™ is an improved version of the UltraLock™ system used in the DAC1 and ADC1 product families. DSP processing is 32-bits, DSP headroom is 3.5 dB, sample rate is 211 kHz, and jitter-induced distortion and noise is at least 140 dB below the level of the music - well below the threshold of hearing. Benchmark's UltraLock2™ system eliminates all audible jitter artifacts.
High Headroom DSP - with 3.5 dB "Excess" Digital Headroom
All of the digital processing in the DAC2 HGC is designed to handle signals as high as +3.5 dBFS. Most digital systems clip signals that exceed 0 dBFS. The 0 dBFS limitation seems reasonable, as 0 dBFS is the highest sinusoidal signal level that can be represented in a digital system. However, a detailed investigation of the mathematics of PCM digital systems will reveal that inter-sample peaks may reach levels slightly higher than +3 dBFS while individual samples never exceed 0 dBFS. These inter-sample overs are common in commercial releases, and are of no consequence in a PCM system until they reach an interpolation process. But, for a variety of reasons, virtually all audio D/A converters use an interpolation process. The interpolation process is absolutely necessary to achieve 24-bit state-of-the art conversion performance. Unfortunately, inter-sample overs cause clipping in most interpolators. This clipping produces distortion products that are non-harmonic and non-musical . We believe these broadband distortion products often add a harshness or false high-frequency sparkle to digital reproduction. The DAC2 HGC avoids these problems by maintaining at least 3.5 dB of headroom in the entire conversion system. We believe this added headroom is a groundbreaking improvement.
Multi-Mode Asynchronous USB System
Benchmark's USB system supports USB Audio 2.0, DSD, and USB Audio 1.1. It is frequency agile, and will follow sample rate changes initiated by the computer and/or the media playback software. In all modes the USB communications are asynchronous in order to eliminate unnecessary sources of jitter.
The DAC2 HGC has a low-jitter master clock which controls the transfer of audio data from the computer to the USB sub-system. The computer asynchronously transfers audio data to a buffer in the DAC2 HGC. The contents of the buffer are then asynchronously transferred to the D/A conversion sub-system. This second asynchronous transfer eliminates any traces of jitter that accumulate as the data is transferred between the USB and conversion subsystems. No traces of jitter-induced distortion are measurable to our measurement limits (better than -150 dBFS). This truly represents the state-of-the art. Enjoy the convenience of computer playback without compromise. The Asynchronous USB system supports USB Audio 2.0 for high-resolution 192kHz, and DSD playback. No drivers are required for MAC operating systems. An easy-to-install driver adds 192 kHz and DSD capabilities to Windows operating systems.
An asynchronous, driverless USB Audio 1.1 mode supports sample rates up to 96 kHz. This USB mode can be selected from the front panel or from the remote control. The driverless USB Audio 1.1 mode allows quick plug-and-play connections to Windows, MAC, iOS, and Linux operating systems without installing drivers. Just plug in the USB, and the DAC2 HGC becomes an available audio device.
The USB subsystem remains active when the DAC2 HGC is powered down. This prevents interruptions to the computer playback operations and eliminates the need to reconfigure the computer every time the converter is turned on.
Quad 32-bit Balanced Conversion System
Four balanced 32-bit D/A converters deliver audio to Benchmark's low-impedance current to voltage converters. The 4:1 redundancy reduces noise and distortion to levels that set new benchmarks. The conversion system at the core of the DAC2 HGC is as good as it gets. The analog circuits that follow the D/A converter are carefully designed. Benchmark has leveraged its long history of building high-end analog audio equipment, in order to create an outstanding output stage.
Diagnostic Tools - Sample-Rate and Word-Length Indicators
Ever wonder why that 192 kHz 24-bit download on your computer just doesn't sound right? Your media player may be down-sampling to 44.1 kHz and/or truncating to 16-bits. Many media players apply poor-quality sample rate conversion and truncation. Fortunately these problems can be eliminated with the selection a good frequency-agile media player. The sample-rate and word-length displays on the DAC2 HGC confirm the proper operation of your media player.
Polarity Switch
You may encounter recordings with inverted polarity. The DAC2 HGC includes a polarity switch to correct the problem.
Home Theater Bypass
The DAC2 HGC can be integrated into a home theater system. Typically the DAC 2 HGC drives the left and right power amplifiers, and an analog feed from the home theater system is connected to either of the analog inputs on the DAC2 HGC. A programmable Home Theater Bypass function sets the pass-through gain to unity when the surround system is active. The DAC2 HGC includes an indicator light that is illuminated when bypass is active.
The second coaxial input can be reconfigured as a digital output. In output mode, any selected digital input (including USB) will pass through to the coaxial output. The digital pass through is bit-transparent and even supports DSD (DoP 1.0). Dolby digital and DTS formats can be passed through to a surround processor.
Benchmark re-invents the 12 volt trigger. The trigger connection on the DAC2 HGC can be used as an input or output or both, and is compatible with any common 12 volt trigger input or output. The trigger can be used to turn a power amplifier on or off automatically. The DAC2 will also respond to a 12 volt trigger and follow the actions of another audio component.
Power Switch
The power switch can place the DAC2 HGC in standby, or full shut down. In full shut down, the unit will still respond to the trigger input and the IR remote control. Power consumption is less than 0.5 W in full shut down.
The DAC2 uses high-efficiency low noise power supplies and may be operated from any standard international voltage without adjustment. Power consumption is 12 W typical.
To achieve the lowest possible noise, the DAC2 HGC uses distributed power supply regulation. Each critical subsystem has at least one dedicated low-noise voltage regulator.
khaos974
Inscription Forum: 20 Mar 2006 20:46
Message » 12 Oct 2012 17:14
Ahaaaaa!
un autre DAC/préampli avec une entrée bypass, ce qui fait de lui un concurent au W4S DAC2! :oldy:
La conversion DSD est elle uniquement dédiée à la lecture du SACD(déjà pas mal interressant dans mon cas...), ou certains fichiers dématérialisés peuvent l'exploiter?
Quel est son PPI justement? j'ai vu autour des 2000$, alors je pense que ça sera autour des 2000€, mais on peut rêver et penser le trouver autour de 1800€ :roll:
Télécommandable? :D
loulou65
Inscription Forum: 12 Sep 2008 6:03
Message » 12 Oct 2012 18:53
loulou65 a écrit:Ahaaaaa!
Télécommandable? :D
J'imagine que c'est en Demat pour le DSD. Sinon j'ai vu trainer 1664 euros, mais je ne connais pas le site: https://www.helios-online.nl/shop/produ ... hgc-silver
khaos974
Message » 20 Oct 2012 12:22
Comme ce convertisseur n'a que des entrées numériques sur prises RCA (probablement du S/PDIF) et optique, je pense qu'il n'est pas possible de l'interfacer avec des lecteurs ou des transports SA-CD, qui utilisent d'autres liaisons numériques plus performantes en raison du débit et de la fréquence d'échantillonnage du DSD. Seule la lecture de fichiers DSD stockés sur mémoire et transmis par la prise USB est peut-être possible ?
Scytales
Contributeur HCFR
Message » 20 Oct 2012 12:39
Scytales a écrit:Comme ce convertisseur n'a que des entrées numériques sur prises RCA (probablement du S/PDIF) et optique, je pense qu'il n'est pas possible de l'interfacer avec des lecteurs ou des transport SA-CD, qui utilisent d'autres liaisons numériques plus performantes en raison du débit et de la fréquence d'échantillonnage du DSD. Seule la lecture de fichier DSD stockés sur mémoire et transmis par la prise USB est peut-être possible ?
La notice n'est pas encore sortie, mais tu tapes probablement juste.
khaos974
Message » 20 Oct 2012 13:13
C'est plus qu'un indice, non ? Et ce n'est que la copie du descriptif posté ci-dessus.
haskil
Message » 20 Oct 2012 14:38
Oui, où avais-je la tête? :ane:
khaos974
Message » 20 Oct 2012 21:33
Très, très, très alléchant ce nouveau Benchmark !!! Avec le NAD M51, et outre le Totaldac (le prix... :cry: sans soute justifié mais...), il fait vraiment partie des produits que j'aimerai absolument écouter chez moi :D
Merci pour les liens :)
David :wink:
DaveStarWalker
Inscription Forum: 25 Aoû 2006 11:08
Message » 20 Oct 2012 22:54
Oui très beau produit :D
palm
Inscription Forum: 30 Nov 2003 1:34
Message » 09 Nov 2012 15:40
Hello, il n'est pas encore en vente en Europe ce beau Dac ?
Nico
Inscription Forum: 13 Oct 2003 19:23
Message » 09 Nov 2012 18:39
Vu chez magic mastering dans les 2000€...
Il a l'air intéressant ce DAC, les multiples entrées SPDIF c'est bien vu.
En revanche le "3.5 dB "Excess" Digital Headroom" ressemble plus à un artifice marketing qu'autre chose.
De plus le "superlock" n'a pas l'air déconnectable donc heureusement que l'oversampling est fait proprement...
gatzou
Inscription Forum: 07 Fév 2010 13:11
Message » 19 Nov 2012 1:30
:D Super ce nouveau Benchmark! Moi ce qui surtout m'intérésse, c'est le Bypass Hometheater! Je vais pouvoir garder mon fidèle EAD signature pour le HC, et je pourrais enfin lire les nouveaux formats musicaux ! :oops: :wink:
alfachris
Inscription Forum: 12 Aoû 2003 21:36
Message » 19 Nov 2012 1:53
:D J'avais déjà beaucoup aimé le Dac1...le Dac2 HGC doit être terrible, vu le CR : :o :wink:
http://everythingaudionetwork.blogspot. ... media.html
alfachris
Message » 19 Nov 2012 10:18
Le dac sera prochainement disponible en France (1à 2 semaines).
Il sera proposé chez Thomann à 2333€ alors qu'il devrait tourner chez nous via l'importateur à 1995€.
Victime de son succès, l'usine est en rupture de stock, les premiers exemplaires ont été rapidement vendus.
Il fera un petit séjour à la maison courant décembre histoire de le comparer au fantastique Mytek DSD 192 utilsant la même Dac chip (Sabre 9018) et aux caractéristiques similaires.
jc30
Inscription Forum: 01 Nov 2004 23:54
Message » 19 Nov 2012 13:13
jc30 a écrit:Bonjour,
J'attends de voir le test stereophile, les gens de chez Benchmark ont généralement mesure le DAC 2 a qqch comme +20 dBV.
Il sera probablement tres bon au banc de test, mais je veux savoir s'il sera exceptionnel, ca serait pas mal de comparer avec des ref plus standard, genre sortie a 1V ou 2V.
PS: Si tu cherches un très bon DAC a base de ESS 9018, il y a l'Anedio DAC 2 a $1470.
khaos974
